How do I separate the upper and lower portion of an early seat?
khalimadeath
khalimadeath is offline
PostPosted: Wed Apr 06, 2016 8:55 am    Post subject: How do I separate the upper and lower portion of an early seat? Reply with quote
As seen here in these pictures
I need to recover then but it appears these studs are pressed in to connect the upper and lower, however I find that unlikely. If so how do I reattach?
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Wed Apr 06, 2016 9:57 am    Post subject: Re: How do I separate the upper and lower portion of an early seat? Reply with quote
I replaced my covers without separating the back from the seat. Those look like big rivets to me. Can of worms that might be better off closed.
busdaddy
busdaddy is offline
PostPosted: Wed Apr 06, 2016 9:59 am    Post subject: Re: How do I separate the upper and lower portion of an early seat? Reply with quote
They are indeed big rivets, and stepped as well, I've seen them replaced with bolts and nylock nuts but the seat's are never the same.
You can do the job with it assembled.
SGKent Premium Member
SGKent is offline
PostPosted: Wed Apr 06, 2016 10:01 am    Post subject: Re: How do I separate the upper and lower portion of an early seat? Reply with quote
you can do it without pulling the top off the bottom. Be sure to check carefully for broken welds while the covers are off.
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
busdaddy
busdaddy is offline
PostPosted: Wed Apr 06, 2016 10:10 am    Post subject: Re: How do I separate the upper and lower portion of an early seat? Reply with quote
And watch out for those nasty pointy retainer tabs or you'll bleed all over your new seats.
khalimadeath
PostPosted: Wed Apr 06, 2016 11:57 am    Post subject: Re: How do I separate the upper and lower portion of an early seat? Reply with quote
Ok ill leave them together then. I have removed the fabric and it appears that most of the tabs are intact. Thanks for the advice.
[email protected]
Samba Peckerhead
PostPosted: Wed Apr 06, 2016 12:08 pm    Post subject: Re: How do I separate the upper and lower portion of an early seat? Reply with quote
I cheated. blew the rivets out and used stainless button head bolts. I have done it with the seat together but I decided to pop them apart. made it easier for sand blasting too
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
