1952 Deluxe
DSweinhagen
DSweinhagen is offline
PostPosted: Fri Mar 17, 2017 3:02 pm    Post subject: 1952 Deluxe Reply with quote
Hi- I'm starting this thread to document a good friend/client's 1952 Deluxe. The bus was purchased in the early 1990s and I believe came out of the Modesto, California area. I've heard it was a known bus so if anyone has info or pictures, feel free to post.
It was fairly complete and had been a driver with a later bug 36hp but hadn't been on the road for a while. I remember putting a new transmission in it, going through the brakes and putting new tires on it and getting it back on the road. The bus was left that way through the mid to late '90s. Here's a couple picts when we drove it to Jerome, probably around 1998...
Sometime around 2000 there was a decision to restore it. We disassembled it and I had the body media stripped and got started on the bodywork. That ended up being short lived as the owner made a move a couple hours north and shortly after that I moved across town. We decided to put the bus in storage up in Northern Arizona and I'd get back on it once I was settled into my new place... So 15 years or so later, I went back up and got it. I can't seem to find any pics of the work I did on it back then but it wasn't very much. I'll do my best to keep this thread updated. Here's a couple pics back in Phoenix and off the trailer...
David S
GTV
GTV is offline
PostPosted: Fri Mar 17, 2017 3:47 pm    Post subject: Re: 1952 Deluxe Reply with quote
Wow, Jerome '98 was the first year I attended Smile Looking forward to the progress!
EMPI Power Rules!
DSweinhagen
PostPosted: Fri Mar 17, 2017 5:15 pm    Post subject: Re: 1952 Deluxe Reply with quote
Now it's in the shop, emptied out and deciding where to start. Obviously it's pretty good for a '52, though it does have its share of damage and odd localized rust. In addition to that, some PO went around drilling and poking holes where I guess they thought it needed to drain. It probably helped though many areas they hammered on a screwdriver till it tore through the metal stretching it pretty good in spots.
My plan is to preserve as much metal as possible. With that said the right side is the worst and the plan is to go all the way with this bus, so door fitment will be important. Here are some picts of the quarter panel and cargo doors...
Luckily we were able to source some new sheetmetal a while back.
David S
obus
obus is offline
PostPosted: Fri Mar 17, 2017 6:09 pm    Post subject: Re: 1952 Deluxe Reply with quote
Looking forward to watching this one!! Popcorn
If anyone can do this bus justice it's you! I still get compliments on the work you did on my mango.
ScideHornet wrote:
Hey man, thats a green mango .......
http://instagram.com/vwbusbuc
**PARTS WANTED:
http://www.thesamba.com/vw/classifieds/detail.php?id=527289
https://www.thesamba.com/vw/classifieds/detail.php?id=2034690
early July 1959 Mango Standard Bus aka Obus
DSweinhagen
PostPosted: Fri Mar 17, 2017 6:43 pm    Post subject: Re: 1952 Deluxe Reply with quote
I was reluctant to go immediately to the new sheetmetal... So I took some measurements and messed around with the cargo doors for a little bit but didn't see it coming out well. Both the lower hinges and mounting points on the pillars were wasted, as I know most barn doors are, but I didn't want to end up with a bunch of time into repair and not be really happy with it. So I tried to fit the new doors, but they weren't even close with the damaged pillars and ended up scabbing in the mounting point on the B-pillar to get the door where I wanted it. Now I have the forward cargo door where I want it and am comfortable using it as a base-point to fit the rear up to...
Some more quarter panel damage, and then removed...
I was hoping to salvage the C-pillar, but ended up replacing it with with an Autocraft piece to give me the flexibility I needed to get the rear cargo door fit.
Everything clamped up and doors are finally getting close.
David S
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Fri Mar 17, 2017 6:46 pm    Post subject: Re: 1952 Deluxe Reply with quote
Wow.. that bus is going to look great. I'm looking forward to the updates on such a nice Samba.
Bill
My 1970 bus refresh thread- http://www.thesamba.com/vw/forum/viewtopic.php?t=598191
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
DSweinhagen
PostPosted: Fri Mar 17, 2017 6:50 pm    Post subject: Re: 1952 Deluxe Reply with quote
Thanks Paul!! Hope all is well..
David S
DSweinhagen
PostPosted: Fri Mar 17, 2017 7:25 pm    Post subject: Re: 1952 Deluxe Reply with quote
Repairing the corner, wheel well and battery tray while the quarter panel is off...
David S
DSweinhagen
PostPosted: Fri Mar 17, 2017 8:08 pm    Post subject: Re: 1952 Deluxe Reply with quote
Quarter panel is ready to weld on now...
I fabbed a wheel well brace. This bus had one on the right side, but not on the left...
Finished the repair on the B-pillar and more cargo door fitting with hardware installed.
David S
vwhelmot
vwhelmot is offline
PostPosted: Sat Mar 18, 2017 2:51 am    Post subject: Re: 1952 Deluxe Reply with quote
Nice work!
Dbk United Kingdom and Wales
http://www.thesamba.com/vw/forum/viewtopic.php?t=629294
Brian_Mccue
Brian_Mccue is offline
PostPosted: Sat Mar 18, 2017 4:12 am    Post subject: Re: 1952 Deluxe Reply with quote
My dream barndoor
(20-024785)Ambulance (20-037784)truck (20-035853)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Sat Mar 18, 2017 9:12 am    Post subject: Re: 1952 Deluxe Reply with quote
I remember this bus, I have some old pictures of it in a box somewhere. I think they were taken around 2000
https://instagram.com/mr_ogpaint
Patrick Hall
squareweave
squareweave is offline
PostPosted: Sat Mar 18, 2017 9:27 am    Post subject: Re: 1952 Deluxe Reply with quote
Beautiful work!! I'm looking forward to following this thread.
VWmeister
VWmeister is offline
PostPosted: Sat Mar 18, 2017 9:29 am    Post subject: Re: 1952 Deluxe Reply with quote
I bought this bus along with a 52 pickup in 1994. In the Barndoor Registry it is the 4th oldest 1952 24G. It was a good driver as witnessed the trek to the Jerome Jamboree.
I had an awesome time at Bad Camberg in 1999 with the Return to the Fatherland tour. I wanted to return in 2003 with a vehicle to hold 4 people and luggage. Hence taking the 52 bus.
Took it apart and 9/11 occurred. Plans changed. We got it media blasted and David replaced the front clip. Then it sat for years storing parts.
Decided about 2 years ago to go ahead but had to wait for David until he picked it up in January. Planning on full restoration so enjoy this thread as it progresses.
djfordmanjack
djfordmanjack is offline
PostPosted: Sat Mar 18, 2017 3:40 pm    Post subject: Re: 1952 Deluxe Reply with quote
teriffic workmanship, fabricating and buttwelding! nice DLX. Beautiful !
Hotrods, Fords, Veedubs and Triumph Twins ! ______Barndoor + Kohlruss Coachbuilt DLX afficionado
'51 Brezel project, Azurblau L36
'52 BD Coachbuild project
'54 Oval Sunroof project with my son, L275 Lichtbeige
'55 Wolfsburg panel project, Taubenblau L31 all original paint
'56 Oval, Polarsilber L324 og paint og chrome og everything
ian macdowall
ian macdowall is offline
PostPosted: Sun Mar 19, 2017 6:21 am    Post subject: Re: 1952 Deluxe Reply with quote
That's a nice early 52 in good shape, great work, looking forward to seeing the progress. Cool
'51 Beetle Deluxe
'52 Barndoor Deluxe
BulletBus
BulletBus is offline
PostPosted: Mon Mar 20, 2017 4:28 am    Post subject: Re: 1952 Deluxe Reply with quote
Two NOS cargo doors and an NOS quarter panel? Shocked Daaayum.
53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen.
vdouglu
vdouglu is offline
PostPosted: Mon Mar 20, 2017 11:07 pm    Post subject: Re: 1952 Deluxe Reply with quote
Awesome! Very Happy
Scotty
Scotty is offline
PostPosted: Tue Mar 21, 2017 6:18 am    Post subject: Re: 1952 Deluxe Reply with quote
Nice work!
aa390392
aa390392 is offline
PostPosted: Tue Mar 21, 2017 10:26 am    Post subject: Re: 1952 Deluxe Reply with quote
You are a craftsmen, very nice work.
Thanks for sharing.
Thomas
Is there a forum on on Returning to the fatherland? Bill Bowman has told me about it, would make a great story of all the stories of the journey.
1956 Oval Prairie Beige
1956 Oval Inca Red Kab.
Always looking for another something.
WTB Alpine motors /Ashville NC License plate frame
Page 1 of 9
