ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Wed Mar 23, 2016 12:13 am Post subject: Ice box, cooler, repair options? |
I tried searching but I didn't find much.
What options do I have to repair my cooler? I need to fix or replace the top plastic and possibly the rubber seal.
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Wed Mar 23, 2016 7:31 am Post subject: Re: Ice box, cooler, repair options? |
A little epoxy and sanding and you could maybe get that plastic in pretty good shape. The seal looks like it might be fine if you just glue it back in place.
Also you could watch the classifieds. Not much there now, but something might pop up. Don't forget to search in the bus sections for "parting" and "parts". _________________ 1976 Westy
1966 Beetle |
Posted: Wed Mar 23, 2016 8:52 am Post subject: Re: Ice box, cooler, repair options? |
Bala wrote: |
Also you could watch the classifieds. Not much there now, but something might pop up. Don't forget to search in the bus sections for "parting" and "parts". |
Thanks. It's there a particular type of epoxy that you recommend?
I wonder if anyone has tried to vacuum form their own replacement part? How does this piece attach to the top? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Bala Samba Member
Posted: Wed Mar 23, 2016 9:24 am Post subject: Re: Ice box, cooler, repair options? |
I think it's glued to the top.
I would use a 2 part "5 minute" clear epoxy that is sand-able and paint-able. Then touch it up with a small brush and some model paint that is a close match. _________________ 1976 Westy
1966 Beetle |
