ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sat Mar 05, 2016 8:33 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
Lots of camping chair threads like this one: http://www.thesamba.com/vw/forum/viewtopic.php?t=592806
Can we please stay on topic? It really helps those searching threads in the future.
Thanks. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Sat Mar 05, 2016 8:42 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
ThankYouJerry wrote: |
^^^ That looks cool. I like the size and the domed roof like the SB. More details? Size? How's it attached to the van? Etc? |
3 small ratchet style plastic wood clamps
Clamp to the rails and put away the 2 other poles away
I think it's 10x10 _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Posted: Sat Mar 05, 2016 8:45 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
Pretty sweet. Looked bigger than the SB's 10'x6'. Got a brand name or P/N? _________________ 1990 Multivan - "Ohana"
chase4food Samba Member
Joined: February 27, 2016 Posts: 636 Location: PNW im Amerika
Posted: Sat Mar 05, 2016 8:58 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
Wow! I just don't see how one can or should refrain from replying to a remark someone made about something they see in a photo of your van. I can see if the discussions continue incessently and lead the thread to stray way off topic. _________________ - Vince 飲食玩睡
what Isolde wants Isolde doesn't always get, 4 I know what is best for her - Liebe macht frei |
Posted: Sat Mar 05, 2016 9:19 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
^^^ Just politely suggesting we keep the thread on topic before there are 3 pages about everyones' favorite camping chairs in an "awning thread". Happens a lot. _________________ 1990 Multivan - "Ohana"
kamzcab86 Samba Moderator
Posted: Sat Mar 05, 2016 9:31 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
http://www.thesamba.com/vw/forum/viewtopic.php?t=526589 _________________ ~Kamz
2016 Golf GTI S
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Mar 06, 2016 11:23 am Post subject: Re: shady boy out of fashion? the light weight awning that is |
chase4food wrote: |
For me it is the light weight, and relatively resistance to breeze - a safety and property damage concern.
The breeze they have there will make a Fiamma dangerous to be left deployed. |
The more light-weight a fabric is, the more susceptible it is to flapping in the wind, same goes for a heavier fabric with little tension on it. Both the Shady Boy and a Fiamma-style awning will flap around in wind. Awnings with parallel, side rafter arms (Trans-Awn, EZ-Awn, ARB) can have inexpensive deflappers added to cut down on flapping even more:
I've had my Trans-Awn deployed in pretty good wind over the years. Staking the poles to the ground (I rarely use the body brackets now), adding guy-lines and deflappers keeps the awning quite stable. It is obviously heavier than a Shady Boy, but I removed the tension springs out of the roller, which shaved off quite a bit of weight.
The Fiamma45 has a deflapper kit, but it costs nearly as much as the dang awning!
I can see the benefit of the Shady Boy, but for the money, I'd take an ARB in a heartbeat. _________________ ~Kamz
2016 Golf GTI S
Posted: Sun Mar 06, 2016 12:54 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
kamzcab86 wrote: |
The more light-weight a fabric is, the more susceptible it is to flapping in the wind, same goes for a heavier fabric with little tension on it. Both the Shady Boy and a Fiamma-style awning will flap around in wind. Awnings with parallel, side rafter arms (Trans-Awn, EZ-Awn, ARB) can have inexpensive deflappers added to cut down on flapping even more... |
The relative unique attribute of Shady Boy is it is structurally built like a sail. The fiberglass battens keeps the 10x6 fabric tensioned like a drum, and structurally like a sail.
While it comes with two lightweight vertical poles it is not to support the outer end from sagging. It is to resist gusts from compressing the awning downwards.
In the photo, you can see I opted not to install the vertical poles in the situation but only to use the two guy-lines. Without the guy-lines the deployed awning stills skywards from horizon about 35-degree from the support of the fiberglass battens.
The beauty and hence the attribute that justify the high price tag is relative resistance to wind. It never flaps in the breeze. The designer chose not to make the awning bigger is his cognizant to the force of breeze can exert onto the horizontal "sail".
The awning withstand very well to heavy downpours and pool very little water that the weight do not compromise the awning. You can always shorten the guy-lines to completely eliminate the pooling of water which takes just seconds. _________________ - Vince 飲食玩睡
Posted: Sun Mar 06, 2016 1:11 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
Here are some more photos:
deployed with vertical support
the 5 battens
the snap connector at the outer corners for the vertical pole
without guy-lines - actually more like 15 degrees up from horizon
the Shady is less suited to the Sprinter due to the much higher height of the Sprinter than Vanagon. _________________ - Vince 飲食玩睡
Posted: Sun Mar 06, 2016 1:26 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
chase4food wrote: |
The relative unique attribute of Shady Boy is it is structurally built like a sail. The fiberglass battens keeps the 10x6 fabric tensioned like a drum, and structurally like a sail. |
More like a kite, IMHO. I've seen the SB in person, and even sat under one in a rain storm (which was replaced about a year later with a larger case-style). Not an awning I'd install on my van, but to each their own. If you prefer the SB, great. I prefer my Trans-Awn, which does shed water, does resist wind when lashed down, and can be fully enclosed, if desired.
Bottom line: Lots of awnings on the market to choose from and all have their pros and cons and varying degrees of pricing. Do your research and choose one that will work best for you and your van. _________________ ~Kamz
2016 Golf GTI S
Posted: Sun Mar 06, 2016 1:40 pm Post subject: Re: shady boy out of fashion? the light weight awning that is |
kamzcab86 wrote: |
chase4food wrote: |
Bottom line: Lots of awnings on the market to choose from and all have their pros and cons and varying degrees of pricing. Do your research and choose one that will work best for you and your van. |
I am not here to sell the SB to anyone. Just want to see how other owners' experience. I said from the first post it is not an awning for everyone. There is no such thing as the best awning. I chose SB for it's safety in breeze, light weight, and minimalistic appearance. I had Fiamma on my James Cook and even with a custom-made room for it. I have never use either once during camping. I want an awning mainly for brief shelter from the onslaught of summer sun, and I camp very frequently at high wind locales. If you are into wind power sport you would know the what a few mph of breeze can exert on a 60 sq ft sail/kite/wing. Sail, kite, and wing are basically the same. They are all wings in the very definition of aerodynamics, but designed to be used in different orientations (most of the time). _________________ - Vince 飲食玩睡
Posted: Sun Mar 06, 2016 2:13 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
I must honestly say that I never heard of the Shady Boy awning before you posted this thread.
At first I had great interest in it, compact, light weight and easy to deploy.
I then stumbled upon the price. I came upon some videos of setting it up and it soon became apparent to me that this awning is little more than a Sun shade.
If you dwell in an area where the rain does not fall and the horrid Sun is always upon your head until you cry out for the cruel comfort of death! (Makes me think of the prophet Jonah fighting with God and God causes his shade providing tree to wither and die) This awning is probably wonderful!
Windy arid settings...... Hmmmmm........ No place that I am EVER voluntarily heading! Been there..... Done that.
No one is knocking the awning as a viable option, it is just clear to myself and others who have posted that the awning is not a product that will meet our needs. For me I want an easy to deploy, affordable, effective shade AND an effective rain barrier in one product.
I honestly thought it was the EZ Awning ..... but that turned out to be not quite so EZ
This thread actually helped me decide to purchase an ARB..... Ironic I know!
We all like different things and we LOVE to tell others about our loves..... There is no attacking of the post or the product here, just honest expression of opinions. Please take them as such.
Ghia
Vanagon
Beetle
Posted: Sun Mar 06, 2016 2:22 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
djkeev wrote: |
Dave |
Diversity is good. Our needs and decisions are all unique to what we value. Every design or decision often requires tradeoff. Contrarian views sometimes risk being like "a nail that sticks out needs to be pounded down" in old Japanese culture that value conformity. _________________ - Vince 飲食玩睡
Posted: Sun Mar 06, 2016 3:01 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
NICE... my awning has tripled in value _________________ Don't harsh my mellow...
1967 Bug- Gone
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sun Mar 06, 2016 3:24 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
I've had my Shady Boy on my westy weekender I think for about 15 years now. It's still as good as new and for what I wanted, it's repaid me in kind. I also like the lightweight, compact design, and personally don't need a side house when camping. I've used it extensively all over the west.
However, when I bought one the cost was about half what it is now. If I were in the market for an awning today I'd have to more carefully consider the options. I've never like the looks of the bigger jobs taking up the whole gutter on one side but that's just me and cosmetics. Functionally and financially I might lean toward the ARB today to compliment my ARB fridge/freezer
But if I had deeper pockets ..... |
Posted: Sun Mar 06, 2016 3:46 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
WestyBob wrote: |
I bought mine circa 2003 for may be around $280. It would be $370 today's price adjusted for inflation.
Just one interesting point, a nominally equipped 1989 Westaflia Vanagon GL sale price (not list) adjusted for inflation would cost about $46k and the Syncro option would cost about $50k. To me they represent incredible values. _________________ - Vince 飲食玩睡
Posted: Sun Mar 06, 2016 10:03 pm Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
I forgot another BIG plus for the Shady Boy for my needs...
The SB awning case doesn't get in the way when I'm strapping my SUP boards on top of my van. I'm only 6'0" and I can't imagine fighting another 4-6" when climbing on my rear passenger tire trying to tie my boards to the rear bar. Put the boards on the driver side??? Nope. That's reserved for my Thule box and RMW ladder. _________________ 1990 Multivan - "Ohana"
Busdepot Samba Member
Posted: Mon Mar 07, 2016 4:47 am Post subject: Re: Shady Boy out of fashion? (light-weight awning, that is) |
Quote: |
I have a BusDepot Ezy Awning which I've set up only once just to try it...We felt that it is so cumbersome to set up that we never bothered and haven't had significant rain to warrant the effort. |
That's because you only tried once. Anyone who uses it often will tell you that the learning curve is steep. The first few times take a while because you're still learning the process, but once you've done it a few times it gets a whole lot faster and easier. Ten minutes from bag to vehicle once you're used to it (a bit longer if you want to put up side walls/screens as well and enclose it). _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
