SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Mon Apr 04, 2016 1:30 pm Post subject: Door Panel Finish |
Good Day,
I have received my new door panels in from the Depot, they look very clean and solid. Overall I’m happy with them. I was attempting to make my own, save a little money and have the pride of crafting my own, but after a couple failed attempts, trying to use what was left of my original panels, I bought the pair for $60.
My question now, how do I finish the panels?? They are paintable, though I’m not sure what color (or make) has an orange similar to the Brilliant Orange paint job the bus is rocking. I have knowingly endless options of cloth, but I’m worried about durability. As for vinyl, other than SewFine in Denver (heard great reviews and have spoken with them personally, good folks), any suppliers of vinyl material that would be worthy of install and durability???
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Apr 04, 2016 3:42 pm Post subject: Re: Door Panel Finish |
I like the material you have there. Probably good sound and insulation qualities too.
Aloha
tp |
Posted: Mon Apr 04, 2016 5:24 pm Post subject: Re: Door Panel Finish |
TP, are you referring to the carpet rug that everything is laying on?
It’s a shame that the original vinyl shrunk so much, it for 40 years old is really nice, full in color and pretty clean. Wish I knew how to accurately stretch it out to reuse. |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Mon Apr 04, 2016 5:47 pm Post subject: Re: Door Panel Finish |
I bet you could get a local upholstery shop to cover them in a quality vinyl in your color of choice for about the price you paid for them.
that would be my suggestion... that or get a bolt of vinyl and some thin foam and do it yourself. nothing better than material that wipes clean. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Mon Apr 04, 2016 7:41 pm Post subject: Re: Door Panel Finish |
Ive been getting vinyl and automotive fabrics from Yourautotrim.com. i usually know what i looking for but something you can look for in a vinyl is one that has a good cold crack resistance. That tells you its going to be softer and nicer to the touch and usually a sign of a better quality. Symphony is my favorite go to vinyl. It a faux leather grain pattern. Spray glue and 1/4 inch foam over your panels first to give a little cushion, just dont wrap foam around the back of the panel. |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Tue Apr 05, 2016 8:41 am Post subject: Re: Door Panel Finish |
SamboSamba22 wrote: |
Do you have some pictures of your original panels? Some careful work with a heat gun and some quality glue and they may be reusable. _________________ 1976 Westy
1966 Beetle |
Posted: Tue Apr 05, 2016 9:08 am Post subject: Re: Door Panel Finish |
Bala,
I'll get a pic of them up here when I go home for lunch, I would love to reuse them. I've called around and have had no luck with finding a supplier with truly close to OEM color, which was a two year run. Bus Depot has a set of MDF panels with the Orange Vinyl on them, but they do not have the original lines and design in the panels.
The reason I'm wanting to reuse the originals is because of the look, the true to character of the factory panels. The bus is a deluxe, so the panels do have the vent door inserts, so the panels of the Depot wouldn't be a drop in replacement. Plus they are $300/set.
I'll look into the heat gun idea, we have plenty here at my day job.
Thanks guys,
Sam |
Posted: Tue Apr 05, 2016 12:52 pm Post subject: Re: Door Panel Finish |
Here are my original door skin vinyl. This is then soaking up the sun, trying to make them a little bit more flexible to work with. I'd love to reuse them!!
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Tue Apr 05, 2016 12:59 pm Post subject: Re: Door Panel Finish |
Good luck reusing what 40 some year old heat pressure strip on vinyl off snf reuse it .... and I have tried all the ways to peel it off.
Those lines are tons of pressure and heat seamed.
IMO chip up $'s to buy the covered Bus Depot panels or get a local upholstery shop to cover them. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
Bala Samba Member
Posted: Tue Apr 05, 2016 1:02 pm Post subject: Re: Door Panel Finish |
Those look great! I would do everything possible to re-use them. Using small binder clips as you go might be helpful too. Last time I made some beetle door panels they were useful in keeping the vinyl in place until the glue sets. And use a bunch, pretty much butt them right up against each other.
1966 Beetle |
Posted: Tue Apr 05, 2016 1:06 pm Post subject: Re: Door Panel Finish |
Werks,
These are my vinyl skins already removed from my original door MDF panels, and I wouldn't mind buying the Bus Depot completed door panels if I hadn't already purchased the blank MDF panels this past week. Plus the completed door panels are for the standard models, not the ones with the vented doors, as my bus is the deluxe.
Bala,
Good thinking, I mean I have no other use for the vinyl panels, so it's worth a shot. It's been a complete miss trying to find accurate model replacements for the front doors.
Cheers guys,
Sam |
Posted: Tue Apr 05, 2016 1:16 pm Post subject: Re: Door Panel Finish |
Should had order the panels with the vent as they such the inside stale air out those vents.
IMO then plan on trimming the wood blanks down the edges for the vinyl shrink over the ages.
Just some ideas trying to help you out. _________________ Werksberg Products....Products that work!
Bala Samba Member
Posted: Tue Apr 05, 2016 1:17 pm Post subject: Re: Door Panel Finish |
I think they'll turn out nice. Are the new panels the correct thickness?
And, I'm guessing you know this, but make sure you don't glue the entire surface to the panel, just the edges that wrap around. _________________ 1976 Westy
1966 Beetle |
Posted: Tue Apr 05, 2016 2:32 pm Post subject: Re: Door Panel Finish |
Well really looking at it, I don't know if I'll be able to stretch it as much as I'm needing to. What do the wise world of the Samba think??
Bala, once you stretched the door panels you used, have they shrunk back much since your install?
Bala Samba Member
Posted: Tue Apr 05, 2016 2:38 pm Post subject: Re: Door Panel Finish |
I didn't re-use the original vinyl, but it did hold in place well with the clips utilized.
What about ironing it out on a low setting? _________________ 1976 Westy
1966 Beetle |
Posted: Tue Apr 05, 2016 7:12 pm Post subject: Re: Door Panel Finish |
I’m still contemplating how if possible, to stretch the vinyl. It has shrunk a large amount in the last 4 decades.
Does anyone know of anyone who has close-to factory orange vinyl for the 74-75 Brilliant Orange Westies???
Please, I don’t want to waste money in the door panels I just bought, to buy the orange panel kits at Bus Depot, just to drop another $300, and cut out the vent track openings in the panels. The panels I have now, are correct to the T, just needing a finishing material. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Wed Apr 06, 2016 5:03 am Post subject: Re: Door Panel Finish |
If you were to bend the backing panel then attach the vinyl to the front and back the force of the backing panel may stretch the vinyl to fit,much like stringing a bow,you may have to trim the bottom of the backing panel . _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
JeBusSaves Samba Member
Joined: May 13, 2007 Posts: 93 Location: SHELTON WA /
Posted: Wed Apr 06, 2016 10:42 am Post subject: Re: Door Panel Finish |
What if you tried throwing the vinyl in the Clothes dryer on low heat for 10 mins? _________________ past' 69' FASTBACK
Current 69' Bus Hightop |
THall Samba Member
Joined: August 25, 2010 Posts: 324 Location: Verona, WI
Posted: Wed Apr 06, 2016 12:12 pm Post subject: Re: Door Panel Finish |
Bala wrote: |
What about ironing it out on a low setting? |
I did this with mine (with a thin towel between the iron and the vinyl) and it worked really well. Work the heat from the center to the edges and clip it in place as you go. Then go around and apply adhesive and re-clip until dry. _________________ '78 Westy - 2.0 FI |
