djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
MaiTai Samba Member
Posted: Wed Nov 29, 2017 5:04 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Thanks tosimplify for the adapter 1/4 steel plate idea - solid and pretty straight forward. Making a template first is helpful. Plate is 17x17.
Kirsche Wasserboxer Samba Member
Joined: November 03, 2016 Posts: 104 Location: Seattle
Posted: Mon Dec 11, 2017 1:46 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
I joined the club and installed a set of these in my Westy this past weekend. I found a good deal on a pair of the grey cloth seats on eBay, and used the adapters from Small Car for the install. I cleaned up the swivel bases while I had the seats off, and had to install new bushings on the passenger swivel as well. So far, I like them, but have yet to do a longer drive with them in. My only complaint right now is that the increase in height has added to my limited view of the top of the speedo and tach. I'm 6'2", and already was missing some of the gauge tops, but it is now worse. I'll have to play around with the amount of recline on the seat back to see if I can get some improvement. I generally like to sit pretty upright, so I may have to get used to not seeing the tops of the gauges. I guess I could remove the swivel base on the driver's side as well, but wonder if that would make it hard to get these on/off with the small car adapters? I had both bases rotated to the doors when I installed them. _________________ 1990 Westfalia Vanagon
2.1 Wasserboxer |
aiwetir Samba Member
Joined: January 31, 2009 Posts: 37 Location: portland, or
Posted: Mon Dec 11, 2017 2:52 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
You could get a Scangauge |
Posted: Mon Dec 11, 2017 3:47 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
aiwetir wrote: |
That would also require an engine conversion, which is still down the road a bit for me, fingers crossed. _________________ 1990 Westfalia Vanagon
2.1 Wasserboxer |
Posted: Mon Dec 11, 2017 3:53 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Oh, right, lol, sorry, wasn't paying attention.
I've always wanted to hook a bike computer up as the speedometer |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Mon Dec 11, 2017 6:17 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Looks like something from Harry Potter or the Pink Floyd movie, "The Wall". _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
Jorda115 Samba Member
Joined: December 21, 2017 Posts: 1 Location: White Rock B.C. Canada
Posted: Thu Dec 21, 2017 6:29 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
SUCH A GREAT IDEA AND LOOKS GOOD TOO. THANKS FOR THE INPUT AND POSTING THIS IDEA. |
vwcrazyfamily Samba Member
Posted: Mon Jan 01, 2018 3:19 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Did the TC swap but reupholstered the seat to better match the van. I bought a set of cloth seats and found that there were some issues that would need to be over come in the reupholstering process. The material used to cover the TC seats are basically a very thin fabric sticker that is applies to the foam. This was an issue because one I had to very gently separate the foam and the fabric sticker without damaging the seat foam. Secondly there was no mechanical way to pull and anchor the pleats to get the couture of the seats to look and feel right. The foam is also very thin where the pleats need to be pulled through and anchored. When the new covers were made we put in very shallow fabric channels behind each pleat so that I could used welding rod and nylon string to pull the pleats down and anchor to the seat frame. I anchored each pleat three places using a combination of hog rings and the string in other places. Like I said the seats are not set up for any kind of mechanical anchoring so it was improvised to any point on the frame that would work. Over all it turned out very nice but just required a little work and imagination.
I have used the seat for about 1,000 miles and can say that they are very comfortable and a vast improvement over the OEM seats. I did keep the swivel bases and it does make the seating height higher and for me a little harder to exit the van because my leg is a little tight between the steering wheel and the new seat, minor tradeoff in my opinion. I am tall with short inseam and long torso so the critical part was headroom; there is about 38” from where your butt goes and the headliner. In my case the new TC seats seem to give more when I sit than the OEM seats, which helps with headroom. The drives side seat just barely has the room to fold down while facing forward, this make a nice place to store thing while camping.
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Mon Jan 01, 2018 5:00 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
aiwetir wrote: |
Back before I repaired my odometer I ran wiring so I could splice it into a bike computer (Cateye Micro, probably) harness, but the odometer repair rendered that unnecessary. The wiring is still in place, just in case. _________________ '87 Westy in Wolfram Grey Metallic |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
Posted: Tue Jan 02, 2018 6:02 am Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
I have an extra set of black perforated leather T&C seats that I was going to use as rear seats.
PM if you are interested. Pickup in Little Rock. Can't ship. _________________ Learn to ride. Ride to learn. |
HoneyVan84 Samba Member
Joined: December 04, 2017 Posts: 1 Location: Petaluma, CA
Posted: Wed Jan 10, 2018 11:52 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
fxr wrote: |
Did mine over the last couple of days. I was very happy with the ebay seller - the seats were very well protected and packaged, and arrived promptly.
My old, manky, non-OEM seats did have slides for the turntables, so I made some brackets from some 1/8" 1"x1" steel angle to marry them to the seats. I cut four 420mm lengths, drilled 8mm clearances holes - the VW slides are 387mm between centres, and the T&C seats are 240mm between centres - and chopped a bit more off each one to give clearance for odd tabs and things on the slides.
I had to straighten out the VW adjusting rod so it didn't foul the new seat. Total extra cost including a few hack-saw blades and some 8mm nuts and washers was less than $20, even buying the angle-iron from Ace (it's at the end of my road...).
Mrs fxr is very pleased, and *loves* the armrests. |
Thank you for your post! I put together exactly what you did today to get my seats in! So stoked! Thank you for the details |
dlb154 Samba Member
Joined: December 27, 2006 Posts: 359 Location: Reno, NV
Posted: Tue Jan 30, 2018 6:01 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
I'm considering the attachment as referenced above (originally posted by fxr, reposted by Honeyvan84) but want to use the Recaro slider kit that Go Westy sells rather than the stock slider rails and modified adjustment rod:
http://www.gowesty.com/product/retrofit-seats/21308/recaro-slider-kit?v=
Has anyone used the Recaro adapters? |
dlb154 Samba Member
Posted: Tue Jan 30, 2018 7:26 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Dave,
I think the set you got was a bit more straight forward. The Go Westy kit will require me to fab cross members to attach the seat to the GW Recaro slides.
I don't like the idea of bolting the seats to the swivel rails. It's my understanding the Small Car adapters bolt to the swivel rails and your forward/aft movement is only the range of the Stow-n-Go built in slide.
I like the Go Westy Recaro slides because they are actuated by a front-of-seat lever rather than the side seat option like stock. Might work out nice and allow for the additional slide range that the stock Stow-n-Go seats have built in.
Guess if the exchange rate improves, the set you got may be the better way to go... |
WLD*WSTY Samba Member
Joined: November 04, 2009 Posts: 438 Location: Arizona
Posted: Tue Jan 30, 2018 11:24 pm Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
dlb154 wrote: |
I'm considering the attachment as referenced above (originally posted by fxr, reposted by Honeyvan84) but want to use the Recaro slider kit that Go Westy sells rather than the stock slider rails |
I just bought two of those on Amazon, $64.72 the pair shipped. They're called "NRG Universal Seat Base Sliders SBR-001" _________________ '82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L |
dlb154 Samba Member
Posted: Wed Jan 31, 2018 12:28 am Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Thanks! Just ordered a pair. Total $80 for two sets shipped. Looks like the listing claims they are a pair but turns out it is a pair of sliders, good for one seat.
Hope you caught that and ordered two pair of slider sets. |
Twan Samba Member
Joined: July 31, 2015 Posts: 69 Location: Longmont, CO
Posted: Fri Feb 02, 2018 8:12 am Post subject: Re: Front Seat Swap, (Town & Country 2nd Row) |
Now, I can't speak for the actual install in a van, but I am writing this post from the middle row of a Grand Caravan, and I'm finding these seats to be rather comfortable. The only two things I can think of that aren't perfect for me is the armrests are a tad too low, and the seat bottom is too short to provide any actual thigh support for me. I think they're both a result of me being 6' tall and long in the torso, combined with the higher floor I'm this minivan. Overall, these feel way more comfortable than the blown out stock seats currently in my van, and hopefully they'll satisfy my gripes. |
