WithTheFlow Samba Member
Joined: March 04, 2016 Posts: 197 Location: Wisconsin
Posted: Sun Jan 07, 2018 5:03 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
busdaddy wrote: |
if you are confident there never was one there don't worry about it.
Nice work!, and your welds are getting better and better, practice makes perfect (and a few hours with the grinder inspires you to improve as well ) |
I did not see one when I cut it out. With all the repairs there is going to be a whole lot of strengthening done
I am going to school now for autobody and refinishing so I had a lot more practice and it also gave me the confidence to really dig in. I am working with a talented body man so the bus is in a shop with TOOLS. Makes a world of difference. _________________ The fastest thing you can do is slow down.
“The secret is here in the present. If you pay attention to the present, you can improve upon it. And, if you improve on the present, what comes later will also be better."
-- The Alchemist” |
BTRacing Samba Member
Joined: February 20, 2013 Posts: 8 Location: Chicagoland
Posted: Sun Jan 07, 2018 5:12 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Ha , I am 100% Polish. In Chicago since 2000. Have European car repair shop in Evanston
btr-chicago.com |
Posted: Mon Jan 08, 2018 10:06 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Started the cargo floor area by removing the top hat support and rear outriggers. Although a few of the floor supports need replacement, the gear shift guide tube will remain in because it's a great reference for fitting the new supports. Also cutting the supports at a diagonal gives much better access to then reweld them once they are fitted
The new support was then clamped to a scale, fitted and tacked.
-- The Alchemist” |
Posted: Mon Jan 08, 2018 10:15 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
-- The Alchemist” |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Wed Jan 10, 2018 8:48 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Worked on removing th second top hat support along with the jacking points. I was originally going to patch the crossmember in an area it rusted through but it turns out the inside is covered with surface rust. The PO filled the heater duct shut. I'm thinking that could be removed as well since I am doing a Subaru conversion. Perhaps it will free up space under there.
-- The Alchemist” |
Posted: Fri Feb 09, 2018 11:27 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Last of the floor supports, outriggers. cross members, and jacking points are in.
-- The Alchemist” |
Posted: Fri Feb 09, 2018 11:31 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
The jacking points from Wolfburgs west don't hold the inner sill up so well. It seems like they will need some adjusting. Im also a but confused with how the inner sill, middle sill, front jacking point, floor and b pillar all come together. _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Posted: Fri Feb 23, 2018 12:31 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
-- The Alchemist” |
Posted: Wed Jun 20, 2018 6:21 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Haven't posted in a while. Let me know if you're still following. Most of my progress gets posted on a local bus group in Wisconsin.
I wasn't happy with the jacking point from WW so I drilled out their welds and welded it back in right
welded jacking point to the outrigger
fitting inner sill
middle sill on drivers side
C pillar fabication
frame patch
Seat belt strengthener
Fit floors and marked my holes! Prepare for hours of drilling
I scuffed and epoxied the floors while there were out!!!
Burn them in
Time to move to the front
-- The Alchemist”
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jun 20, 2018 6:24 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
That floor looks slick! keep it coming. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Wed Jun 20, 2018 6:41 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Any tips on removing the handbrake lever pin under the floor? [/quote] _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jun 20, 2018 7:40 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I will try to avoid cutting but won’t waste my time if it’s stubborn. _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Wed Jun 20, 2018 9:28 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Keep it up... You're doing good work!
And thanks for sharing your progress, its fun to watch. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Posted: Tue Jun 26, 2018 8:38 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Removed the steering wheel and the the cab floor
So I have an original rust free dog leg with the a pillar and parts of the b-pillar still attached.
My bus needed work on the bottom of the pillars as well.
I’ve already fabricated parts of the inner b-pillar and want to use the curve in the original rust free price to fabricate the rest of what’s missing.
I’m thinking of trying to weld in the whole dog leg with the pillars attached and building from there. I already have it pretty close. If it fails I will have to drill out the spot welds and separate the pillars from the dog leg and weld in each piece separately but that is time consuming and a little more invasive.
Any thoughts?
-- The Alchemist” |
yoyorob Samba Member
Joined: June 16, 2014 Posts: 7 Location: Redondo Beach
Posted: Tue Jun 26, 2018 9:49 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
thanks for sharing! i’m just getting starting disassembling my 70 deluxe walkthru so I appreciate you documenting your progress.
where did your replacement cargo floor come from and how’d you like it? |
Posted: Wed Jun 27, 2018 4:50 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
If you weld it in whole like that, make sure you plan through how you will reach each point to weld. And what is your plan for rust prevention? Leaving the weld completely untouched on the back side will rust quickly. Just thoughts, I think they can likely be overcome. Good work so far. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Wed Jun 27, 2018 8:04 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Spike0180 wrote: |
If you weld it in whole like that, make sure you plan through how you will reach each point to weld. And what is your plan for rust prevention? Leaving the weld completely untouched on the back side will rust quickly. Just thoughts, I think they can likely be overcome. Good work so far. |
After hours and hours of staring at and measuring I cut it out in a way that I will be able to access each spot to weld it in. I’m going to spray everything in epoxy before it goes in and then clean off the area where I will weld.
When I’m done I’m thinking of drilling a hole in the top of the a pillar and b pillar and running a hose down that sprays epoxy 360 degrees _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Posted: Wed Jun 27, 2018 8:09 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
yoyorob wrote: |
The cargo floor is from Wolfsburg west. Out of all the things I got from them I was happiest with the floors. I made some cuts into it to help with fitting it. Pm me if you have any questions or photos. _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
