Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Fri Apr 08, 2016 10:05 pm Post subject: Re: 36hp 1500cc Eng. Build |
Thank you all for the kind words in this thread about my work. I am called to strive for perfection on a daily basis.
I want my work to reflect my passion for these little jewels that I build. Each engine I build as if I were building
it for myself. If it does not meet my high quality standards, I don't expect the customer to be happy and it wont
leave my workshop. As a retired aircrarft structure mechanic for 21 years at The Boeing Company, C-17 military
cargo transport, I believe in 1st time quality as the minimum norm. Cheers and God Bless, Mr. Okrasa
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Robert Chambers Samba Member
Posted: Fri Apr 08, 2016 7:19 pm Post subject: Re: 36hp 1500cc Eng. Build |
Amazing! Looks better than New! _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
Posted: Thu Apr 07, 2016 10:27 pm Post subject: Re: 36hp 1500cc Eng. Build |
Lingwendil wrote: |
I'm assuming you have a shop Alodine your case and sump...
I was thinking of building up a Vintage Speed style 40HP at some point and having alodine applied. |
Alodine is for aluminum and not magnesium. Dow #1 is for magnesium. The sump is aluminum but that was treated with a chromate type treatment. _________________
VW www.Okrasa.com
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
ibilisi Samba Member
Joined: August 12, 2011 Posts: 45 Location: United States
Posted: Thu Apr 07, 2016 11:12 am Post subject: Re: 36hp 1500cc Eng. Build |
I love these threads. I really need to get my garage finished so I can start making progress on my '57!
Thanks for the pictures and info! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Apr 07, 2016 8:02 am Post subject: Re: 36hp 1500cc Eng. Build |
Great looking engine- what are your projected power out put on that set up? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
tobiasax Samba Member
Posted: Thu Apr 07, 2016 7:54 am Post subject: Re: 36hp 1500cc Eng. Build |
Wow! Nice job Mr. Okrasa! _________________ __________________________________________ |
Posted: Wed Apr 06, 2016 9:22 pm Post subject: Re: 36hp 1500cc Eng. Build |
I installed the valve train today. Will install the oil galley plugs, valve covers, flywheel seal and torque.
Should go to the craters on Thurs. afternoon.
Cheers. Mr. Okrasa
VW www.Okrasa.com
wcfvw69 Samba Purist
Posted: Tue Apr 05, 2016 4:51 pm Post subject: Re: 36hp 1500cc Eng. Build |
I love these engine builds as well. Amazing how meticulously clean the parts are.
That Ghia engine is ssoo smooth, sitting there idling.
Nice work! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Tue Apr 05, 2016 1:39 pm Post subject: Re: 36hp 1500cc Eng. Build |
sled wrote: |
have those heads been ported?
very nice work Joe. |
While the heads appear to have been ported, they are actually "as cast". With the small Solex style carbs,
you can only flow so much air/fuel through them. Porting/polish ports really comes into effect when you
have all the variables: big valve heads & camshaft, comp. exhaust, match port int/manif.,
BIG 40 Weber's / Solex's, high (mild) compression and of course........a heavy foot! _________________
VW www.Okrasa.com
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Tue Apr 05, 2016 8:14 am Post subject: Re: 36hp 1500cc Eng. Build |
Beautiful looking motor as always Joe. _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
sled Samba Member
Posted: Tue Apr 05, 2016 7:24 am Post subject: Re: 36hp 1500cc Eng. Build |
very nice work Joe. _________________ drive your split. |
Posted: Mon Apr 04, 2016 11:56 pm Post subject: Re: 36hp 1500cc Eng. Build |
GTV wrote: |
That is a thing of beauty.
Please keep the pictures coming. I love your builds. |
I made more progress on the 1500cc 36hp build today.....
I read a thread that the factory valve job on the heads is not as good as it could be so I "touched" the seats with a fine stone.
Installed 80mm pistons.
Installed cylinders.
Installed W.West heads.
Cheers! Mr. Okrasa _________________
VW www.Okrasa.com
Posted: Mon Apr 04, 2016 11:46 pm Post subject: Re: 36hp 1500cc Eng. Build |
GTV wrote: |
Any reason why you don't use a counterweighted crank and/or a lightened flywheel?
I dont like to use the later C/W 912 cranks as there is a lot of weight spinning within the magnesium block.
Early Porsche 2pc. 1500cc engines use the non-counterweighted crank with great success. I have used
early "A" - "B" cranks and have never had any type of failure so i'm sticking with what works for me.
I like the full weight of the stock flywheel. It dampens the crankshaft impulses and makes for a smoother running engine.
I have a 1300cc Denzel engine in my lowlight Ghia with a full weight flywheel and love how smooth it runs.
Check out the engine running:
VW www.Okrasa.com
GTV Samba Member
Posted: Mon Apr 04, 2016 6:27 pm Post subject: Re: 36hp 1500cc Eng. Build |
Please keep the pictures coming. I love your builds. _________________ EMPI Power Rules! |
fcampbell356 Samba Member
Joined: December 15, 2007 Posts: 217 Location: Pensacola, Florida
Posted: Mon Apr 04, 2016 6:04 pm Post subject: Re: 36hp 1500cc Eng. Build |
Thanks for the reply, always like to know.
Frank |
Posted: Mon Apr 04, 2016 5:19 pm Post subject: Re: 36hp 1500cc Eng. Build |
fcampbell356 wrote: |
Thanks Mr. O,
Sorry, but should have asked the following.
Did you use Porsche or VW main bearings?
What piston & cylinder?
Love your photos.
Thanks
Frank |
I use Porsche main bearings.
AA 80mm cylinders that I modify.
Cheers! _________________
VW www.Okrasa.com
Posted: Mon Apr 04, 2016 12:35 pm Post subject: Re: 36hp 1500cc Eng. Build |
Thanks Mr. O,
Love your photos.
Thanks
Frank |
Posted: Mon Apr 04, 2016 11:19 am Post subject: Re: 36hp 1500cc Eng. Build |
Very nice, would like to ask a couple of questions.
What camshaft did you use?
Did you resurface the flywheel?
What lifters are you using?
Thanks
Frank |
To answer your questions in order:
1) I use my own grind. Porsche Super 270*
2) I had Jose @ DPR Performance Cranks & Flywheels resurface, 8-dowell and balance the flywheel.
3) I'm using NOS German 1pc. lifters that I lengthened for stroker motor.
VW www.Okrasa.com
