VWBUS998 Samba Member
Joined: April 01, 2006 Posts: 102 Location: Toronto, Ohio
Posted: Sun Jan 13, 2008 7:13 pm Post subject: Engine tin and screws |
While deciding on a final paint scheme I figured I'd get my engine cleaned and detailed. I searched and came up with that I'm missing the lower right front tin but from my search it is exclusive to the 79 california 2.0 which is to te best of my research the motor in my bus a picture of this piece or a part number would greatly help out in trying to locate it. Also going to order new screws need a good source and about how many needed for the tin. Thanks _________________ My resto pictures http://mysite.verizon.net/resp7ex0/vwbusphotoalbum/
Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Sun Jan 13, 2008 7:17 pm Post subject: |
I'm not quite sure what piece you need, but I just got a tin to cover my left pushrods (#3 and 4) from a junked bus at a local vw guy's place. Wasn't much, and I ordered up a sack of new screws from Bus Depot just to avoid hassles. It was a dollar or so a bag of 6 or 8, and the tin needed 4 to install. Hope this helps a little! _________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Redd73 Samba Member
Posted: Sun Jan 13, 2008 11:26 pm Post subject: |
sweet. i have about 20 of these now. when im driving regularly i check my tin about once a week. i lose those screws all the time. _________________ "...theres nowhere to go but everywhere." - Kerouac
73 Westy 2000cc w/dual solex (engine code GE) + aftermarket AC |
1FUNBUG Samba Member
Joined: June 29, 2004 Posts: 599 Location: Waterville, OH
Posted: Mon Jan 14, 2008 7:01 am Post subject: |
Get these...
Picture is from Ratwell's site.
You'll use most of the bag if you replace every screw. _________________ 1FUNBUG
71 Beetle, 1776, dual Kadrons
77 Westy, Camper Special 2.0 F.I. |
NOVA Bus Samba Member
Joined: April 18, 2005 Posts: 517 Location: Herndon, VA
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Mon Jan 14, 2008 7:59 am Post subject: |
I always use stainless, with never seize, when replacing tin screws. They always come back out when I need to remove them.
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
jl74supercab Samba Member
Joined: April 13, 2007 Posts: 172 Location: Flemington, NJ
Posted: Mon Jan 14, 2008 9:33 am Post subject: |
for diagrams and part numbers for cooling tin go to http://www.bus-boys.com . Scroll down on the left frame for Air cooling system parts. _________________ 73 Riviera Camper - "Julius"
74 Super Convertible - "Someday" |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Mon Jan 14, 2008 11:02 am Post subject: Re: Engine tin and srews |
VWBUS998 wrote: |
While deciding on a final paint scheme I figured I'd get my engine cleaned and detailed. I searched and came up with that I'm missing the lower right front tin but from my search it is exclusive to the 79 california 2.0 which is to te best of my research the motor in my bus a picture of this piece or a part number would greatly help out in trying to locate it. Also going to order new screws need a good source and about how many needed for the tin. Thanks |
The lower fronts are not Calif only. The left side is the same as 72-74. The right side is 79 Fed or Cal.
The lower tin covering the pushrods is different between 79 Fed and 79 Calif on the left side. Same piece for both 79 Fed and Calif on the right side as 72-74; except 79 does not have the hole in the front edge for the 3rd hose coming off the fuel pump on the 72-74.
On the lower right front: the tin shape is the same between 72-74 and 79 except for the square hole for the hot air duct for the carb pre-heat.
Here are pics of the 2 pieces:
Karl Samba Member
Posted: Mon Jan 14, 2008 11:09 am Post subject: |
Here are the right lower pushrod tin. Only difference is the hole for the 3rd fuel hose coming off the 72-74 fuel pump.
The 72-74:
The 79:
I can post pics of the 79 Calif only left lower if anyone wants to see it. |
Redd73 Samba Member
Posted: Mon Jan 14, 2008 12:05 pm Post subject: |
i have a 73 with a replacement GE block but the original 73 tin. on each only three of the holes line up. _________________ "...theres nowhere to go but everywhere." - Kerouac
twinfalls Samba Member
Joined: November 21, 2003 Posts: 2133 Location: France
Posted: Mon Jan 14, 2008 12:18 pm Post subject: |
vdubyah73 wrote: |
Bill |
I replace rusty screws with stainless too, on my boat and bus; This saves a lot of time. _________________ Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Mon Jan 14, 2008 12:31 pm Post subject: |
Karl wrote: |
That would be nice... |
Posted: Mon Jan 14, 2008 12:44 pm Post subject: |
The puzzle all started when my computer crashed and lost most of my pictures when I started in summer of 2006 I definitly need lower below push rod as in Karl's photo. #1 & #2 I got figured out but #3  along with the piece I'm missing still have me puzzled. I just want to install tin as I assemble my motor _________________ My resto pictures http://mysite.verizon.net/resp7ex0/vwbusphotoalbum/ |
Karl Samba Member
Posted: Mon Jan 14, 2008 5:25 pm Post subject: |
keifernet wrote: |
Karl wrote: |
Here is the 79 Cal left lower:
and
It is easy to confuse it with 80-83.5 Vanagon Calif left lower except......
On the bay the flat section, along the top in the upper pic and along the bottom in the lower pic, is over an inch wide. On the Vanagon, it is about a 1/2 inch wide. Both resemble 75-78 bay lower where it is curved to clear the exhaust manifold. |
Karl Samba Member
Posted: Mon Jan 14, 2008 5:47 pm Post subject: |
VWBUS998 wrote: |
The puzzle all started when my computer crashed and lost most of my pictures when I started in summer of 2006 I definitly need lower below push rod as in Karl's photo. #1 & #2 I got figured out but #3  along with the piece I'm missing still have me puzzled. I just want to install tin as I assemble my motor |
Go here and pick the ones you need. I may have them.
http://www.bus-boys.com/aircoolsystem.html#tin |
Rocknrod Samba Member
Joined: November 02, 2004 Posts: 2157 Location: North Carolina
Posted: Mon Jan 14, 2008 5:58 pm Post subject: |
Best thing I've found was a screw driver that actually fits the tin screws.
Its got a square shank probably three quarters of an inch thick... more pry bar than anything. Clean out the slot, adjustable wrench on the shank and they all pop loose without much fuss. Too small screw driver and the first time it slips dooms all future progress. _________________ 1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My! |
Posted: Mon Jan 14, 2008 7:22 pm Post subject: |
I use a Phillips Posi-driver, large size works well for ski binding adjustment/screws.. _________________ ********************************
1977 Transporter / Weekender
- GE engine, L-Jetronic w/ hyd. lifters
- Brown Beige plaid P27 Interior (ED)
http:/[url=http://www.vw-mplate.com/mplate-29638.png]Click to view image
Camper Interior donor:
[/URL]/www.vw-mplate.com/mcode.php?lang=EN&id=721 (M-Code for interior). |
Karl Samba Member
Posted: Mon Jan 14, 2008 9:50 pm Post subject: |
Can someone please correct the spelling of the word srews in the topic name? |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Jan 14, 2008 9:59 pm Post subject: |
NOVA Bus wrote: |
I use a Phillips Posi-driver, large size works well for ski binding adjustment/screws.. |
A Phillips Screwdriver should not be used with a Pozidrive Screw, or visa versa. Serious damage will result in both the screw and the driver head.
is it really that difficult to get a #3 phillips head screw driver? _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
