one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
Posted: Wed Apr 06, 2016 9:54 am Post subject: Starter / Ignition Woes |
This morning, I left for work and my starter fired on while I was driving out of the parking lot. I immediately turned the car off and pull over. I did a quick check of the starter wiring and found no abnormalities.
When I restarted the car the starter would not quit turning even with the car already started. I had to run the car for a 1/2 block grinding away to get it back in it's parking spot. After that I just took my car truck to work.
Is random starter engagement a sign of the ignition going out? I have never had this happen. The starter is wired with a relay looped in to reduce the amount of wiring. Know as the "hot start relay." That has been in place and working fine for a month or two.
Looking for a little help here.
I got home at lunch today, fired the car up and everything seems to be fine. I will drive it to work and see what happens. _________________ My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Apr 06, 2016 9:56 am Post subject: Re: Starter / Ignition Woes |
Could be the switch or the hot start relay. Somehow power is getting to the starter terminal. I'd eyeball the wiring and then suspect the relay. Which relay are you using? |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Wed Apr 06, 2016 11:52 am Post subject: Re: Starter / Ignition Woes |
Do you use the automatic starter? _________________ 71 Elm Green FI A/T Squareback |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Apr 06, 2016 12:12 pm Post subject: Re: Starter / Ignition Woes |
Maybe unrelated, but: How is turning the key? Stiff?
On my Square, particularly when it's cold out, I have to manually turn the key back to run, from the start position. Otherwise, I experience the symptom you describe. Not so bad during Summer months.
I'm pretty sure the ignition switch needs disassembly & lube, but it's low on the priority list. _________________ Everything known to man has been written.
Readers are Leaders! |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Apr 07, 2016 6:04 am Post subject: Re: Starter / Ignition Woes |
I hope you have the little plastic cap that covers the wires in the last pic.
It holds the disc thing in contact with whatever is inside. When not tight, problems follow. BTDT.
If I recall, those caps are difficult (at best) to acquire.
In desperation, I installed at T1 column/ignition. Not "period correct", but works flawlessly. _________________ Everything known to man has been written.
Posted: Thu Apr 07, 2016 6:19 am Post subject: Re: Starter / Ignition Woes |
Air-Cooled Head wrote: |
In desperation, I installed at T1 column/ignition. Not "period correct", but works flawlessly. |
The black cap for the back of the ignition switch is meant as a cover only - it shouldn't be holding anything together.
The caps are not impossible to find...just takes a little patience. It's a commonly hoarded part.
What I've found usually happens is the screw for the aluminum block in the column comes loose, allowing the ignition switch to rotate. The missing screw additionally allows the switch to be pushed against the side of the column housing. Instead of fixing the issue, many people simply shove the key into the ignition to keep the cylinder from spinning so the car can be started. Repeated action leads to the power wire shorting out on the column, roasting the ignition switch along with several wires under the dash.
I'm rebuilding two columns now that experienced this exact problem. My 64 was garaged by its second owner for 25+ years due to this problem. The guy went so far as to completely rebuild an engine with less than 50k miles on it because he thought it was an engine problem.
Posted: Thu Apr 07, 2016 6:38 am Post subject: Re: Starter / Ignition Woes |
ataraxia, thanks for the breakdown. I cannot figure out how to get the blinker switch off. I'll look closer at it this afternoon.
Air-Cooled Head, I do have the cap. It was off at this point.
My short-term fix is going to be removing wire 50 from the steering column wire grouping and wiring it to a switch already in the car for the fog lights. I no longer have to worry about high amp draw from this wire because I have installed the starter relay by the battery.
Taking power away from the switch for initiating the starter is all I need right now. "Keyed power" is still working fine. It was starter signal that was not turning off.
Then I will take my time to source a new switch or a steering column to get it fixed right. I don't want to leave a hack in place forever, but I do want to get my car back on the road for this beautiful Texas spring weather. _________________ My Old 64 Field Find
My Old 66 Beetle
My Old 70 Squareback |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Thu Apr 07, 2016 6:56 am Post subject: Re: Starter / Ignition Woes |
If you are planning on removing the ignition, please take your time and look your column over before pulling it out. Every persons experience with this is different. I considered this surgery and it was a bit stressful but I’ll share with you what I did. The wires on the left side will hold you up from removing the intact ignition cylinder unless the wires are out as in ataraxias first link pics, second page at comment #9 pic. I had a really hard time trying to get the wires out. I ended up heating the soldered points with a soldering pen and removed the wired from the posts (after making a small sketch and documenting which color wires go to which numbered pos). That’s what I ended up doing in trying to get the cylinder out. I did this because each time I was trying to place the cylinder back in after putting the inner pieces in place, the brown cap kept moving on me while trying to place it in place. It wouldn’t sit correctly in its’ spot. This caused the inner springs, cover plate and paper to move around and no longer line up. When I had the brown cap out along with the cylinder, I was able to line everything up, place the cap in the proper place and stamp the little armature piece as depicted in the manuals image to lock the brown cap in place. I was then able to insert the whole thing back into the column and solder the wires back in place. It’s a bit scary process since I didn’t have much to go by but with some of the references on his site and help from others in the community, I was able to get this thing back together. For what it’s worth, I when I was testing my electrical system and I turned the key for the first time and turned my starter, I knew I had succeeded in rebuilding my ignition that had blown up on me. Last week, I fired my car up for the first time in 2 ½ years of rebuilding! Good luck and please take your time if you are going to take this on. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Thu Apr 07, 2016 8:18 am Post subject: Re: Starter / Ignition Woes |
one4house wrote: |
ataraxia, thanks for the breakdown. I cannot figure out how to get the blinker switch off. I'll look closer at it this afternoon. |
There's a very thin circlip holding the turn signal arm off. This is what they look like once off the housing:
Posted: Fri Apr 08, 2016 6:19 am Post subject: Re: Starter / Ignition Woes |
ataraxia wrote: |
Well, that was my experience.
When I got my Notch, that cover was missing. The PO had duct-taped a wad of paper in there. When removed, the car would only start by pressing on that disc when turning the key. Hence, my conclusion that the disc needs to be held in contact with something inside. And, IIRC, at that time, someone was selling those caps for $100 each. _________________ Everything known to man has been written.
Posted: Fri Apr 08, 2016 6:26 am Post subject: Re: Starter / Ignition Woes |
ataraxia wrote: |
When I got my Notch, that cover was missing. The PO had duct-taped a wad of paper in there. When removed, the car would only start by pressing on that disc when turning the key. Hence, my conclusion that the disc needs to be held in contact with something inside. And, IIRC, at that time, someone was selling those caps for $100 each. |
Something was already wrong with your switch by then...the bakelite on the back is about as strong as a Dollar Tree trashbag once it's cracked. Properly built, they're very durable and reliable - especially when there's a hot start relay in the system. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Fri Apr 08, 2016 8:25 am Post subject: Re: Starter / Ignition Woes |
ataraxia wrote: |
ataraxia wrote: |
Yes, if you had to push on it, the bakelite disc was popping out and this had nothing to do with the cap. _________________ How to Post Photos
MonT3 Samba Member
Posted: Tue Apr 12, 2016 3:27 am Post subject: Re: Starter / Ignition Woes |
MonT3 wrote: |
Any updates on this?? |
I put in the push button switch like planned. Works as planned.
I will look this summer for a option to get it back to stock. Right now I am just driving.
I think I may need a new flywheel too. The starter spins without initiating from time to time. Must have damaged mine when I had to run it for 10 seconds with the starter grinding away. Such is life. _________________ My Old 64 Field Find
My Old 66 Beetle
