WithTheFlow Samba Member
Joined: March 04, 2016 Posts: 197 Location: Wisconsin
Posted: Fri Mar 04, 2016 8:40 am Post subject: My First Bus / 1970 / Non Walk Through / Bench Seats |
I just bought my first bus, a partially restored 1970 Bay Window from Green Bay Wisconsin. We drove her 125 miles to Wisconsin Dells to my farm. She ran great! When stopped at a red light she turned off and we couldn't get her started. With an orchestra of horns honking behind us, I ran out a started pushing her while my brother steered her to the gas station. I was surprised at how easy it was to push. We couldnt get her started, we used a jump, and then after a while the engine finally turned over and she ran. What a relief. We tried our best to not come to a complete stop again. (blowing stop signs, and inching through red lights) We got pulled over going 43 in a 25 (the speed limit changed all of a sudden and we were going downhill). Suprisingly she kept on running even as were stopped. We finally got her home ticket-free
Posted: Fri Mar 04, 2016 8:51 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Fri Mar 04, 2016 8:56 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Looks like a pretty solid start, congrats!
That engine needs some love. Replace your fuel lines now!!!! _________________ 1976 Westy
1966 Beetle |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Mar 04, 2016 8:58 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Welcome!
Nice bus you have there, lots of potential.
You'll want to read up on fuel line replacement, cooling tin seals and general engine cleanup. The dying at stops could be from overheating, tight valves, poor carb adjustment or the lack of a real aircleaner, likely a combination of many things. An engine cleanup and tune up would be first on my list assuming the brakes work well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
boundstaffpress Samba Member
Joined: June 18, 2013 Posts: 161 Location: Southeast Colorado
Posted: Fri Mar 04, 2016 9:18 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Looks like a great project. I'm kind of partial to the 8 and 9 passenger setups. _________________ Justin
Building a 73 Super Beetle with my kids. |
panic_fan Samba Member
Joined: April 21, 2008 Posts: 711 Location: Mcdonough GA
Posted: Fri Mar 04, 2016 10:33 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
busdaddy wrote: |
An engine cleanup and tune up would be first on my list assuming the brakes work well. |
The brakes work well. He put in a new master cylinder. I need to fix the parking break though. Right now we are just leaving it in gear when parked |
danfromsyr Samba Member
Posted: Fri Mar 04, 2016 11:50 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
you're blowing a large portion of your cooling air out into the compartment with the open heater air ducts
and w/o a engine seal to the body your sucking in alot of the already super heated air.
it's wallowing in it's own heated air.
you MUST remedy this ASAP before you are looking for a new motor too.
soo many new(old) vws die this new owner death. it's lost it's humor.
but congrats, it's a good start to a satisfying (at times) and money stealing (at times) hobby (obsession at times) _________________
Abscate wrote: |
Posted: Fri Mar 04, 2016 12:09 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
danfromsyr wrote: |
I am not driving at all until I get her up to par. I will fix that immediately. The photo is from the craigslist ad. We were going to fix it there but forgot the hose from excitement. Thank you for the heads up! |
Tcash Samba Member
wcfvw69 Samba Purist
Posted: Fri Mar 04, 2016 2:07 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
That's a solid bus from being in the North East. I'm seeing some of the common rust under the windshield rubber and in the lower panels but overall, not bad.. I like the color as well.
Lots of great information on this site, in this forum with nice folks to answer your questions.
After you get the mechanicals dialed in, you should consider attacking the rust issues before it get too bad. _________________ Contact me at [email protected]
The Samba member since 2004.
mlesniak Samba Member
Joined: April 08, 2015 Posts: 350 Location: Wisconsin
Posted: Fri Mar 04, 2016 2:32 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Also when "withtheflow" and I drove the bus back, on our first stop we noticed that the carb was leaking continuously at the bottom of the throttle lever. _________________ Rosita the 73' Tin-top |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Mar 04, 2016 3:16 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
the mods will most likely want you to keep all your questions regarding your bus in your new bus thread, unless it is posted to an existing thread. you will get more help if all your questions are in one place. (talking about your separate sliding door thread. lots of available info if you use the search)
Great looking bus, and amazing condition bench seats! |
Posted: Fri Mar 04, 2016 4:05 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
alman72 wrote: |
I posted the sliding door thread... Withtheflow is my brotha. i told him to make a more official thread so he can formally introduce himself and his first bus _________________ Rosita the 73' Tin-top |
Posted: Fri Mar 04, 2016 5:02 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
ah. from the pics I assumed same poster. that's what I get for only looking at the pretty pictures! |
Posted: Sun Mar 06, 2016 12:23 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I am going to be replacing the fuel lines first. No one seems to agree on which fuel lines to use. I was wondering if anyone had any success with these :
http://www.autohausaz.com/search/pn.aspx?sku=12855...RoC-kLw_wc |
Posted: Sun Mar 06, 2016 12:53 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I've completely lost faith in any braided hose, too many premature failures lately. I use the Goodyear fuel injection hose with the blue inner liner from my local FLAPS, the closest imperial size is 1/4 " but it easily squeezes down onto the fittings with good quality FI rated clamps (not the worm ones). Others claim to be happy with this stuff if you are bent on metric sized line https://www.belmetric.com/rhm5-flennor-multifuel-hose-5mm-p-3718.html?cPath=14_662 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Mar 06, 2016 1:18 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Yes I wasn,t sure if the 1.35mm difference was going to be too much. Thanks. I'll look around for the goodyear ones and continue my research! Much appreciated |
Colonel Mosby Samba Member
Joined: February 23, 2014 Posts: 253 Location: Warrenton, VA
Posted: Sun Mar 06, 2016 3:54 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Terrific bus. You can get this up and going with a little time and patience. Try and learn how to do as much of this yourself as you can. There are a lot of nice people on Samba to guide you along. One day down the road pop out your windshield and take care of the rust in that windshield frame area. |
Posted: Sun Mar 06, 2016 4:38 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I'm looking forward to doing the work myself and developing a relationship with the bus! My brother is helping me out too. I can use all the advice I can get ! |
