jimf909 Samba Member
Posted: Sun Apr 03, 2016 10:23 pm Post subject: Nokian WRG2 pre-failure |
Pre-failure? Pre-demise? I'm sure the enginerds have a word for it.
Crawling under the van today revealed this soon-to-fail tire:
Nokian WRG2, 215/60R16 DOT date stamp of 1409, i.e. it's seven years old to the week. Nokian's website provides this interesting 6/10 year rule:
"The recommendation is to use the same tyres for a maximum of six years. Even if you do not use your car frequently in the summer, and your tyres appear to be in good shape, you should nevertheless replace them at the latest when ten years have passed since their date of manufacture."
The tires were installed by the PO on 9/10/2009 and have about 19K miles on them. The snow wear bar is a bit less than 1/16" from contact:
Here's the DOT stamp:
All-in-all, I'm glad I was goofing around underneath my van today. _________________ - Jim
Abscate wrote: |
denver_westy Samba Member
Joined: June 28, 2008 Posts: 130 Location: Albuqueque
Posted: Mon Apr 04, 2016 6:55 pm Post subject: Re: Nokian WRG2 pre-failure |
Wow looks bad are those supposed to be reinforced sidewalls? are they made in russia? I have 15 inch nokians on my westy. |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Mon Apr 04, 2016 7:44 pm Post subject: Re: Nokian WRG2 pre-failure |
I have the same tires in 215/65/15 and like them VERY much. Just went and checked my date code... 1813. Guess I'm ok for now. Thank you for posting the reminder that we should all check from time to time. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Posted: Mon Apr 04, 2016 9:02 pm Post subject: Re: Nokian WRG2 pre-failure |
denver_westy wrote: |
I'm not sure about reinforced sidewalls, but they have an adequate load rating. This tire was stamped as having been made in Russia.
I sure do like these tires too. Reasonably quiet and smooth with above average traction in snow. I'm ordering a replacement set of 215/60R16 WRG3s. I hope to wear them out long before they die of old age. _________________ - Jim
Abscate wrote: |
bluebus86 Banned
Posted: Mon Apr 04, 2016 9:41 pm Post subject: Re: Nokian WRG2 pre-failure |
pre-failure??? I'd say post failure. that is pretty bad. maybe prior owner damaged it some how.
Glad you found it in time before it caused an accident, that could be bad at 70MPH.
Russian made yeah, all part of the post war commie conspiracy.
Do you know there is talk of putting it in milk, children's ice cream? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Tue Apr 05, 2016 8:58 am Post subject: Re: Nokian WRG2 pre-failure |
Look at both ends of the cut. If there are witness/rub marks, it is possible that the damage is from road debris.
For example a damaged storm drain, scrap metal in the road etc.
I had a vehicle with 2 shorter, but similar sidewall cuts. At first I thought it was tire failure until I noticed the rear tire on the same side had identical damage. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
