1Rockhead Samba Member
Posted: Mon Mar 14, 2016 4:02 pm Post subject: 67 square socal |
New to vw. Plan on making this square a decent cruiser over the next couple years. I have no idea what I am doing so I hope I don't ask to many stupid questions:) just wanted to say hello.
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Mon Mar 14, 2016 4:54 pm Post subject: Re: 67 square socal |
Nice square! The FAQ section will be your best friend, but there's a lot of people who are always willing to help.
Martin
allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Mar 14, 2016 5:15 pm Post subject: Re: 67 square socal |
Nice!
Yes, read all you can, and then ask specific questions. And don't get in too big of a hurry.
Also, don't throw anything away! _________________ 71 Elm Green FI A/T Squareback |
Posted: Thu May 12, 2016 10:48 am Post subject: Re: 67 square socal |
The more I dig, the more there is going to be to do. I am in no rush though. Got the front down 2 clicks. Think this is perfect for me.
dirtslinger Samba Member
Joined: January 20, 2009 Posts: 392 Location: South Bay, So Cal
Posted: Thu May 12, 2016 12:57 pm Post subject: Re: 67 square socal |
That's the one that was up Phelan for sale a while ago right?
Looks pretty good. _________________ 1967 Class 5
1970 Class 11 HSD Racing
1972 5/1600 V-MAR/Rasta Baja
1956 Baja
1960 Sand Rover buggy
1965 Street bug
1967 Squareback |
Posted: Thu May 12, 2016 2:36 pm Post subject: Re: 67 square socal |
I bought it in Hesperia. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Thu May 12, 2016 11:17 pm Post subject: Re: 67 square socal |
1Rockhead wrote: |
Just make sure you check and reset the toe in before you do too much driving. It changes (usually goes out) when lowering. BTDT. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jun 25, 2017 4:06 pm Post subject: Re: 67 square socal |
About to pull the body off to get ready for pan resto. Was wondering if it is fine to pull the body off with a rusted our rocker? Do I need to fix that first for rigidity of the shell?
Was also wondering about painting under the rear qtr's. There is a bit of surface rust and a couple pin holes on the passenger air intake. What is the best way to address that as far as rust prevention. Can't really get in there to sand and paint.
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Mon Jun 26, 2017 8:46 am Post subject: Re: 67 square socal |
Will you be pulling the doors off as well? Maybe brace it up inside the door frame.
As for the rear quarter, you could remove the outer panel to get in there and do what you need to. Drill the spot welds out, work in there and weld the panel back in. Look forward to reading up on your build. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Jun 26, 2017 9:08 am Post subject: Re: 67 square socal |
I would leave the doors on it for an alignment check, while welding on the heater channel. You could use a wire wheel on the inner fender rust and then brush on silver and/or black www.MasterSeriesct.com on pans/inner fenders/chassis etc. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Jun 27, 2017 10:33 am Post subject: Re: 67 square socal |
Brace the door openings, but do so about 8 to 10 inches above the rocker, so you'll have room to work on them. I'd probably do like Monte suggested on the rear air boxes. It will be easier to work that area that way. You might want to look into getting a "spot blaster", and working a little at a time with it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Feb 25, 2018 7:28 am Post subject: Re: 67 square socal |
Found a clean complete pan from a 71. Is it better to use the complete pan and have to change the title, or just weld the 71 pan sections to my 67 tunnel? |
Posted: Sun Feb 25, 2018 10:36 am Post subject: Re: 67 square socal |
1Rockhead wrote: |
I've welded pan sections in both my old 71 Notch, and my 64 T-34, back when Russ owned it before I got it. If you have the body off, then doing pan halfs is easier, especially when using used pans (they fit better than the Gerson pans). What you do is cut the donors as close to the tunnel as you can, and cut your old rusty pans on the edge of the 1/2 inch lip. This allows you to set the new pans in place, and gives you something to weld to.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
jeremydoc Samba Member
Joined: March 14, 2013 Posts: 113 Location: Gardena, CA
Posted: Tue Feb 27, 2018 9:50 pm Post subject: Re: 67 square socal |
Hey man, what art of SoCal are you in? I also am building a 67. |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Wed Feb 28, 2018 10:46 am Post subject: Re: 67 square socal |
Hesperia. |
Posted: Wed Feb 28, 2018 10:51 am Post subject: Re: 67 square socal |
1Rockhead wrote: |
I should have added above, that I wouldn't do a pan swap and re-title. I only say that as California might require you to do some sort of emissions testing for the re-title (wouldn't surprise me), and it makes the car no longer "numbers matching". _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
