spikes64bug Samba Member
Joined: February 22, 2015 Posts: 22 Location: United States
Posted: Thu Mar 24, 2016 5:14 pm Post subject: I have good spark, fuel, and compression; Still will not start. |
This my 1835 build. This car was running a 1641 prior to the installation of the new motor.
The problem is I have fuel, spark, and compression. It will not fire. All components are new. Battery, harness, coil, Dizzy, etc. The engine is new, never been fired. I assembled it myself and this in not my first rodeo.
I read the posts found this one particularly helpful:
http://www.thesamba.com/vw/forum/viewtopic.php?t=556143
Still will not fire.
Anyone have any ideas or tests that can be preformed that are out of the norm. I'm pretty sure I have tried all the normal tests.
Any advise would be helpful.
Thanks
Marc
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Mar 24, 2016 5:16 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Only thing left is timing and firing order. |
Posted: Thu Mar 24, 2016 5:28 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Timing is set static at 10, I have also tried 0 and 30. Will not start.
I verified TDC at the pulley and head #1 valves are closed. Wires are new and are verified at a 1432 orientation. Still will not fire.
I have built a few engines before, I know sometimes they can be stubborn. This one is something I have never encountered before, something is fishy... |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Thu Mar 24, 2016 5:32 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Make sure wires from ignition switch and distributor are connected correctly to the coil, as it's easy to forget when you r&r engines.
ALSO, make sure that if you have any automatic chokes, to connect them to coil correctly, as will leave you with a very weak spark. Don't think I saw them on your engine, but I could be wrong.
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
modok Samba Member
Posted: Thu Mar 24, 2016 5:33 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Do you know how to find TDC overlap?
When #1 is at firing TDC, #3 will be at overlap, both valves slightly open about the same amount. So what I'd be doing is turn the engine over and get the #3 valves rocking at overlap, then look at the pulley and see if it's at 0 degrees, or the empi logo, or at 90...could be off! never trust anything |
srfndoc Samba Member
Posted: Thu Mar 24, 2016 5:34 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
No points gap? _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Thu Mar 24, 2016 6:47 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
modok. I looked at the overlap on #3, it does not exist. I also noticed that using the same logic, the #2 exhaust should be rocking at TDC it is not. Knowing this is key. Now in theory all I have to do is find the engine position that reflects what I want to see happening. i.e Valves on #1 closed, #2 exhaust rocking, with overlap on #3. Then mark that position on the pulley as TDC and set the Dizzy, the timing and double check valve clearance. Thanks for the tip. I will let you know how it turns out. |
modok Samba Member
Posted: Thu Mar 24, 2016 6:51 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
I think you do not have the cylinder numbers right in your mind. They are marked on the tin just outside the spark plugs.
#1 TDC, #3 will be rocking.......or some thing is wrong |
Posted: Thu Mar 24, 2016 7:11 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
modok. #'s 1 and 3 are at the rear and 2 and 4 are towards the front.
I watched this video I found in another post with similar issues. This guy in the video does not go in to overlap on #3 but he does address #2 exhaust should be rocking at TDC. Mine is not. Nor do I have any play or overlap on #3 at TDC. So something is definitely off.
https://www.youtube.com/watch?v=ulQmKU2weyI |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Thu Mar 24, 2016 7:26 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
pop your diet cap off and take a pic of the rotor position at TDC on pulley.
i'm thinking your plug wires are off or your dist drive gear is in wrong.
If they check out, spray some starting fluid down the carbs. if you have spark and correct firing order, it will atlas start up for a sec or 2.
Also, when you open the throttles, do your access tubes squirt fuel? |
modok Samba Member
Posted: Thu Mar 24, 2016 7:48 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
spikes64bug wrote: |
Actually the opposite, but that's pretty close. |
Posted: Thu Mar 24, 2016 9:25 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
1 and 3 at the rear 2 and 4 in the front.. Of the motor, I was not talking about the the whole car, sorry my focus is solely on the engine at this point.. |
modok Samba Member
Posted: Thu Mar 24, 2016 9:32 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Ok
the back WOULd be the front if it was a Matador. |
Posted: Thu Mar 24, 2016 9:42 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
modok wrote: |
Ok
Correct.
Thank you for the overlap idea. I am going to look in to it this weekend. I will take some pics along the way and post.
I suspect that I have the darn gear in there 180 off, and then built the rest of the motor around that mistake. |
modok Samba Member
Posted: Thu Mar 24, 2016 11:05 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
If the cam gear was 180 off, it would still be timed right, ironically.
But yes if it was timed wrong it sure would be confusing. |
Dale M. Samba Member
Posted: Fri Mar 25, 2016 7:25 am Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Just for clarity...
During assembly (lay up) in case...
Posted: Fri Mar 25, 2016 12:47 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
modok wrote: |
Ok: Here it is lined up at TDC for # 3. #3 is closed and gaped at .006
#4 is closed with slack on the rockers. #'s 1 and 2 are in transition.
And: Here it is lined up at TDC for #1. # 1 is closed and gapped at .006.
#2 is closed with slack on the rockers. #'s 3 and 4 are in transition.
Does that sound right to you ? |
Posted: Fri Mar 25, 2016 1:11 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
modok wrote: |
Ok this is more what I am used to seeing at TDC; # 1 is closed, #2 Int closed. Exhaust transitioning neither open or closed. #3 is rocking, #4 Int transitioning neither open or closed. Exhaust is closed. Take a look where my rotor and pulley wound up.
Derek Cobb Annoying
Posted: Fri Mar 25, 2016 1:26 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Is that green wire on the positive or negative post on the coil? |
Posted: Fri Mar 25, 2016 1:29 pm Post subject: Re: I have good spark, fuel, and compression; Still will not start. |
Derek Cobb wrote: |
Its on the #1 or negative side. |
