Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Mon Mar 21, 2016 8:23 pm Post subject: Gear Shift Rod Wear? |
I'm getting ready to paint my gear shift rod, and I had a questions about some wear that I noticed.
Is the wear below the ball on the left and right sides of the flat plate (not sure of technical term, I checked Bentley, but couldn't seem to figure it out) normal?
One side is longer than the other, does that affect the function?
Should I replace the gear shift rod?
If it should be replaced, where can I buy one besides used on this site? Does anyone produce a reproduction of the shift rod? Anyone have a suggestion for which one to buy?
Thanks
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Mar 21, 2016 8:35 pm Post subject: Re: Gear Shift Rod Wear? |
That ring looks worn down. That is what keeps you from shifting into reverse. Push down on the shifter, that ring drops below the "ramp" on the shifter plate and you grab reverse. With that much wear I bet it feels pretty sloppy. Welder up and you should be good to go. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Clara Samba Member
Posted: Mon Mar 21, 2016 8:58 pm Post subject: Re: Gear Shift Rod Wear? |
That is a really nice picture!
I call that the skirt, it should be a circle, but it has two flat areas worn on it. This totally happens, but yours is extremely worn. I bet you could put it in reverse w/o pressing down, and you might accidentally find reverse when you wanted 2nd.
Weld it up, and grind it into a nice circle, and you're good to go.
Make sure you put grease in the ball and socket joint.
Make sure you put grease in the ball and socket joint. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12400 Location: Over 2002 posts deleted!
Posted: Tue Mar 22, 2016 6:56 am Post subject: Re: Gear Shift Rod Wear? |
glideking wrote: |
Put shift lever on your swap meet shopping list.
Kurt |
X2! If you lived in a forsaken island, Cuba comes to mind, a resourceful fellow would have already welded and ground it to shape or just plain made one from scratch! But you are Kalifohnia already. Replace it and be done with it! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Tue Mar 22, 2016 10:09 pm Post subject: Re: Gear Shift Rod Wear? |
Thanks everyone for the information.
Below is a picture of the parts I have. There may be one part to the right of the actual shifter, that is not suppose to be in the mix...I can't remember and Bentley doesn't show it....Any ideas what that is, or what it may have been used for? It was in the bag with all the parts I pulled off the day I removed the shifter. I can't seem to find the pictures I took right now that show the removal process, so I'm perplexed about that part and where it might go.
My bus is an April 1966 production, is it one of the years where things changed a bit? The pin fits into the ball and the hole through the ball seems to have a spring inserted into one half of the hole. Is that normal? From the parts shown, does it appear that something has been sheared off?
Providing I have all the parts, I may give it a go at welding up the skirt as suggested by Clara. Or, if things are missing, or things are sheared off, I may hunt one out at a swap, or by a reproduction. It appears that CIP1 has a shifter kit, but I'm assuming the original stuff is better than what they have available.
Thanks for the help and information. I'm a total novice, and at times when I delve into Bentley, I become more confused. Also, if my best route is to seek one out at a swap meet, I want to make sure I'm looking for the right one for my bus.
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Wed Mar 23, 2016 5:59 am Post subject: Re: Gear Shift Rod Wear? |
The pin goes through the hole in the shifter ball. I've never removed a pin, but I know it shouldn't be a loose fit. I've welded up shifters with the same wear without any problems. If you get another shifter, be aware that 66-67 look the same as earlier bent shifters but are not. They are longer from the pivot point to the ball. Take some good measurements or the old one with you to the swap meet. Here's some good info with pics from the split bus FAQs:
http://www.thesamba.com/vw/forum/viewtopic.php?t=190619 _________________ Tim |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14216 Location: Casa de Oro, California
Posted: Wed Mar 23, 2016 9:30 am Post subject: Re: Gear Shift Rod Wear? |
You are missing the nylon bushing that the little pin goes into on the front of your rod: part 19 here: http://oacdp.org/5867part/359.png You have the latest style rod that pivots in front. That little pin should be attached under your bus on a little hanger. |
Posted: Sat Mar 26, 2016 9:20 am Post subject: Re: Gear Shift Rod Wear? |
Thank you everyone for the information.
I looked on the classified ads and couldn't seem to locate a gear shift rod for my year. I'm going to place a wanted post up, and hope someone has one.
Is it possible to weld in the pin that goes through the ball? Mine slides in and out very easily, and from what you mentioned, it should not move that easily right?
I don't remember seeing any bearing or small steel ball when I disassembled it, nor was it in my pictures. I wonder if it is long gone before I got the bus.
Also, thank you for the diagram, I will order up that bushing piece.
Thanks for info about different size rods.
Worst case scenario I have to buy a reproduction, any suggestions? I checked WW, and they don't seem to have the actual rod for a bus. I think I found it on CP1, but I'm guessing it is a cheaply made overseas part.
Any additional help and information is appreciated. |
Clara Samba Member
Posted: Sat Mar 26, 2016 9:34 am Post subject: Re: Gear Shift Rod Wear? |
The front shift rod under the bus is reproed, but not the stick in the cab, AFAIK
Most used ones have some wear. Yours is extra worn, but they all have some. Generally ads do not show this part clearly.
You can push the pin back in and peen it over, I've heard. I've installed a stick where the pin will slide out, and once in the ball and socket joint it isn't going anywhere even if it slides out when off the bus. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Wed Mar 30, 2016 5:44 pm Post subject: Re: Gear Shift Rod Wear? |
Clara wrote: |
You can push the pin back in and peen it over, I've heard. I've installed a stick where the pin will slide out, and once in the ball and socket joint it isn't going anywhere even if it slides out when off the bus. |
Thanks for the info, it's good to know that it can work even with the pin able to slide in and out. Ideally, I would like it to be the way it was originally, and I'm not sure I can peen it back.
Anyone have rod that doesn't have a loose pin laying around? I'm ok with the wear on the skirt because I can weld that up and grind it.
I did find a few places that sell a kit that I believe has the rod I need. Can I assume they are all the same part from China? Anyone pick one of these up, how is the quality?
http://www.texasaircooled.com/catalog/Gear-Shifter-Kit-Bus-Camper-66-74.html
http://www.busdepot.com/211798121e
http://vwparts.aircooled.net/Shifter-Repair-Kit-1966-1-2-1974-1-2-Type-2-p/211-798-121e.htm
https://www.airheadparts.com/vintage-vw-parts/shifter-parts/gear-shifter-kit-211798121-e |
Posted: Tue Apr 12, 2016 8:00 am Post subject: Re: Gear Shift Rod Wear? |
Anyone have any experience with one of these reproductions? |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10192 Location: Petaluma, CA
Posted: Tue Apr 12, 2016 8:30 am Post subject: Re: Gear Shift Rod Wear? |
glideking wrote: |
The large dish shaped washer is for your brake pedal return spring. That loose pin does not belong in the mix. The shaft with two holes is for your parking brake cables. Time for you to visit again. Original VW shifter for your year are a dime a dozen. Yours has too many problems. I may have some around somewhere.
Kurt |
That's not the brake pedal cup - actually, I think his bus being a '66? doesn't use that part at all. That piece looks like it's the top cup for the swing lever kit to me.
When you hunt for a shifter, make sure you find the '66-'67 version which matches the one you have. |
Posted: Tue Apr 12, 2016 12:56 pm Post subject: Re: Gear Shift Rod Wear? |
campingbox wrote: |
glideking wrote: |
Kurt |
I feel like such an idiot...When you mentioned the top cup for the swing lever, what exactly is that part and where does it go?
Thank you for the help. |
Posted: Tue Apr 26, 2016 2:29 pm Post subject: Re: Gear Shift Rod Wear? |
I have a 1966, and I think I have finally found an original gear shifter that will work.
My pin fits in loosely...When I look inside the hole in the ball, I can see what appears to be like a spring. However, there is no spring on the outside. I'm thinking it was sheared off at some point.
Did the shifter on a 1966 originally have a spring around the pin like the one in the photo below?
Spitty
Posted: Wed Apr 27, 2016 7:52 am Post subject: Re: Gear Shift Rod Wear? |
Anyone have any info on the above stated questions?
Thanks for the help.
Spitty |
BarryL Samba Member
Posted: Wed Apr 27, 2016 8:26 am Post subject: Re: Gear Shift Rod Wear? |
'66 should have the pin and spring. Put your pin in and see if the mushroom end has a smidge of pressure outward on it. That is all part of the anti-chatter and more direct feel of the lever going into the rod. The pin keeps the lever from spinning around and enhances your wrist and arm motion into helping push the ball into side motion. |
Posted: Wed Apr 27, 2016 9:24 am Post subject: Re: Gear Shift Rod Wear? |
BarryL wrote: |
So, the picture I posted with the spring is what it should look like? I have already confirmed that it is the proper length. I know you mention a spring is needed, I just want to confirm, as the one in the picture is the one I'm looking to buy off a member.
Thanks,
Spitty |
BarryL Samba Member
Posted: Wed Apr 27, 2016 6:50 pm Post subject: Re: Gear Shift Rod Wear? |
If the rod is the correct length from the mushroom to the end of the ball then that is correct. The pin and spring are correct. Grease it all, of course. |
