Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Wed Mar 02, 2016 3:04 am Post subject: AAZ IP Bosch Info, Anyone? |
So, the Bible covers what was put in the van over all the years it was made.
Now that I have an AAZ pushing it, I need to add a supplement to my -Bentley- Bosch : AAZ Injector Pump.
Does anyone have one of these? PDF?
Cheers!
Nico _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Last edited by Team WorldTour on Wed Mar 02, 2016 6:54 am; edited 1 time in total |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Wed Mar 02, 2016 6:38 am Post subject: Re: AAZ IP Bentley Section, Anyone? |
VW never released injection pump internal information to Bentley... You'd need to find it from Bosch. _________________ www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12102 Location: Port Manteau
Posted: Wed Mar 02, 2016 9:38 am Post subject: Re: AAZ IP Bosch Info, Anyone? |
The Bentley for the B4 Passat covers the AAZ, since it was an option in Canada, though I doubt it will be any more pump specific with the info than a manual for the JX types of engines. I would ask around over at the TDI club for mTDI info, which will probably be much closer to the details needed for your AAZ pump...though not 100% the same. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4062 Location: East Kootenay, British Columbia
Posted: Wed Mar 02, 2016 12:12 pm Post subject: Re: AAZ IP Bosch Info, Anyone? |
VWDiesel Forum:
http://vwdiesel.net/forum/index.php
IDI section for the older engines like the AAZ;
http://vwdiesel.net/forum/index.php/board,6.0.html
Look at the FAQs for links to Bosch guides. _________________ Currently:
Posted: Wed Mar 02, 2016 12:49 pm Post subject: Re: AAZ IP Bosch Info, Anyone? |
Oops, I forgot about that site...even though I've been a member there for lots longer than here. That's where you should go _________________ Casey--
y u rune klassik? |
