usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Zvonimir1985 Samba Member
Joined: August 19, 2015 Posts: 135 Location: Zagreb, Croatia
Posted: Fri Mar 11, 2016 8:03 am Post subject: Re: One more Zwitter bug 1953 |
Thanks but I can print it and be as happy as with the original +i have money in my wallet! _________________ Proud to be Croat! |
Posted: Mon Mar 14, 2016 9:45 am Post subject: Re: One more Zwitter bug 1953 |
Hey guys! Is there any difference between 52/3 ( the one I need )and 67 rear fenders? _________________ Proud to be Croat! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Mar 14, 2016 9:47 am Post subject: Re: One more Zwitter bug 1953 |
Zvonimir1985 wrote: |
Hey guys! Is there any difference between 52/3 ( the one I need )and 67 rear fenders? |
they will fit, but they are definitely different parts _________________ regards
Uli
Posted: Mon Mar 14, 2016 9:54 am Post subject: Re: One more Zwitter bug 1953 |
Ok, please show me the one I need and untill year they were produced. Some link to buy would be great! _________________ Proud to be Croat! |
Posted: Sun Mar 20, 2016 3:26 pm Post subject: Re: One more Zwitter bug 1953 |
Wow!
I have found the original tank cap in the car!
The beetle looks far more better then I tought!
One more question! All zwitters has the same speedometer? There must be two arrows separated or no?
Thanks!
And take a look at the original rear mirror!
And this is a newer one.
Posted: Mon Apr 04, 2016 1:34 am Post subject: Re: One more Zwitter bug 1953 |
Hello guys!
It is time to order a new back fenders and front and rear apron. Please, if anyone has ordered, let me know what is the best site. _________________ Proud to be Croat! |
joel55bug Samba Member
Posted: Tue Apr 05, 2016 2:32 pm Post subject: Re: One more Zwitter bug 1953 |
Hello guys!
It is time to order a new back fenders and front and rear apron. Please, if anyone has ordered, let me know what is the best site. |
On the aprons I'd check out Wolf1 on here and get the weatherstripping metal insert from virtanen also on here. For the fenders I'd try to find some good OG ones or wait for the next production run of the Gerson ones but as far as I know he's only making the fronts. |
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Tue Apr 05, 2016 2:55 pm Post subject: Re: One more Zwitter bug 1953 |
This car has a lot of character, good save!
I what condition are the floors/chassis ?
The most recommended way is to start from the chassis/floorpan and after to the body...
Either way good luck and keep the pictures coming |
Posted: Mon Jul 18, 2016 10:56 am Post subject: Re: One more Zwitter bug 1953 |
Hi guys! Nothing new with my beetle. But, I have sold one daily car so now the zwitter story can start soon.
I am still looking for rear end and I cant figure out what are the differences in years. Please, help me so I can order parts needed for restoration.
Thanks! _________________ Proud to be Croat! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Mon Jul 18, 2016 6:00 pm Post subject: Re: One more Zwitter bug 1953 |
Rear fenders: OK, I'll start with an overview of the differences using photos from the gallery. Those will help you judge how much you want to "improvise" or "make concessions" due to money and originality. I fully agree with the above statement that a 1967 rear fender will fit, and the overall contour will be a close match. You could redrill your current rear fenders for the mounting holes needed with the low "heart" tail lights, weld up the current holes as well as the round hole for the overrider tube, and most people would not notice the difference unless they look at the underside of the fender.
I'll make notes for "export" rear fenders which have the additional round hole above the vertical slot for the bumper bracket, which could be found in Europe.
1. Zwitter fenders: have "heart" tail lamps mounted down low using 4 holes in the fender. These 4 holes were used until mid-1955 when the revised, larger "snowflake" style tail lamps came out, which were positioned slightly higher.
They also have ribs between the bolt holes which were utilized through the end of the oval era (thru 1957 model year); possibly slightly later as well-
Here you can see the correct, low mounting position of the heart tail lamps which would be correct for your Zwitter. Note that the left fender has the round hole above the bumper bracket slot for a bumper overrider support tube, but the right fender does not-
2. mid-1955 thru 1957 fenders- "Snowflake" tail lamps mounted higher on Euro as well as US-spec Beetles. The photo below shows the round hole above the bumper bracket slot for an overrider-style bumper. This general style and tail lamp location was used through the 1961 model year. The only major difference would be when those ribs were discontinued.
3. 1962 thru 1967: Larger tail lamps mounted even higher, just like the ones you have now. Once again you have the round hole for an export bumper support bar.
25 years ago I bought a Oct. 1952-built Zwitter here in the USA which did have its original split rear window . Chassis # started with 1-041... It had one badly bent/ mangled rear fender, and the other one was OK and original. I was not interested in a restoration, but just to get the body into presentable condition because I installed the body onto a 1973 chassis with the semi-trailing arm rear suspension. I found a 1967 fender, transferred the dimensions of the heart tail lamps from the one original fender, and had a friend weld up the '67's tail lamp holes. Once I found a set of heart tail lamps, the rear of the car looked acceptable. I sold the car in 2003. |
Posted: Mon Nov 28, 2016 11:28 am Post subject: Re: One more Zwitter bug 1953 |
Rome, thank you! It is very helpfull!
Few days ago, I have bought 63 beetle and I will use it as a donor for this zwitter. I can use rear fenders, front hood and seats! What about mechanic and suspension? Brakes?
I cant find rear deck lid!
greek_tony Samba Member
Joined: February 12, 2013 Posts: 243 Location: Athens, Greece
Posted: Tue Nov 29, 2016 4:18 am Post subject: Re: One more Zwitter bug 1953 |
Front hood is different for sure - the arms that the hood is bolted to has 3 holes to attach to the 3 holes in the hood and other differences.
The seats won't fit properly. The seat rails in pre-55 cars are flat. Post-55 are angled up. This means that a post 55 seat will have the front end sloping down. _________________ 1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there. |
Posted: Tue Nov 29, 2016 4:46 am Post subject: Re: One more Zwitter bug 1953 |
Somebody dipped that whole donor thing in red primer and then left it at a scrap yard? _________________ Master of my domain! |
AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1070 Location: Massachusetts
Posted: Wed Nov 30, 2016 7:28 am Post subject: Re: One more Zwitter bug 1953 |
usariemen wrote: |
Somebody dipped that whole donor thing in red primer and then left it at a scrap yard? |
But they masked off the shifter!
That Zwitter is awesome! Why not leave the cool (and valuable) gauges and rally looking stuff there? Less holes to weld up! The seats will be tough, why are so many 53-55's missing their seats, mine is missing them also. |
beetlekey Samba Member
Posted: Wed Nov 30, 2016 12:00 pm Post subject: Re: One more Zwitter bug 1953 |
That is a 55 and younger body with a welded in splitroof, it is no switter....
If you need help with the interieur, no pproblem.
Marcus _________________ Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO |
Posted: Wed Nov 30, 2016 3:48 pm Post subject: Re: One more Zwitter bug 1953 |
? Try again!
Yes, I need interior and if you can help me, please do! _________________ Proud to be Croat! |
Posted: Sat Feb 04, 2017 5:50 pm Post subject: Re: One more Zwitter bug 1953 |
Hi guys!
Is this one right for my bug?
Rome Samba Member
Posted: Sat Feb 04, 2017 7:45 pm Post subject: Re: One more Zwitter bug 1953 |
I don't think so; that one appears to be for a later oval window. There are 2 quick differences; look at this one from the gallery:
1. Shape of the engine lid spring holder at the top inner edge- "yours" is made of two parallel channels. Split window or even early ovals have a triangular shape.
2. Shape of the license plate light cutout is very different.
"Your" engine lid with the "W" indentations would be much closer to being correct than the two you now have. If you can get it for a reasonable price, I'd suggest buying it. You could sell the two engine lids you have now to help with the purchase of the W lid. |
