Terry Kay Banned
Posted: Wed Mar 30, 2016 7:36 am Post subject: Re: Throttle Return Spring |
Try pg. 24.37, 24.33 in your Bentley for the correct arm attachment point for the spring.
You havevit on the correct lever.,the question is, where do you have it hooked on the other end? _________________ T.K. |
sped372 Samba Member
Joined: March 30, 2006 Posts: 653 Location: Waunakee, WI
Posted: Wed Mar 30, 2016 6:51 am Post subject: Re: Throttle Return Spring |
Thanks for the info... I snapped that pic after moving the spring to the lower hole. It was in the upper one and the pedal just didn't feel right. I also removed an extra lever/bracket that was for the [now nonfunctional] cruise control because the spring was hanging up on it preventing WOT. I disabled the cruise because of a parasitic electrical load described in a different thread.
Getting the bugs worked out of this van for sure! _________________ 1971 Karmann Ghia - 1600 DP
1984 Westfalia - 1.9 WBX |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Wed Mar 30, 2016 6:26 am Post subject: Re: Throttle Return Spring |
You have your throttle return spring in the correct hole, the upper hole should have a plastic grommet pressed into it along with an adjustable linkage that connects to the EGR valve.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Posted: Tue Mar 29, 2016 7:50 pm Post subject: Throttle Return Spring |
Why are there two 'arms' with eyes near the throttle body? Which one is the return spring supposed to connect to? Mine was on the 'upper' one but the spring pressure felt too strong, I've seen photos with it connected to either of them, and a quick skim of Bentley doesn't clear it up for me.
The top position seems to act "directly" against the accelerator pedal, while the bottom location moves the 'other side' of the torsion spring near the throttle body, so a less-direct return spring effect. _________________ 1971 Karmann Ghia - 1600 DP
