doc_holiday Samba Member
Joined: March 04, 2004 Posts: 8 Location: San Francisco
Posted: Thu Mar 04, 2004 8:18 pm Post subject: Gene Berg Shifter |
Zup?
I have a 1970 Bus and I am having some trouble with my Gene Berg shifter. I mailed it to Gene Berg Enterprises and they totally re-did everything. It is now "like" new.
My problem is that I can shifter in 3rd and 4th and reverse. No problem. But, I can't get into 1st and 2nd unless I press the reverse button.
Any ideas? Please help [/b][/color] _________________ Doc
orangeeyesore Samba Bammer
Joined: November 23, 2003 Posts: 1264 Location: looking in Hazetguy's windows
Posted: Thu Mar 04, 2004 8:24 pm Post subject: |
i'm having a hard time understanding your post. are there gears that you can"t get into? _________________ HBB
As it says, who have you got as a quote in your signature line and why? |
nik Samba Member
Joined: February 13, 2003 Posts: 849 Location: 1 block away
Posted: Fri Mar 05, 2004 3:43 am Post subject: |
I think he meant to say that he can't get into 1st and 2nd?
Have you replaced the shifter bushing?
Do you have the shifter lined up correctly? If it is off center I am sure that you will not be able to get into certain gears.
nik _________________ It ain't easy being cheesy
Analyze this, Biotch!
WTD: Early "Wrap Around" dash pad |
stevo Samba Member
Joined: January 22, 2004 Posts: 908 Location: the eugeniverse
Posted: Fri Mar 05, 2004 10:32 am Post subject: |
i recall reading on the gene berg site you must replace your shift rod bushings. of course make sure the shifter is lined up per bentley. and finally make sure the shift rod coupler is sound, especially the cage. on last inspection when it was difficult for me finding 1st and 2nd, i found the cage faulty. the round part in the rear loosens from the rectangular part. _________________ When you cross an Irishman, they never forget. I mean, never. |
Posted: Mon Mar 08, 2004 8:30 pm Post subject: |
nik wrote: |
nik |
[]Thanks Nik, I did replace the bushings, I did not line-up the shifter. I shall try that. Thanks. [/i][/b] _________________ Doc |
Posted: Mon Mar 08, 2004 8:46 pm Post subject: |
stevo wrote: |
i recall reading on the gene berg site you must replace your shift rod bushings. of course make sure the shifter is lined up per bentley. and finally make sure the shift rod coupler is sound, especially the cage. on last inspection when it was difficult for me finding 1st and 2nd, i found the cage faulty. the round part in the rear loosens from the rectangular part. |
]Thanks Stevo, I shall check the cage also. [/i][/b] _________________ Doc |
Tcash Samba Member
Posted: Fri Oct 14, 2016 8:22 pm Post subject: Re: GENE BERG SHIFTER |
Ran across this today.
Gene Berg Bus Shifters -10% Off Special
Quote catalog listing.
http://www.geneberg.com/product_info.php?products_id=1194
"GB 6750 66-79 bus shifter. Fits chassis number 216-028-112 to the Vanagon. Approx 1-1/2" from bottom of base to bottom of ball. Polised inset T handle as standard. Length approx 25" from floor to top of handle. SW#6 MSRP $351.85 Our Price+ $255.89 Cash Price $246.05"
"GB 6750R 66-79 bus shifter. Fits chassis number 216-028-112 to the Vanagon. For right hand drive buses. We have bent this shifter the opposite way and installed our right hand drive handle. Approx 1-1/2" from base to bottom of ball. Total length approx 25" from floor to top of handle. SW #6 MSRP $351.85 Our Price+ $255.89 Cash Price $246.05"
"Midnight Special. All black non-locking shifter, base, shaft and handle upgrade. For bus/quickshift add $5 for a black quickshift plate. Added to price of a shifter."
"Midnight Special add $20, or $25 for bus/quickshift for a black Q/S plate."
Hope it helps
Tcash |
Brian Samba Moderator
Posted: Fri Oct 14, 2016 9:32 pm Post subject: Re: GENE BERG SHIFTER |
Ditch the Berg shifter, get stock one.
Then once you get a stock one, adjust the shifter stop plate. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sat Oct 15, 2016 6:16 am Post subject: Re: GENE BERG SHIFTER |
Brian wrote: |
Then once you get a stock one, adjust the shifter stop plate. |
x2....
long story short, I am in the middle of a transmission re-re-rebuild because of a berg shifter. the punch line to the joke is the 2nd gear hub is so massive in a bus, and holds so much inertia that the short shift shifters obliterate the second gear synchros. I have had 4 vw transmission shops tell me this.
when I described my problem, the first words out of EVERY shop was "you're running a berg shifter, aren't you?"
so, if you want to shift it 1234 don't do a berg....you will have to shift it more like 1..................2.........................3........................4 to let the hubs slow down.
of the 3 transmissions I have gotten from one company, the only one with ANY issue was the one with a berg shifter. I would strongly suggest looking up the thread I did on restoring the stock shifter. if you have a proper not worn out stock unit, the shifting is simply amazing.
again, the only transmission that had an issue had a berg installed in it. from what I gather, this IS NOT as big of an issue on the bug transmissions seeing they have smaller hubs _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Heliconman Samba Member
Joined: August 08, 2008 Posts: 283 Location: Minnetonka, MN
Posted: Sat Oct 15, 2016 8:49 am Post subject: Re: Gene Berg Shifter |
Thanks Skills,
I had planned on ordering a berg. Ill stay away now. I'm sad to hear it though because they look really nice. |
Posted: Sat Oct 15, 2016 9:00 am Post subject: Re: Gene Berg Shifter |
they do....
and the 1-2 & 3-4 are like an inch apart....very, very close, just like anything else with a short shift kit.
if you plan on driving your bus like a dump truck, and delay your shifts you may be ok....
again, this is what I was told by very reputable builders. for all of them to have the same answer/reply was amazing. for our builder to warranty this was more than appreciated. huge shout out to benco racing. ben is by far the most honest and reasonable guy I have met....
shame on me for not looking into this. the trans in question had about 7-8K on it when the issue came to light _________________
Jake Raby wrote: |
Brian wrote: |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Sun Oct 16, 2016 9:12 am Post subject: Re: Gene Berg Shifter |
I`m not so sure about all this. I have used Berg shifters on several Bugs and early Buses but I`ve only owned one Baywindow. And it had a Berg shifter along with a new coupler, bushings and an extremely well built 002 trans. It never caused this problem and actually was not as tight as posted on here. I`ve known others with Berg shifters in Baywindows with no issues either. _________________ If you`re going to do something, do it right. |
GTV Samba Member
Posted: Sun Oct 16, 2016 9:13 am Post subject: Re: Gene Berg Shifter |
Bryan67 wrote: |
I`m not so sure about all this. I have used Berg shifters on several Bugs and early Buses but I`ve only owned one Baywindow. And it had a Berg shifter along with a new coupler, bushings and an extremely well built 002 trans. It never caused this problem and actually was not as tight as posted on here. I`ve known others with Berg shifters in Baywindows with no issues either. |
Agreed. _________________ EMPI Power Rules! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Oct 16, 2016 9:21 am Post subject: Re: Gene Berg Shifter |
Some shifter porn
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
wcfvw69 Samba Purist
Posted: Sun Oct 16, 2016 9:32 am Post subject: Re: Gene Berg Shifter |
I don't think VW aftermarket parts manufacturing companies get enough credit for their marketing practices. Even today, with so much utter (Chinese) garbage parts being sold for our classic VW's, some folks still gobble it up. Then these forums are littered daily with posts about how poorly their VW now runs, shifts, drives, etc.
Now, I'm not implying that Gene Berg products are garbage but rather, some in my opinion are not simply not needed or required. In many cases, these aftermarket parts are a significant reduction in quality over the original VW made parts.
After refreshing my buses shifter bushings, replacing the POS Chinese shifter plate for an NOS one and relubing the assembly, I was rewarded with a nice tight, crisp VW shifting experience as was designed by the factory. It cost me less than $30 to achieve this as well.
I want to point out that I'm really NOT knocking people's decisions to try to upgrade or improve their classic VW buying some of these parts. I'm only sharing my experiences (and others) in that I've learned most of these crappy aftermarket parts belong in the trash dumpster. There's a reason so many people are scrounging up the original parts and refurbishing them. They simply work that much better. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Oct 16, 2016 10:06 am Post subject: Re: Gene Berg Shifter |
just passing on what benco, wright, long, and rancho told me. early transmissions had a smaller hub...why do you think all the buggy guys want 091's?
whatever...just telling you what I have found. if you want to run the risk, that's on you. but having 4 transmission done and holding up well and one come unglued with the berg being the wild card...then asking around to different trans builders, I would say I did my due diligence.
do what you want...you're going to anyway _________________
Jake Raby wrote: |
Brian wrote: |
chabanais Samba Member
Posted: Sun Oct 16, 2016 11:00 am Post subject: Re: Gene Berg Shifter |
Thanks for the info on the short shifter. I didn't know that. Glad I stayed stock. I had been eyeing the Vintage Speed shifter. _________________ "I spud therefore I yam." |
Dogsled Samba Member
Joined: November 07, 2010 Posts: 62 Location: Denver, CO
Posted: Sun Oct 21, 2018 3:07 pm Post subject: Re: Gene Berg Shifter |
I've had a Berg shifter for a while now, all the shifter bushings have been updated, adjusted, etc. Shifter feels firm and solid but I am going back to stock. The big issue I have is the reverse lockout. Sometimes downshifting to second is balky, and I grind gears (reverse). Occasionally this happens when up shifting as well. I NEVER had this issue with a stock shifter. I have had misalignment issues and balky shifting until adjusted correctly, but never grinding reverse. I can tell this as I have a backup camera that triggers on reverse, and this comes on sometimes downshifting, and even sometimes starting in 1st. Tried alignment changes, no effect. Berg shifters use a button, instead of pressing down, and I think that is the problem. _________________ Don't make a fuss, just get on the bus... |
Posted: Sun Oct 21, 2018 3:31 pm Post subject: Re: Gene Berg Shifter |
I recently had a customer with a “rebuilt” transmission. The shop couldn’t get it to shift right and they told him he needed a berg shifter. They tried to install it but shifting still wasn’t good. That’s when I got involved.
The sad end of this story is that after fucking with the berg many many times I still couldn’t get shifting right. In frustration I went back to the stock shifter. Same problem. I fucked some more. No luck. Turns out that the tranny shop screwed the pooch and tried to blame it on needing a berg shifter. Lots of wasted time on my part.
I gave the bus back to the owner and told him to go back to the tranny shop for relief because it was their fault. Still don’t know the final result.
Observation: I love my Berg shifter in my personal bus. Everything better be in good shape when you install one though because it’s not a fix for poor shifting. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1882 Location: N.W. Georgia
Posted: Mon Oct 22, 2018 5:24 am Post subject: Re: Gene Berg Shifter |
I have had my Gene Berg shifter in two early bays with 3 rib boxes with no problems. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
