Door contact switch wiring question
Spike0180
Spike0180 is offline
PostPosted: Sat Apr 09, 2016 9:59 pm    Post subject: Door contact switch wiring question Reply with quote
PostPosted: Today 2:30 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) Reply with quote Edit/Delete this post Delete this post
Ok. I'm looking at my door contact switch with contact for buzzer. I'm looking at the diagram and at where my wires are. If the button on the diagram is oriented correctly, then my wires are wrong (done my PO and explains why my buzzer and interior lights didn't work)
Here is the question. Where should each of these wires go or what do the internals of this switch act? Here is the diagram I'm working off of. (F3 is the object in question) http://www.thesamba.com/vw/archives/info/wiring/baybus_70_wiring.jpg
And here is what I have.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Curtquarquesso
Curtquarquesso is offline
PostPosted: Sat Apr 09, 2016 10:35 pm    Post subject: Re: Door contact switch wiring question Reply with quote
Well, you can run a simple continuity test with a volt meter to find out whether the switch opens/closes on opposite left/right sides, or back/front sides of the switch.
Brownish-grayish wire: To ground. Goes through T1 insulated connector behind instrument cluster as seen in diagram, then goes to the steering wheel.
Gray/Black Striped Wire: Goes to the buzzer relay, if you still have one.
Brown/White Striped Wire: One wire goes to the dome light, one wire goes across the the other door switch.
White: I'm not entirely sure actually. Where does it lead to currently?
BayCreamPuff
BayCreamPuff is offline
PostPosted: Sat Apr 09, 2016 11:02 pm    Post subject: Re: Door contact switch wiring question Reply with quote
You're holding F2 in your hand. The wires look correct to me. They are all ground wires and when the switch closes (door open) they are all grounded to the frame through the switch and screw.
Gray/Black goes to buzzer relay #85
Brown/White wires go to right door switch and interior lights
Brown wire goes to ignition switch
White wire goes to ???
Clean the contacts on the switch and try touching the unpainted metal part that you're holding in your hand to a good unpainted ground.
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
lintbrush
lintbrush is offline
PostPosted: Sat Apr 09, 2016 11:27 pm    Post subject: Re: Door contact switch wiring question Reply with quote
My wires in my 70 didn't match the diagram, but things are working.
Here is where my wires are going:
1) Brown/white dual wire one goes to interior light and passenger door jam.
2) Brown is ground
3) Black/white is going to ignition
4) White is going to the buzzer
1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/
Spike0180
PostPosted: Sun Apr 10, 2016 8:27 am    Post subject: Re: Door contact switch wiring question Reply with quote
So really front and back and side to side orientation doesn't matter then. I just have to make sure that any of the wires go to any one of the specified locations on the diagram. Perfect! Thanks!
Tcash
Tcash is offline
PostPosted: Sun Apr 10, 2016 9:36 am    Post subject: Re: Door contact switch wiring question Reply with quote
The brown wire with the blue connector has been added by a PO.
That wire should go to a ground lug on the body located to the left of the fuse box.
The other wires are ok where they are. Note there is two sides to the switch. One side is for the door buzzer and the oher side is for the light.
Tcash
Spike0180
PostPosted: Sun Apr 10, 2016 10:15 am    Post subject: Re: Door contact switch wiring question Reply with quote
Tcash
Not the PO. The CO. And thank you tcash. I'll give it a shot.
SevenOaks
SevenOaks is offline
PostPosted: Wed Jul 11, 2018 6:27 pm    Post subject: Re: Door contact switch wiring question Reply with quote
Okay, so I know this is an old thread but I stumbled across it while searching for something else. It enlightened me enough to go take a closer look at my dome lights, dash light switch, door switches and wiring. One hour later the front dome light now comes on when either door is open (and turns off when the doors are closed) and the rear dome light turns on and off with the dash switch. Woo Hoo! Iíve had the bus for five years now and itís still a thrill to fix something even that small. Surprised
David
1974 9-passenger bus
1969 Single cab
Tcash
Tcash is offline
PostPosted: Wed Jul 11, 2018 8:23 pm    Post subject: Re: Door contact switch wiring question Reply with quote
Applause
