ldj1002 Samba Member
Posted: Sun Mar 27, 2016 9:06 am Post subject: Another reason for clutch chatter??? |
I have clutch chatter and after reading about possible reasons I found bowden tube is OK. Then went under car to check engine and trannie mounts. I noticed one of the lower engine to bell housing nuts is off and the other side the stud is gone. All that is holding engine are to top bolts. Would this cause clutch chatter?
Can I screw a bolt in from outside into where the stud goes?
update, never mind screwing the bolt in where the stud went. I stuck a nail in there and the stud is broke off. Could only get nail 1 3/4" in hole. So I guess out comes the engine. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sun Mar 27, 2016 10:22 am Post subject: Re: Another reason for clutch chatter??? |
yes it can...had a former employee do that once...three will work so check the uppers and tighten the remaining lower....if it still chatters you have more problems....a bolt long enough to thread into the block will hit the side cover on the trans....you might be able to sneak one in if the trans is a 73 and up single sidecover model and the missing bolt is on the side without the cover...of course the stud could be broken off in the block |
Posted: Sun Mar 27, 2016 10:33 am Post subject: Re: Another reason for clutch chatter??? |
volksworld wrote: |
OK, so put a nut on the remaining stud just to check if chatter stops. If it stops then that is the problem. Would it be ok to leave it with the one stud broke or remove engine and fix. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
Posted: Sun Mar 27, 2016 10:51 am Post subject: Re: Another reason for clutch chatter??? |
For peace of mind I remove engine and inspect all of the stuff associated with clutch chatter. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sun Mar 27, 2016 4:53 pm Post subject: Re: Another reason for clutch chatter??? |
I found a nut that fit the stud, put it on and tightened it. Guess want? No clutch chatter, it is as smooth as can be. I am going to pull engine to replace the broke off stud.
I have read and read about clutch chatter and not 1 time was loose engine to bell housing mentioned as a cause. Maybe this post will help someone in the future.
Thanks everyone.
Leo |
Cusser Samba Member
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sun Mar 27, 2016 6:23 pm Post subject: Re: Another reason for clutch chatter??? |
It must have chattered every time you got on and off the accelerator too...you need to get under the car once in awhile,stick your eyes...and a wrench on bolts and nuts... |
Posted: Sun Mar 27, 2016 8:52 pm Post subject: Re: Another reason for clutch chatter??? |
johnnypan wrote: |
No, only taking off in 1st and reverse |
