Body Changes.... How is my 91 different from your 80?
Page: Previous  1, 2, 3  Next
fxr
fxr is offline
PostPosted: Mon Mar 14, 2016 1:58 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
SCM wrote:
Does anyone else NOT have an "OXS" indicator light on their instrument cluster? My 91 Westy doesn't have it.
A PO glued a penny over where mine might be - so I assume I do have one, but I can't see it...
Jim Crowther
Vespa GTS 300
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Mar 14, 2016 2:26 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
My '89 doesn't have the Ox light
Casey--
Seven VW vans from T1 through T4 since 1985
Volkswagens powered by Volkswagen
Respect the marque
djkeev
djkeev is offline
PostPosted: Mon Mar 14, 2016 3:36 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
D Clymer wrote:
Three production changes that quickly come to mind:
1. Rear license plate/oil filler flap handle changed from curled style to grab handle. (1983 or 1984)
2. Rear decklid push-button and surrounding sheetmetal revised. (1984)
3. Chrome front bumper gained embossed ridge along back edge. Used to be flat like the rear.
I'll add pictures when I have a chance. Fun thread!
D
So .... The front bumper embossed ridge...... As in this photo on my 86?
Who has photos of the earlier bumper?
Who knows when they changed?
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Mon Mar 14, 2016 3:41 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
D
The license plate door.....
Here is my 86......
Anyone have photos of the older style?
When did they change?
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Wed Mar 23, 2016 4:32 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Sliding door change....
When exactly did it take place?
For all of 85 or early in the 85 year run?
And exactly what are the differences?
Dave
Ghia
Vanagon
Beetle
kalispell365
kalispell365 is offline
PostPosted: Wed Mar 23, 2016 4:47 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
1980 had a very nice metal hoop to pull and release the spare tire, 81 and on had the plastic pull hoop and sometime later the whole latch assembly went to all plastic.
The fridge also changed to an auto reignitor setup in 1990.
1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
Yellow Rabbit
Yellow Rabbit is offline
PostPosted: Wed Mar 23, 2016 8:21 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
My 85 has the late sliding door and the late license plate flap.
1985 Westfalia GL
D Clymer
D Clymer is offline
PostPosted: Wed Mar 23, 2016 9:36 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Dave
Hi Dave,
As far as I know, all 1985 model year vans have the updated sliding door. It can be spotted by the shorter handle and deeper, but smaller handle recess.
The entire track assembly is different on the newer system and it eliminated the nylon guide bushings used on the early door.
The window aperture on the later sliding door is also slightly shorter.
Dave
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Fri Apr 01, 2016 6:15 am    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
My '87 has this stamp 10/86
'87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '65 Split Deluxe 'Henry', '63 Notch
djkeev
djkeev is offline
PostPosted: Sun Apr 03, 2016 11:46 am    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Adjustable front seat arm rests..... What year?
Up to and through 86 is a No.
87????
88 and up seems like a Yes?
Dave
Ghia
Vanagon
Beetle
D Clymer
D Clymer is offline
PostPosted: Sun Apr 03, 2016 2:06 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
87????
Dave
The adjustable armrests were introduced for MY 1987.
D
bikelash
bikelash is offline
PostPosted: Sun Apr 03, 2016 8:29 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Arm rest and rear window vents on my 88.
Ace
64 baja sold
72 sb wrecked
69 baja sold
69 std sold
72 sb sold
54 std sold
74 sb-ongoing
88 westy-ongoing
PostPosted: Sun Apr 03, 2016 10:06 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Well, yes, the title says '87, and the 10/86 seems to confirm. Front seats are both adjustable arms. Although, the driver door has the electric mirror adjuster, which does not work, and I can't find Fuse #25. Looks to me a lot like the driver side took a full front to rear swipe. It is entirely possible that the driver door was replaced with another perhaps newer one. Also, I'd guess the PO upgraded the seats if they weren't standard for that year. That old Duffer really did some amazing stuff, from all the things I have found thus far. The only thing I truly detest was to cut off the closet door.... I think the door that could swing open over the table was a year or so later? Hence, the PO was aware of that from somewhere, and doing 'upgrades' as he could. Too bad about the cabinet frame. The door is not good, but the frame, sheesh, come on!!!
djkeev
djkeev is offline
PostPosted: Mon Apr 04, 2016 3:59 am    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
The closet door length is a new item to me.
What year did Westfalia change the design and does anyone have photos of the design change?
Dave
Ghia
Vanagon
Beetle
OddN
OddN is offline
PostPosted: Mon Apr 04, 2016 5:01 am    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Dave
Actually, it was more of a model change.
All Joker/Club Joker models have the tall door. And all California/Atlantic have the shorter door.
California first appeared in late 88, and the Atlantic in early 89. But there were some overlap Joker production after that (up to 90 I believe)
Club Joker door:
California door:
1991 VW Multivan syncro 1,9 TD
Gruppe B
Gruppe B is offline
PostPosted: Wed Apr 13, 2016 5:00 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
My 1991 Carat has factory painted sound deadening on the rear engine deck and behind the rear seat while my 1980 aircooled and 1985 Westy are just painted metal.
My 1982 Diesel however has the same sound deadening treatment....
tjet
tjet is offline
PostPosted: Wed Apr 13, 2016 5:33 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Dave
Hi Dave,
Dave
Dave(s), regarding the sliding door changes, was there a change in window size?
boat_builder
boat_builder is offline
PostPosted: Fri Apr 15, 2016 4:17 pm    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Someone asked about date stamps...There are date stamps on the front of the wheel rims that show the month and year of manufacture... my spare is from 1977![/b]
My 1984 Rusty Vanagon Restoration Thread
jimf909 Premium Member
jimf909 is offline
PostPosted: Sat Apr 16, 2016 7:57 am    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
Dave
When I was shopping for a Westy camper I saw an '87 with the long door (shortened as in the photo above) and bought a '90 with a short door. My '85 had the long door.
I find the short door to be much more convenient due to the easier access to the closet.
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
kamzcab86
kamzcab86 is offline
PostPosted: Sat Apr 16, 2016 9:10 am    Post subject: Re: Body Changes.... How is my 91 different from your 80? Reply with quote
All Westfalia full-campers shipped to North America had the short closet door beginning with the 1989 model year (no such thing as Joker and California here). That door is one of the reasons I limited my search to '89-'91.
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
Page 2 of 3
