Harris Samba Member
Posted: Mon Apr 04, 2016 7:26 pm Post subject: JB Weld as a Fix on deck Lid |
Had to remove a '62 deck lid and found this separation at the top. I'm thinking JB weld will help. This is a a high stress point at the spring area. Do you think the JB will hold? I'm sure other older cars have the same thing. the area clamps down well with vice grips.
Ok pushing the spring back on a second look I have over 1/2 " separation. Should I have it spot welded? Or is the JB Ok? The spot weld will result in painting on the lid???
bugheadred Samba Member
Posted: Mon Apr 04, 2016 7:40 pm Post subject: Re: JB Weld as a Fix on deck Lid |
I don't think that will work if you don't want to weld it maybe put 2 pop rivets in use a little paint to touch the heads up |
Harris Samba Member
Posted: Mon Apr 04, 2016 7:42 pm Post subject: Re: JB Weld as a Fix on deck Lid |
[email protected] wrote: |
Rivets. Had not thought of that. thanks. That is a clean way to do it. But that will show on the lid--right
Posted: Mon Apr 04, 2016 7:45 pm Post subject: Re: JB Weld as a Fix on deck Lid |
make sure you get steel rivets put them in from the outside so the head is on the outside I think they will hold and you wont have to burn your paint |
grandpa pete Samba Member
Harris Samba Member
Posted: Mon Apr 04, 2016 7:51 pm Post subject: Re: JB Weld as a Fix on deck Lid |
OK I see what your suggesting. The rivet is on the lip of the lid and not the hood itself so you have really nothing showing. That just may work. |
Harris Samba Member
Posted: Mon Apr 04, 2016 8:04 pm Post subject: Re: JB Weld as a Fix on deck Lid |
Thanks guys. As always your suggestions are good. I've been at this hobby for over 40 years and you young guys come up with really good solutions. If your older the solutions are still good. Always good to check the Samba to be safe. |
bluebus86 Banned
Posted: Mon Apr 04, 2016 9:15 pm Post subject: Re: JB Weld as a Fix on deck Lid |
the JB weld will not hold is my thinking and it would make any future attempt at welding difficult as it would have to be removed first. go for the steel rivets that is a very good idea. make sure you select the correct length rivets. if you ever do get it welded, the rivets can be removed easily and the holes welded up and ground smooth.
mine tore also a bit worse than yours, I removed the spring for now. kind of a pain having to use a prop to hold up the lid. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
stanovich Samba Member
Joined: March 18, 2013 Posts: 191 Location: central coast calif
Posted: Mon Apr 04, 2016 9:56 pm Post subject: Re: JB Weld as a Fix on deck Lid |
see if you can pick up some saber screws they are used in the air conditioning industry are short and self tap quick and cheep 10cents each. you can pull them out and rivet or weld later |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Apr 05, 2016 7:51 am Post subject: Re: JB Weld as a Fix on deck Lid |
Find a muffler repair shop in your area and they should be able to weld it back together.
Even better is you buying a good quality gas wire feed welder and learning how to weld. Not that hard, and so handy down the road! _________________ In Stereo, Where Available! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Tue Apr 05, 2016 7:57 am Post subject: Re: JB Weld as a Fix on deck Lid |
Me - I'd try the steel rivets; I don't weld either.
Eric&Barb wrote: |
Even better is you buying a good quality gas wire feed welder and learning how to weld. Not that hard, and so handy down the road! |
Have a brand/model number you'd recommend to a beginner-welder? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Tue Apr 05, 2016 8:00 am Post subject: Re: JB Weld as a Fix on deck Lid |
Eric&Barb wrote: |
Find a muffler repair shop in your area and they should be able to weld it back together. |
x2. Forget epoxy, get it welded for real.
I had a local welder fix my 62's original decklid many years ago, he did a very good job. _________________ Andy T.
stale air Samba Member
Joined: August 23, 2007 Posts: 5152 Location: Senoia Ga, formally NorCal
Posted: Tue Apr 05, 2016 8:40 am Post subject: Re: JB Weld as a Fix on deck Lid |
I had the same thing happen with my lid. Take is by you local body shop, and have them zap a couple of spot welds on it. Works like a charm. _________________ WANTED: Henry Veale Santa Rosa plate frames
carcrazed Samba Member
Posted: Tue Apr 05, 2016 8:43 am Post subject: Re: JB Weld as a Fix on deck Lid |
JB weld would never hold. Weld is the best bet, but try some heavier pop rivets if you choose not to get it welded. I am not sure pop rivets would be a permanent solution with all the stress from the spring though. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1226 Location: Eerie PA
Posted: Tue Apr 05, 2016 9:13 am Post subject: Re: JB Weld as a Fix on deck Lid |
Find a small local body shop and have it spot welded. If you're going to have to touch up the paint anyway do it to look as factory as possible. Even consider picking up a spot welder from harbor freight when they have their bi-weekly parking lot sales and do it yourself and now you have the welder for future jobs. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
bluebus86 Banned
Posted: Tue Apr 05, 2016 4:37 pm Post subject: Re: JB Weld as a Fix on deck Lid |
pondoras box wrote: |
Find a small local body shop and have it spot welded. If you're going to have to touch up the paint anyway do it to look as factory as possible. Even consider picking up a spot welder from harbor freight when they have their bi-weekly parking lot sales and do it yourself and now you have the welder for future jobs. |
some of the bargin mig welders are more trouble than what they are worth. consider a quality one used.
the Hobart Handler is a nice portable unit. gas for sure, the flux wire sucks. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Apr 05, 2016 5:46 pm Post subject: Re: JB Weld as a Fix on deck Lid |
We have a Hobart Handler and it is a good one. Better ones would be Lincoln or Miller. _________________ In Stereo, Where Available! |
Harris Samba Member
Posted: Tue Apr 05, 2016 7:35 pm Post subject: Re: JB Weld as a Fix on deck Lid |
I'm going in tomorrow afternoon to a well respected body shop here for them to look at the lid. They have helped me on great single stage painting in the past. I ask for spot welding. They do that. We will be looking at the lip on the top of the lid. I have less than 7/16" room on the side that will show with the lid closed. Will report back. Thanks guys for your help Hoping for 2 or 3 spot welds close to the spring plate
Posted: Wed Apr 06, 2016 6:47 am Post subject: Re: JB Weld as a Fix on deck Lid |
Counting four just in the first picture that will need to be welded back up, and it would not hut to add in two more just for a little extra strength. _________________ In Stereo, Where Available! |
