Glasser Samba Member
Joined: September 18, 2007 Posts: 1640 Location: Calgary Alberta Canada
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Thu Mar 31, 2016 7:45 am Post subject: Re: Driving lights |
Can you offer a brand, model, where you got them, cost?
Have been considering adding daytime running lights (DRL) and those look like a great choice. _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1104 Location: North East Pennsylvania
Posted: Thu Mar 31, 2016 9:12 am Post subject: Re: Driving lights |
I'm liking those.
I think DRLs might be a good idea. Most newer cars seem to have some sort of daytime running light. Which brings up something I thought of recently. A 3rd brake light. Anybody running one on their Buggy?
Does your driving light circuit have a relay?
Your garage looks like mine. Um, busy...
Your weld cart has a flat.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Mar 31, 2016 9:23 am Post subject: Re: Driving lights |
BIGMIKEY wrote: |
I'm liking those.
Mike T |
http://www.amazon.com/Marathon-3-50-4-Wheel-Offset...amp;sr=8-3
Hot Air Samba Member
Joined: February 25, 2007 Posts: 664 Location: Baltimore, Maryland
Posted: Thu Mar 31, 2016 9:44 am Post subject: Re: Driving lights |
I guess this was a sign, I was just thinking of adding driving lights since I only have a single filament bulb for head lights. I was just looking them up.
Those are great looking, Great job _________________ 73' Bug
85' Porsche 911 Carrera 3.2 |
Posted: Thu Mar 31, 2016 12:01 pm Post subject: Re: Driving lights |
BIGMIKEY wrote: |
I'm liking those.
Mike T |
I didn't use a relay. The wiring kit I used for my buggy was for a hot rod and had a heater blower motor circuit (High amp circuit) so I just tapped into it and used a heavy duty switch. The lights only draw 530mA so I'm not expecting any issues.
My buggy has a third brake light. It's a little low. I might insert one into the upper roll bar, seems it would be a better position up there.
LOL Yeah I had a new set of solid tires for my welder cart given to me. I went to put them on before I did the LED installation and found out the axle Dia. was different, cant win......
Thanks for the feedback guys. _________________ Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008 |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Apr 02, 2016 9:00 pm Post subject: Re: Driving lights |
BIGMIKEY wrote: |
I'm liking those.
I think DRLs might be a good idea. Most newer cars seem to have some sort of daytime running light. Mike T |
I'm using a set of these on my car as DRL's.
http://www.ebay.com/itm/2x-White-LED-9W-Eagle-Eye-...19ee6c42fe
Mounted them to a piece of 1" wide flat aluminum stock that's sandwiched between my front license plate and its mount. Wired up with a relay so they run whenever the engine is running and the headlights are off. Easy-peasy. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Sun Apr 03, 2016 7:23 am Post subject: Re: Driving lights |
Glasser wrote: |
I went out last night for the first time. No way can I run these at night time, Way too bright. |
Set them up with relay that cuts them off with dimmer switch...
cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Sun Apr 03, 2016 7:26 am Post subject: Re: Driving lights |
Glasser wrote: |
i know its not funny, but i laughed when i read that
leds are bright thats for sure
hey on another note what did you use a filler between your hood and body i see it looks black. or better yet where did you get it |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Mon Apr 04, 2016 7:19 am Post subject: Re: Driving lights |
Glasser wrote: |
sounds like what I need on my Passat. after having 3 cars with zenons, the cost cutting stock headlights on the current Passats SUUUCK. the low beams on my 135i are brighter than the high beams on the Passat. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
Posted: Mon Apr 04, 2016 10:58 am Post subject: Re: Driving lights |
Need a thumbs up or like button Dale, good idea.
LOL Cdnltded.
I think it was actual beetle fender gasket (for lack of better words). It likes to pop out every once in a while. My hood flange is swiss cheese and needs the flanges to be re glassed to fix the holes so I can securely fasten the gasket and hood in position. It's not going anywhere but would be nice to hold that gasket in properly.
I have full intentions to tear the car completely down and get frame and cage blasted and powder coated. Might get some body work done at the same time.
John, Yeah I'm super impressed with these , They are more of a flood light type set up. Not sure they could even be aimed properly to use as a head light but they are going to work fantastic as a in your face day time running light. _________________ Brent
ChadCook Samba Member
Joined: January 09, 2011 Posts: 764 Location: Charles Town
Posted: Tue Apr 05, 2016 11:37 am Post subject: Re: Driving lights |
I like to run them with the high beam, have them wired to the dimmer with a relay. I use a rigid industry light bar on my bike and piaa on the buggy. No problems with other drivers forgetting to turn off their high beams either. |
