Type 4 engine tin
pioneer1
pioneer1 is offline
PostPosted: Wed Feb 24, 2016 3:08 pm    Post subject: Type 4 engine tin Reply with quote
Reassembling all the painted engine tin today. Everything went pretty smooth until I realized I had one piece left over...yikes. In the Haynes manual on page 21 it's called "warm air duct (R rear)" Rear as in near alternator or near firewall? I can't see/figure out where it goes at such a late place in the assembly. Anyone?
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
bigbore
bigbore is offline
PostPosted: Wed Feb 24, 2016 3:50 pm    Post subject: Re: Type 4 engine tin Reply with quote
photo please.
where its cold and snowy
raygreenwood
raygreenwood is offline
PostPosted: Wed Feb 24, 2016 3:58 pm    Post subject: Re: Type 4 engine tin Reply with quote
If memory serves it has one or two botts that bolt to the 3/4 cylinder side cylinder cover plate....listed as part #2 in the lower picture on page 21.....and has two bolts that attach it ro part # 5 in the lower picture which is the 3/4 lower "sled tin".
You should be able to put it on after removing the lower sled tin ......with a little wiggling. Ray
udidwht
udidwht is offline
PostPosted: Wed Feb 24, 2016 4:45 pm    Post subject: Re: Type 4 engine tin Reply with quote
Or perhaps the warm air duct that goes from 1-2 side into the engine bay stock air cleaner set up.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
NGK BP6ET plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
Tcash
Tcash is offline
PostPosted: Wed Feb 24, 2016 4:57 pm    Post subject: Re: Type 4 engine tin Reply with quote
1972-73-74 Type IV (4) Engine Tin
Please do not take the fan apart. You would need to realign and balance it.
pioneer1
pioneer1 is offline
PostPosted: Wed Feb 24, 2016 5:05 pm    Post subject: Re: Type 4 engine tin Reply with quote
010-27 is the culprit
busdaddy
busdaddy is offline
PostPosted: Wed Feb 24, 2016 5:18 pm    Post subject: Re: Type 4 engine tin Reply with quote
You can't just leave it out if that's what you are hinting at, try to gently jam it in but I suspect you'll have to move a step backwards before proceeding further.
I know it's exciting to be remantling but now's the time to do it right, it won't be any easier later.
pioneer1
pioneer1 is offline
PostPosted: Wed Feb 24, 2016 5:35 pm    Post subject: Re: Type 4 engine tin Reply with quote
Great videos but...The you tube video leaves out the installation of this part. Looking at the alternator,is it on the right surrounding the alternator or firewall end?
bigbore
bigbore is offline
PostPosted: Wed Feb 24, 2016 5:46 pm    Post subject: Re: Type 4 engine tin Reply with quote
Like I said POST A PHOTO of the tin these numbers mean nothing.
Gregg in the 603
Gregg in the 603 is offline
PostPosted: Wed Feb 24, 2016 5:50 pm    Post subject: Re: Type 4 engine tin Reply with quote
Right? I was thinking the same thing. Then you said it the first time.
Then I thought the same thing....
1979 Mexico Beige Westy auto
Dirty Dover, NH
pioneer1
pioneer1 is offline
PostPosted: Wed Feb 24, 2016 5:58 pm    Post subject: Re: Type 4 engine tin Reply with quote
bigbore
bigbore is offline
PostPosted: Wed Feb 24, 2016 6:00 pm    Post subject: Re: Type 4 engine tin Reply with quote
Ok maybe this will speed things along these two are on the right side of the engine one is up by the firewall and ones behind the alt which one?
Goodhand77
Goodhand77 is offline
Just rebuilt mine recently and took a lot of Work to makesure I had ALL the tin first clean and shiny
So post a photo of the extra piece and we can all stop trying to guess Smile
my world consists of my three girls , my wife and my daughters
and my 72'S!!!!!
1972 beetle sedan almost original
1972 westfalia current project, and loving it!!!
bigbore
bigbore is offline
PostPosted: Wed Feb 24, 2016 6:03 pm    Post subject: Re: Type 4 engine tin Reply with quote
That one ok pull the blower housing.
Goodhand77
PostPosted: Wed Feb 24, 2016 6:05 pm    Post subject: Re: Type 4 engine tin Reply with quote
Sorry photos came up slow that piece fits in on alternator side near rear of bus so rear passenger side pretty sure it just kinda snaps into place as you mount other pieces no bolts hold it I place
I will go have a closer look at mine
But you need to install for sure directs heat / air flow
These other guys really know there stuff so don't ignore their advice
and my 72'S!!!!!
1967250s
1967250s is offline
PostPosted: Wed Feb 24, 2016 6:15 pm    Post subject: Re: Type 4 engine tin Reply with quote
pioneer1 wrote:
Ok, that piece goes to the rear of #2 cylinder. The top edge there in the pic goes against the engine case. That hole at top right is the cable from the thermostat, so is upper left. The screws at the bottom secure the top right tin over the cyllinders. To get it in the fan housing will need to be loosened up so it can be slid in. The rear edge goes under the fan outlet lip and flap. You kind of have to hold it in position and push the fan in to hold it there.
'72 Elm Green Deluxe
pioneer1
pioneer1 is offline
PostPosted: Wed Feb 24, 2016 6:38 pm    Post subject: Re: Type 4 engine tin Reply with quote
thanks-I'll try tomorrow
Tcash
Tcash is offline
PostPosted: Wed Feb 24, 2016 8:04 pm    Post subject: Re: Type 4 engine tin Reply with quote
There are 6 vids.
https://youtu.be/pHamKMIyKWQ?t=250
SGKent Premium Member
SGKent is offline
PostPosted: Wed Feb 24, 2016 9:05 pm    Post subject: Re: Type 4 engine tin Reply with quote
BTW TO STRESS WHAT TCASH posted - taking the fan apart is a no-no. Without a lathe and time on your hands it is near impossible to get it running true again. Ask me how I know.
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
pioneer1
pioneer1 is offline
PostPosted: Thu Feb 25, 2016 6:52 am    Post subject: Re: Type 4 engine tin Reply with quote
All done-simply slip that piece of tin in it's place...FIRST! haha- will nominate the videos for a sticky
