modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Mon Mar 21, 2016 2:18 am Post subject: oil relief plunger clearance= headache |
I'm building a type-4. God have mercy on my soul.
Type-1 stuff, generally the bore is .630"(16mm) and the plunger .629"
So I pick up the oil relief plunger and measure it. ummm, wtf.
Not only is it tapered, it's also NOT round.
The top is .627, middle .629, bottom .631-.633
possibly, somebody jammed something in the bottom of this poor plunger and expanded the bottom outward.
But now what? it's been in there going up and down like that for who knows how long. I tried to measure the bore and I was getting around .633 right before I got the snap guage stuck in there because it's so darn deep the handle is too short to work properly. And I broke the snap gauge getting it back out.
So then I decide..... lets make a extra big plunger. It came out lovely. .6305 is as large as I dared make it, for fear of hanging up on a less worn area of the bore. Still feels awfully loose in the block tho when I tried it. It has at least .003 clearance just be feel.
What should I do?
Should I run it with the .0015" oversize plunger I made?
or do I need to buy a reamer to oversize the bore and make another plunger to fit?
I haven't done enough type-4 engine to know if this is normal or awful |
raymon covey Samba Member
Posted: Mon Mar 21, 2016 7:00 am Post subject: Re: oil relief plunger clearance= headache |
This might be a good time to try a ball check valve. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Mar 21, 2016 7:56 am Post subject: Re: oil relief plunger clearance= headache |
raymon covey wrote: |
Had one in a type 1 case, didn't particularly like it as there was no documentation (easy to find) on how to set it up (mine came with used motor) .... Think it would be last resort...
mark tucker Samba Member
Posted: Mon Mar 21, 2016 8:48 am Post subject: Re: oil relief plunger clearance= headache |
how about bore the case for the next size up and make one that fits. just run the next size reamer and make a piston, polish it good befopr usage, make it a tad longer for better support, and no sharp edges at all.simple fix. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Mon Mar 21, 2016 10:01 am Post subject: Re: oil relief plunger clearance= headache |
modok wrote: |
What should I do?
The plunger is not designed for a tight fit when its factory new. Along with the side groove in the case....the tolerance around the piston is part of the bypass design....as long as the oil pump system is operating normally.
I have two pristine type 4 cases on my work bench. When I get back home this evening if you can wait...I will measure both bores and both pistons so you can get an idea of what tolerance they should be.
Then you can use Mark tucker's suggestion and make an oversized one with the right tolerance. Don't get crazy on oversizing though. The more you oversize....the shallower the bypass groove in the case gets and the larger diameter the piston gets...which increases the square area that oil pressure operates against. Ray |
Posted: Mon Mar 21, 2016 6:22 pm Post subject: Re: oil relief plunger clearance= headache |
logic thinking says very little clrearance as the case will expand more than the piston.....but it needs to move freely when the motor is cold so...I would shoot for about half a thou to .001". and unless you get realy big I dont think a few thou will change squat in blow off pressure. or.....just add one of those adjustable thingys to the springy thingy so you can have some cake and drip on it too. with that said....Ive never tuched a type 4 so.....I havent a clue what Im talking about...... |
modok Samba Member
Posted: Mon Mar 21, 2016 9:59 pm Post subject: Re: oil relief plunger clearance= headache |
I have a good condition WBX hoarded so I got that out to examine, should be similar design.
the bore is .630 and the plunger is.....627"
nice and wobblyloose. And the plunger has a groove for no reason. I'm pretty sure this thing is 100% OEM, and virtually no wear
SO, I believe, the type-4 wore out it's bore about .002-.003, THEN the hippies turned the plunger into a dunce hat.
My oversize plunger does restore the fit to "almost new"....maybe
I'll wait to see what Ray comes up with.
For MARK:
Why did it need to be so loose? It's odd. I don't agree with it. In the late 70's type-4 they reverted back to the one plunger doing both jobs, with a big hole drilled though the bore so the piston has very little bearing area and can jam easier. I think it's a stupid design, they knew it was, and they didn't care. Poor thing got no love from the beginning.
It's not good enough to me, but if I can say it's "good as new" then it may be good enough for this job. |
Posted: Tue Mar 22, 2016 8:54 am Post subject: Re: oil relief plunger clearance= headache |
modok wrote: |
For MARK:
OK....some bits and pieces. Both of the cases I have out...I am second owner of, know the history and the condition is excellent.
Both of my pistons measure .627...one actually is about .6275" but I only I had my .001" mic handy.
The bore on both is .630"
So...you piston...somebody jammed something into and "ballooned" it from the sound of it. If it was stuck....a stupid person might take a steel rod....whack it up in there with a hammer ...to pull it out...which will balloon the skirt.
The tolerance from my little black book of measurements from lots of engines I have built and owned...notes that .627" and .630" are nominal and normal.
The piston is supposed to have a groove in it from the factory. It works differently than a type 1.
Bear in mind....this is NOT the same oiling system as a type 1. Its not a dual relief case. The second valve near the fuel pump boss is not really a pressure relief. Its a pressure maintainer....it has a cast in restriction and the plunger acts more like keeping your thumb over the end of a hose to maintain steady pressure. This is partly because this system is also bleeding off to/feeding an oil filter.
Also if you take a small flashlight and measure and look inside of the bore of the type 4 relief system....you will note that the piston total movement from the seat at the end of the bore is roughly 1/2" max.
The amount of downward movement of the piston before the top edge groove...which is bottom edge of the piston head...crosses the top lip of the vent hole for the oil to go to the case....is a little less than .250". So there is always some oil bleeding around the piston...into the groove.... when the oil is fully warmed.
The maximum the piston has to move for the top face of the piston to cross the top lip of the oil relief port is a little less than .375". The relief port is about 10mm diameter.......so what the groove does is allow oil to flow around the top edge of the piston as it drops under pressure so that oil flows through the groove and across the piston top at the same time.
This makes the piston more sensitive to actual medium pressures so its not so crude of an adjustment.
Leave the grooved piston in there.
I heated the piston in boiling water while I made coffee this morning. At a little over 200....it grew by a hair over .001".
The bore will grow by about .002"-.003" when heated. ...so tolerance is about .004" to .005" maximum between bore and piston when warmed up. This is normal...and part of what the groove carries away.
Ray |
Posted: Tue Mar 22, 2016 9:07 am Post subject: Re: oil relief plunger clearance= headache |
I would go with a max of .001~.0015 clearance ....thats if you have a good filteration system on it. and oh so smooth, possiably even heat treet it so no abrasives can scratch it..
on another note..isant the same size as type1?
on another note I had a motor brought to me after a few hundrad miles that was blowed up...not by the owner but the northwestcoast moron joe that built it. the pistons liikked they were shot with steel ratshot. what a bitch to get out. it was a neer new new case that the "builder" effed over real good,(hammer and chizzell stroker clearancing).
You may e able to get a + size 5/8 or 16 mm to slightly over size the bore, they make a adjustable one with a allen head in the end to expand it a tad too.
or possiabl;y this is just a 20-50 motor.......hmm might be a 50 weight. |
Posted: Tue Mar 22, 2016 10:29 am Post subject: Re: oil relief plunger clearance= headache |
mark tucker wrote: |
That is too little clearance on the oil relief piston.
The type 4 already has an overabundance of oil pressure. What would be the purpose of tightening up the tolerances....except to change the efficiency of the piston....which changes how it operates and reacts to pressure.
There is nothing wrong with the type 4 oil pressure relief system. Don't screw with it. Ray |
modok Samba Member
Posted: Tue Mar 22, 2016 5:25 pm Post subject: Re: oil relief plunger clearance= headache |
Thanks Ray, that matches exactly what I found.
the "why does it have a groove?" was directed to the WBX, the WBX has no oil cooler so the groove does nothing, but they used the exact same plunger anyway. I guess......why not.
I have measured OE appearing plungers to vary from .627 to .629
Today I learned...., like a lot of things, they got looser in the 70's |
Posted: Tue Mar 22, 2016 7:55 pm Post subject: Re: oil relief plunger clearance= headache |
modok wrote: |
I think they got looser....as oils got better and VW learned from how vehicles were performing in the field.
The problem I was getting at with making the piston too tight......is that with the really high cold weather oil pressure that these things generate......if thr piston does not have some oil blowing past it....it can push down to far....vent quick....pop back up and it will oscillate. I can both wear faster and cause up and down oil pressures. Ray |
modok Samba Member
Posted: Tue Mar 22, 2016 8:17 pm Post subject: Re: oil relief plunger clearance= headache |
The late hippie bus does, in fact, have the loosest plunger orifice of any engine I've ever examined.
You may not be aware of this, because you aren't a specialist in this field.
As long as you feel satisfied in your relationship, it's ok, I don't think it's contagious or transferable. |
Posted: Wed Mar 23, 2016 7:37 am Post subject: Re: oil relief plunger clearance= headache |
modok wrote: |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Sun Mar 27, 2016 5:20 pm Post subject: Re: oil relief plunger clearance= headache |
It can be a common practice to use a big straight-slot screwdriver to remove the plunger.
I'll admit to doing it..
If the plunger is sticking in place from surface tension, or just wants to stay in place for some reason,
I stick a screwdriver up there that's just the right size to wedge, and grab it, and pull it out.
Surely I'm not he only one..
Now,
That said, I'm careful about it, and would never jam it up in there hard enough to oval it out,
But,
Bet you some ham-fisted types might do just that..
And,
Come on,
Admit you done it al least once...
Add checking for an ovaled-out plunger to my list of inspection measurements! _________________ Bus Motor Build
What’s That Noise?!? |
modok Samba Member
Posted: Sun Mar 27, 2016 5:29 pm Post subject: Re: oil relief plunger clearance= headache |
Nope, never done it. I use a valve guide.
Round plug fits in round hole, square plug fits in square hole.
Didn't you have that kids toy? |
Posted: Sun Mar 27, 2016 6:45 pm Post subject: Re: oil relief plunger clearance= headache |
modok wrote: |
Sure. ....but I screwd it up by using the metal hammer instead of the plastic one. Pretty soon.....all the holes are round-ish.
Ray |
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Sun Mar 27, 2016 7:04 pm Post subject: Re: oil relief plunger clearance= headache |
You could use an external relief and not the internal one. I plug the small relief hole in the block and eliminate the plunger and spring. I also use a relief cover for the oil pump.
Install it after the remote oil filter and cooler. It ends up just a few inches away from the stock relief. It's much easier than dealing with worn out relief bores. It is easy to adjust the pressure and you don't get the usual drop of pressure with hot oil with the stock system.
You can use a 1/16 NPT plug for plugging off the relief hole.
http://www.jegs.com/i/JEGS+Performance+Products/555/110400/10002/-1
_________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
modok Samba Member
Posted: Sun Mar 27, 2016 8:11 pm Post subject: Re: oil relief plunger clearance= headache |
If I ever build a type-4 for myself I'll consider that an option!
Plunger is the least of my problems now, now I have to figure out why the oil pump drive isn't inline with the cam. |
Posted: Sun Mar 27, 2016 8:28 pm Post subject: Re: oil relief plunger clearance= headache |
modok wrote: |
What pump are you using?
Ray |
