Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Mon Mar 14, 2016 4:52 pm Post subject: Will a 12 Volt Flywheel fit on a 1300? |
First off this is not a comprehensive 12 volt conversion question!!!
I've got a complete engine that starts with F0XXXXX and I've got a spare 12 volt flywheel assembly laying around and wanted to put it in a spare buggy that just needs a power plant. the 40 horse stuff wont fit together without machining, but I couldn't really figure out whether or not the 1966 1300 crank would accept the later style flywheel.
Anyone with thoughts on this?
Thanks
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Mon Mar 14, 2016 6:01 pm Post subject: Re: will a 12 Volt Flywheel fit on a 1300? |
You may want to confirm the 1300 crank and flywheel is o-ring sealed or has a step and gasket. But it should fit... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24732 Location: Olympia Wash Rinse & Repeat
Posted: Mon Mar 14, 2016 6:42 pm Post subject: Re: will a 12 Volt Flywheel fit on a 1300? |
As long as it is not a 20, 25, or 36 HP engine it will fit if you get the correct parts. O ring or non-O ring FW and crank is the main hurdle. _________________ In Stereo, Where Available! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26306 Location: Douglas, WY
Posted: Mon Mar 14, 2016 9:44 pm Post subject: Re: will a 12 Volt Flywheel fit on a 1300? |
FYI: The change from step to O-ring style crank/flywheel, if this engine somehow still retains its original crankshaft, came at engine number F0741385.
_________________ Andy T.
Posted: Tue Mar 15, 2016 6:25 am Post subject: Re: will a 12 Volt Flywheel fit on a 1300? |
glutamodo wrote: |
Thanks for the replies guys, unfortunatly this engine is a vw excange program engine so all bets are off, but when I remove the 6 volt flywheel, how do I tell the stepped vs non stepped apart? something about a length difference? I read about a difference in lip/length or something of the sort...I'm more of a visual person, does anyone have a side by side comparison or the ability to set one beside the other and take a picture for me?
Thanks,
1959 beetle
1962 Karmann Ghia
Posted: Tue Mar 15, 2016 6:40 am Post subject: Re: will a 12 Volt Flywheel fit on a 1300? |
From a search of the gallery for "Crankshaft End":
Quote: |
6V vs. 12V Crankshafts
hazetguy
On the left is a crankshaft that uses a stepped, 6V flywheel.
On the right is a crankshaft that uses an o-ring type 12V flywheel.
Notice the different depths that are machined on the ends of the crankshaft. |
Posted: Tue Mar 15, 2016 12:02 pm Post subject: Re: will a 12 Volt Flywheel fit on a 1300? |
Eric&Barb wrote: |
hazetguy
Thanks! Lol the right key phrases make all of the difference. low that I know what to look for, it Looks like its time to breakout the torque buddy
1959 beetle
1962 Karmann Ghia
