Syncro Jael Samba Member
Posted: Thu Apr 07, 2016 12:35 pm Post subject: So you have a "NO RUST" Van? |
I recently had a truck throw a good size stone at my windshield. Needless to say a simple rock chip repair was not going to work. I have had success with several of these on the van.
So I removed the glass, seal, and I was appalled at what was under the seal! Rust in several spots, and a "HOLE" in the corner. This van had been repainted in the past 10 years and it shows no signs of rust. During winter camping I remember how much condensation would run off the inside of the windshield. I would roll towels up and stuff them between the dash and the windshield.
It was time to take action and cut out the metal and re-weld in new. I then primed and applied POR 15 to both sides of the pinch welds. (3)three coats.
I was lucky to catch this before things got much worse. Being careful I was able to keep the paint looking good other than one spot needed a touch up with paint.
So take a look under the rubber on your van. If you notice bubble spots raising the edge of the rubber seal, then you know what's going on under there.
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Thu Apr 07, 2016 12:44 pm Post subject: Re: So you have a "NO RUST" Van? |
Bummer. Not trying to show but was happy to see this when I pulled mine last fall. Went ahead and did a preventative rust bullet as added protection
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
A rust bubble on the edge of a window seal is a kiss of death as far as I'm concerned! I certainly do not have the numerous Vanagons of experience as some people on here do, but I think they may agree a rust bubble here is signs of a hole underneath the seal. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Thu Apr 07, 2016 12:46 pm Post subject: Re: So you have a "NO RUST" Van? |
Maybe I can scrape off the rust with a wire brush and paint it with Rustoleum.... _________________ .ssS! |
chase4food Samba Member
Joined: February 27, 2016 Posts: 636 Location: PNW im Amerika
Posted: Thu Apr 07, 2016 12:52 pm Post subject: Re: So you have a "NO RUST" Van? |
May be living in UT does not help thing. And worst if the van is from the rust belt. Higher temperature the faster the oxidation chemical reaction. What about paint damage from bad windshield replacement workmanship? I remember seeing auto glass replacement techs scrapping down the old sealant/caulking with a sharp putty knife and just re-install the windshield without any attempt to reseal the damaged paint. _________________ - Vince 飲食玩睡
what Isolde wants Isolde doesn't always get, 4 I know what is best for her - Liebe macht frei |
Posted: Thu Apr 07, 2016 2:15 pm Post subject: Re: So you have a "NO RUST" Van? |
Abscate wrote: |
Maybe I can scrape off the rust with a wire brush and paint it with Rustoleum.... |
Do a little research on that one. You would be better using automotive paints designed for the job and the proper preparation for the long term protection. Don't get me wrong and not talking you down, Rustoleum is good stuff, but there is better! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Posted: Thu Apr 07, 2016 4:12 pm Post subject: Re: So you have a "NO RUST" Van? |
djkeev wrote: |
The more time that passes that I'm exposed to this Vans, the more I am becoming convinced that a 100% rust free Van does not exist!
Even many of the pristine SW Vans have seam rust and kitchen rust.
If not rusted there the sun dried out the weatherstrip and the is window rust.
In my mind there is a sliding scale ..........
Less Rust >>>>>>> Rusty <<<<<<<<< more Rust
10 ............................. 5 .................................... 0
We ALL fall on that scale somewhere!
Dave |
Oh yah?
You are almost right. I do have a small surface rust spot at the rear door cable entry. Mine is 99.95% rust free. you need to add many more dots by the 10 side for me so I can depict where mine is at. _________________ - Vince 飲食玩睡
Posted: Thu Apr 07, 2016 4:15 pm Post subject: Re: So you have a "NO RUST" Van? |
Dave.
Your scale is in need of some resolution upgrade. _________________ - Vince 飲食玩睡
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Thu Apr 07, 2016 4:28 pm Post subject: Re: So you have a "NO RUST" Van? |
Ron, just park next to mine if you want to feel good about a rust free van _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Thu Apr 07, 2016 4:41 pm Post subject: Re: So you have a "NO RUST" Van? |
For some it may be viewed as foolhardy. My windshield was the recipient of a flying rock within the first year of my ownership. It never fails with every new vehicle that I own, I get a rock chip almost immediately.
It cause a hairline crack on the passenger side near the A pillar. There were no chip fix back in circa 1990 - at least not widely known. I thought should I get the windshield replaced? I knew about the potential risk of having the windshield replaced and only to have the tech damage the paint on the metal. I decided that I would live with it. I still have the same factory windshield today, and the virgin rubber gasket. One of these days, I might replace the windshield myself.
I hope because of this I don't have rust under the windshield gasket.
I have done one on a BMW 2002 and it is a bit of struggle even with a helper. _________________ - Vince 飲食玩睡
Posted: Thu Apr 07, 2016 4:51 pm Post subject: Re: So you have a "NO RUST" Van? |
djkeev wrote: |
You will have rust because the rubber glass seal dried and shrank creating a small gap.
Not because of a glass chip or crack.
3M bedding compound is your friend with new glass.
Dave |
I am unconvinced. If my gasket is in excellent shape, because of spending most time in garage, the painted sheet metal is likely to be in pretty good shape. If I am not mistaken, VW factory used butyl sealant under the rubber gasket. If what you say is true than all other windows would likely be in similar boat, though a bit better due to the forward traveling of the vehicle. _________________ - Vince 飲食玩睡
Posted: Thu Apr 07, 2016 4:59 pm Post subject: Re: So you have a "NO RUST" Van? |
chase4food wrote: |
djkeev wrote: |
Dave |
I am unconvinced. If my gasket is in excellent shape, because of spending most time in garage, the painted sheet metal is likely to be in pretty good shape. If I am not mistaken, VW factory used butyl sealant under the rubber gasket. If what you say is true than all other windows would likely be in similar boat, though a bit better due to the forward traveling of the vehicle. |
You saw my window lip a few posts up, that was OG seal, bone dry. All the rest of my seals are OG too. Every so often I gently lift them up with a flathead screwdriver with tape over the blade to check for rust. So far nada. All the seals are soft and pliable with no cracking whatsoever. I agree with Dave though, they do shrink with age and allow moisture to sit under the seal doing horrible things behind your back. Fortunately I live in a dry climate so, the demons are not as nasty out here |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2319 Location: Adobe Jungle USA
Posted: Thu Apr 07, 2016 5:07 pm Post subject: Re: So you have a "NO RUST" Van? |
My New Mexico van has no rust. Zero. Well, one spot under the corner of the sliding door. Apparently a factory worker forgot to daub it with goo, because all other Vanagons I’ve seen have goo spread in that corner. But in the typical places, no rust at all.
It does however suffer from rubber decomposition from the harsh UV here. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Thu Apr 07, 2016 5:08 pm Post subject: Re: So you have a "NO RUST" Van? |
candyman wrote: |
chase4food wrote: |
djkeev wrote: |
Dave |
Your points are well taken and I appreciate you share your experience. My thinking is that I am better not to lift to examine and stretch the rubber. _________________ - Vince 飲食玩睡
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Thu Apr 07, 2016 5:10 pm Post subject: Re: So you have a "NO RUST" Van? |
that looks like a sunken treasure ship. a Spanish galleon would be my guess. _________________ - Vince 飲食玩睡
Posted: Thu Apr 07, 2016 5:37 pm Post subject: Re: So you have a "NO RUST" Van? |
ftp2leta wrote: |
chase4food wrote: |
that looks like a sunken treasure ship. a Spanish galleon would be my guess. |
No, it's part of the Titanic |
can't fault the French Canadians for their love of gourmet sea salt. _________________ - Vince 飲食玩睡
