delx23 Samba Member
Posted: Sat Apr 02, 2016 2:58 pm Post subject: 67 N.O.S. decklid but licence plate light is odd |
I recently bought this Germany NOS decklid 211 827 085 G.
It looked to be 67 and fits fine on my 67 westfalia..however the backside top where the bulb holder for the license plate is supposed to be has a different shapes and it's flat with no hole for the bulb holder.
I also tried to fit a later bay window license plate bulb holder that gets installed from the outside but it doesn't fit either..I'm lost..
What do I have here?
Thanks guys |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
Posted: Sat Apr 02, 2016 3:04 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
If you look next to the light hole, there should be an indentation for the screws, on both sides. Probably just filled with primer.
How much did you pay for the lid? |
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Sat Apr 02, 2016 3:12 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
Wow, very cool!
Can't be too many NOS deck lids out there any more. Good score.
Sorry, can't help with the licence plate light hole.... _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sat Apr 02, 2016 3:30 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
late bay (72-) are longer than early bay license plate lights. what year light did you try?
looks like a 68-71 light would work _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
delx23 Samba Member
Posted: Sat Apr 02, 2016 3:39 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
skills@eurocarsplus wrote: |
looks like a 68-71 light would work |
Thanks for the reply ..The bulb holder I tried could be adapted but definitely not the right one and should be for a 73..
The weird thing is that I have never seen this before and didn't know that there was a transition bulb holder shared from split and bay window models.. |
Posted: Sun Apr 03, 2016 8:11 am Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
I have the same deck lid and the normal license plate light bulb/lens fits fine. There is no problem |
delx23 Samba Member
Posted: Sun Apr 03, 2016 3:22 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
chrisflstf wrote: |
Chris if you look inside there is no place for the bulb holder ...no hole or indentation..i Have a 66 and a 67 westfalia and the shape of the inside top is different..the lens outside is probably the same but the bulb holder must be the style like the bay window bus have with bulb holder attached to lens..maybe the early bay style like somebody mentioned..
I have never seen the same stamping before..look at pics of the inside top part.. |
Berf Samba Member
Joined: December 09, 2008 Posts: 84 Location: Wichita, Kansas
Posted: Mon May 02, 2016 8:01 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
delx23, I have a '67 bus with a decklid that has only the outside rectangular opening with 2 screw holes one slightly off-center. I suspect that the 68-71 light assembly may be what is supposed to be there. I removed a home-made bracket clogged with silicone & wire ties with bits and pieces from the earlier split bus light hardware. If you peruse the UK web sites that sell VW parts, the 211943161D is listed as the late 67 to 71 application. I can let this thread know in about 4 days if this is so.
Gary |
delx23 Samba Member
Posted: Thu May 05, 2016 7:44 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
Berf wrote: |
Gary |
Thanks Gary |
Berf Samba Member
Posted: Mon May 09, 2016 6:29 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
Well I received the new WW license light and it doesn't seem to fit. The clear cover lens and gasket fit fine, but the light bangs into the cavity. I tried tweaking the metal bracket that is riveted onto the lens, but no joy. My bus is a March 1967 production date. It looks like I'll have to fabricate something. Unless someone is kind enough to post a couple of pics of what is really supposed to be in there. Looks like we may be inf the same boat on this one.
Gary |
Berf Samba Member
Posted: Mon May 09, 2016 7:26 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
Well, I lied. It looks like it will fit:
I put some RTV on the back side of the bulb contact hoop as this is pretty close to the sheet metal on the inside of the lid. And I had to use some nut-clips to repair the wallowed out holes for the 2 screws. Exacto knife for trimming pockets to make room for the nut-clips.
Gary |
Berf Samba Member
Posted: Mon May 09, 2016 7:29 pm Post subject: Re: 67 N.O.S. decklid but licence plate light is odd |
Oh, and I had to trim the nut-clips down about 4mm (approx 3/16") in length so they won't stick out from under the gasket. Not that this bus isn't ugly already... |
