MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Tue May 29, 2018 2:55 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
A quick follow up on this. Took the Syncro on a fairly long drive around the valley today and tried out the fresh air system in different modes.
The a/c definitely works better with the Vanistan vent closed and without warm air entering the cab. I could leave the a/c fan on 1 and use the front fan on 1 or 2 and it stayed nice and cool.
At freeway speeds closing the Vanistan vent made the van a bit quieter.
With the vent open and just regular fresh air flow I really couldn't notice a difference from before installation. I was worried a little that the reduction of flow would be noticeable.
Great product, nice job Chris. _________________ Currently:
Zeitgeist 13 Samba Member
Posted: Tue May 29, 2018 3:52 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Solid feedback. I'm sold. Just need to save the ducats and prepare my justification spiel. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
tencentlife Samba Member
Posted: Thu Jun 07, 2018 1:16 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
MsTaboo wrote: |
Great product, nice job Chris. |
Thanks so much for the compliment and for taking the time to write up your installation, MsTaboo, I'm really glad you are enjoying the kit.
Yeah the pest screen is kind of an add-on to the kit, I've never been able to work up something very slick there. That odd-shaped scoop is just really hard to fit anything to, and steel mesh is an awkward material to handle. The screen isn't necessary to use the kit at all, but better to have something there than nothing. It's in two pieces to allow the kit to be shipped in a medium flat-rate box, the longer boxes cost more to ship and are much more prone to being damaged. And a single piece is actually harder to install. The really best approach is what you did, re-use the existing screen panel but use additional materials to close the big gaps and make it actually fit the opening. In that case you could leave my screens out entirely. But that takes some futzing with so it doesn't interfere with the control cable, and that might be a bit much for some users. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Wed Oct 03, 2018 12:57 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
With cold weather on the way now's the time to install a Vanistan Cabin Air Control kit to keep that chilly air out.
From today thru Mon. midnight the Cabin Air Control kit will be discounted $20, price is now $175 plus shipping. Within the US this kit ships USPS flat rate at $17.05, for a total of $192.05.
https://intrepidoverland.com/shop/cabin-air-control/
This is the posted price as of now and until midnight on Mon. Oct. 8.
Review this thread to learn more about the kit, or post your questions here.
Follow the link to place your orders in the Vanistan shop at IntrepidOverland. Credit cards and Paypal accepted. I ship USPS worldwide. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2320 Location: Adobe Jungle USA
Posted: Tue Oct 09, 2018 8:01 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Chris from Intrepid Overland came out of his inventor’s lair and installed the latest version of his fresh air intake flap, some pictures to show what’s involved. The tunnel into the air box doesn’t lend itself to photography, some pictures I adjusted the brightness to improve visibility inside.
Thanks to the molded metal the ends of the tunnel are blocked off with foamy inserts:
Holding the flap in the open position before attachment:
Note the rubber foam glued to the inside of the metal plate.
The flap in position to screw down (or up as the case may be):
Chris demonstrating the control mechanism. Did I mention this is the 4ᵀᴴ revision of this upgrade?
The Vanistan Syncro bringing up the rear, this here is a work vehicle:
The flap control and one side of the bug/rodent screen installed:
Note that the wire screen allows more air than the stock thick perforated plastic screen, so it should move as much air as the original when the flap is open.
A gravity operated recirculation flap installed into a hole cut in the air box:
Chris demonstrated this to me and it works on all three fan speeds!
Haven’t driven in cold weather but a comfort report may be forthcoming. With a little in-town driving I was able to verify that almost all outside air is off with the flap closed. This will be nice in dusty and smoky New Mexico weather. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit
Posted: Tue Oct 09, 2018 10:18 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Hey Gnarlodious, thanks for the write-up. I really enjoyed visiting while we installed the kit.
Just for the record, it's the inlet door supports that are on their 4th version, the first was never marketed, this last one with the foam inserts does the best job of sealing off the inlet scoop and is cheaper to make. The bellcrank mechanism you showed has had one major revision, mostly to require fewer steps.
It's that way in manufacturing, always trying to make things:
work better
cost less
easier to produce
easier to install.
If I hit all four it's like a super hat trick! _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Tue Oct 09, 2018 11:44 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Cool pics. I'm looking forward to acquiring one of these kits. _________________ Casey--
y u rune klassik? |
jlrftype7 Samba Member
Posted: Wed Oct 10, 2018 6:44 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Durn, somehow I missed the notice about the sale, Bought one today anyway since I wanted one of these from reading about them here on the Samba a good month ago.
I need to pull my whole dash out anyway to redo foam flap pieces, probably replace the Heater Core while I'm in there and lube the Blower motor while I'm at it. So I might as well add this kit to the list at the same time.
If I didn't have all of that to look forward to, this would be a simple job with a Dash in place/not removed... It looks well thought out and revised as needed from Feed back here on Samba.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Wed Oct 10, 2018 8:58 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Sorry you missed the special, I bumped the thread to keep it on the first page but I guess you didn't notice. Thanks a lot for the order anyway, your business is much appreciated!
The recirc flapper valve will be easier to install with the heater box out. The rest, it doesn't make much difference. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Mon May 13, 2019 6:54 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
tencentlife wrote: |
A little update: the Cabin Air Kit can now be ordered with an independent pull-knob cable control instead of the cable that is integrated with the existing ventilation levers. Price is the same for either.
The pull-knob control is much easier to install and provides smoother more direct operation of the inlet door. Thus is the way I originally developed the kit but then I thought that a lot of owners want things to look totally stock, so I worked out the integrated control. But I decided I should offer both versions.
The pull-knob cable is installed in the lower dash by drilling a 3/8" hole for it. If you don't want to modify the dash you could easily make your own bracket for it, but I won't be providing one. Here's a pic of it installed in the dash itself:
I personally prefer the independent pull-knob, when pushed in as shown the inlet door is closed.
I neglected to update this thread earlier, but as of a couple months ago I no longer offer the original integrated vent lever control method for this kit. Once I added the pull cable option I sold almost none of the lever method, and the pull-knob works so much better I decided once my parts for the lever option were gone I wouldn't bother making them any more. So now all kits come with the pull-knob control method.
Thanks for everyone's support, I hope you all have a great year full of exciting adventures! _________________ Shop for unique Vanagon accessories at the Vanistan shop:
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Mon May 13, 2019 7:07 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
I just installed this last weekend and am really impressed by it. No more whistle from the air box on the highway and the AC is no longer fighting warm outside air. Highly recommended! |
Posted: Mon May 13, 2019 8:42 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
After driving a long cold winter it definitely improves the comfort level! Its best use is blocking incoming cold air during warmup, or dusty air, or smoky air in summer. If you just installed the blocking flap it would be an upgrade. The recirculator feature is nice but secondary, it doesn’t move a lot of air but does improve the heat in very cold weather. With the recirculator on you need the fan running, so meake sure it is lubed up before winter hits! _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Wed May 15, 2019 7:58 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Terrific! Thanks for the reports! _________________ Shop for unique Vanagon accessories at the Vanistan shop:
almo Samba Member
Joined: January 27, 2011 Posts: 174 Location: In the back sleepin
Posted: Wed Jan 29, 2020 11:12 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Will this work with Kens set up from Vanagain.com
https://www.vanagain.com/shop/barebones-dash-ac-kit-for-all-vanagon
I’m a little confused as to where to tie In the fresh air? Or does it just pour in around the dash when opened.
Cheers _________________ San Francisco/Mayo Ireland
1986 2.1L Westy 2wd 4-spd Sold!!!!
1987 2.1L Westy syncro
2005 Subaru legacy 2.5Gt Wagon 5sp MT |
Posted: Thu Jan 30, 2020 8:29 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
If you have questions about installations all my instructions are downloadable here:
https://intrepidoverland.com/product-instructions/
You'd need to look at the AC setup you're considering to know whether they're compatible, but some of them do completely block the normal fresh air pathway and only recirculate cabin air, if so my kit would be useless. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu Jan 30, 2020 11:53 am Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
On Ken's Youtube series he shows the whole front opening permanently blocked.
https://www.youtube.com/watch?v=cmR0Qcs7JUE
I don't know whether that's completely necessary or if you could use the recirc kit. Probably a good question for Ken (then post the answer here so I know what to do when the time comes. ) _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Thu Jan 30, 2020 12:15 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Yeah that seems to be the trend, but the question would be better directed at the sellers of the AC kits, who should know how their set-up treats the Vanagon fresh air ports under the dash. I've never seen one and have no idea how many different ones are being sold and whatever peculiarities they have. My kit lives in the outside inlet scoop and what it does there is plain to see, and if anyone needs more details, just download the instructions. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
almo Samba Member
Posted: Thu Jan 30, 2020 10:00 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
I just watch Kens YouTube series.
I see what you guys mean he blocks off the fresh air inside and out. Noob ideas 🙈 but I am wondering could I maybe get a couple of tee’s and cut into the new ducting that run from the new evaporator to the 2 original side vents on the vanagon. The hard part would be fabbing some kind of a manifold to capture an redirect the fresh air to the new tee’s. My concern is over time it would fill up the new evaporator with dust and debris.
Mite be over ambitious 🙈
Or somehow redirect the fresh air up towards the windshield or footwell? .... hmm _________________ San Francisco/Mayo Ireland
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Wed Feb 12, 2020 4:06 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
Little bit of feedback - I picked up an'86 Syncro a few months ago.
I got the vanistan kit this past weekend. I just installed it. He says you will need 2 hours, that is probably accurate. It could be done in about 15 minutes - as soon as you know how to do it. The longest time for me was just test fitting everything, and making sure I understood how it worked, so I made sure I installed it correctly.
I took my first drive with it today - HUGE difference on the highway. There was no way my heater box could keep up with 65MPH winds coming over it. It was not as cold as it has been, I'll report back with numbers from the temp gauge I had sitting on my dash vents - but initially I'm looking at least a 20 degree temp improvement.
I highly recommend this product - and I've only driven with it for a day _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
4Gears4Tires Samba Member
Posted: Wed Feb 12, 2020 9:08 pm Post subject: Re: Vanagon Fresh Air / Recirc Control Kit from Vanistan |
You should look into replacing everything in your cooling system then. My front blower motor is currently seized and I have all the heat I need. It's very toasty in the van on the highway. Turning on the rear fan seems to heat the van up quicker. That said, my feet are still a bit chilly, it'll be nice to get the front blower motor replaced. Not knocking the mod though, I want to do it at some point.
Just saying your heat should be hotter. _________________ '87 Syncro
