stevo96 Samba Member
Posted: Sun Apr 10, 2016 6:58 pm Post subject: Need an extra inch for garage |
Hi Guys,
I need to lower my bus by an inch to get the bus into the garage. I currently have the standard 14 inch wheels and tyres and I'm thinking if I put on a lower profile tyre that should fix my issue. Any ideas on what size tyre i'll need to drop the tyre by 1 inch?
Steve |
nezz Samba Member
Joined: January 13, 2006 Posts: 412 Location: Coimbra-Portugal
Posted: Mon Apr 11, 2016 2:32 am Post subject: Re: need an extra inch |
there's another solution, bu this one brings work every time you want to drive the bus
deflate your tires enough to enter garage and inflate after taking bus of garage |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Apr 11, 2016 3:54 am Post subject: Re: need an extra inch |
is it the opening of the garage, or the door that you need to clear? if the door, that can be adjusted. I would try to modify my door opening before putting tiny tires on my bus. |
JeBusSaves Samba Member
Joined: May 13, 2007 Posts: 93 Location: SHELTON WA /
Posted: Mon Apr 11, 2016 9:22 am Post subject: Re: need an extra inch |
Don't we all..... _________________ past' 69' FASTBACK
Current 69' Bus Hightop |
SGKent Samba Member
Posted: Mon Apr 11, 2016 9:35 am Post subject: Re: need an extra inch |
do you have a roof rack on the bus? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Apr 11, 2016 9:49 am Post subject: Re: need an extra inch |
JeBusSaves wrote: |
Don't we all..... |
I almost said it too... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Apr 11, 2016 10:04 am Post subject: Re: need an extra inch |
I had the same problem. I got sick of the antenna on my new bus clinking up against the old door.
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Mon Apr 11, 2016 12:03 pm Post subject: Re: Need an extra inch for garage |
Almost didn't buy our current home because I wanted a garage and my bus wouldn't fit. I decided garaging the bus wasn't worth passing on a sweet house. I made the right decision. _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
chazz79 Samba Member
Posted: Mon Apr 11, 2016 12:29 pm Post subject: Re: Need an extra inch for garage |
I just remodeled the house. The wife wanted perfectly good white siding swapped for green so I weaseled some 8' doors to replace the 7' doors we bought the place with.
I figured while we're doing needless upgrades I might as well get to not let air out of my tires to put the bus away. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Mon Apr 11, 2016 12:42 pm Post subject: Re: Need an extra inch for garage |
I am in the process of scrapping the automatic roll-up door for classic barn-doors that I just finished buiding. It is gonna buy me like a foot in length and two feet of clearance inside the garage where the bus would barely have been squeezing by all the motor/light apparatus hanging from the ceiling, forget jacking it up. Should have plenty of room when it is done.
My vote is to try and remodel the garage door, or even, if easier, dredge out the garage floor. Smaller wheels/tires come with their own issues.... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Posted: Tue Apr 12, 2016 2:55 am Post subject: Re: Need an extra inch for garage |
Cheers guys, I can't modify the door or the floor. Yes I have a Rack which is a pain to put on and off so that's not an option. Just need the tyre size to drop an inch.. |
Posted: Tue Apr 12, 2016 3:47 am Post subject: Re: Need an extra inch for garage |
well then, what tire are you running now? and if you do this, it may just be a city driving bus, As the motor will have to work harder to spin these tiny things fast enough to hit highway speeds, amiright?
-Edit also, what about using drop spindle to lower the bus?(in the front. You would adjust the thingamajig in the rears by dropping a couple teeth/spindle/whatever. tortion bar? ) |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Tue Apr 12, 2016 5:19 am Post subject: Re: Need an extra inch for garage |
stevo96 wrote: |
Theres no way I would take advice over the inter webs over simply measuring my tire, mounting a proposed tire on my rim, and then measuring that.
Just for giggles I looked up tire diamater variance for new tires and it is about 1/2 inch - ergo you probably need to measure your actual new tires to fit, not just assume all 14 inch rubber is equal. _________________ .ssS! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
Posted: Tue Apr 12, 2016 6:39 am Post subject: Re: Need an extra inch for garage |
I think you need to decide which you want more; a roof rack or to park your bus in the garage? If you are currently running the proper rated tires for a bus you will be hurting the performance/ride of the bus buy going with a smaller P rated tire. A P rated tire is rated for a passanger car not a VW bus, which requires a D rated tire. Now, if you currently have P rated tries, you'll probably never notice a difference... _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
SGKent Samba Member
Posted: Tue Apr 12, 2016 7:09 am Post subject: Re: Need an extra inch for garage |
wait until something is in that roof rack and you forget when you pull in thinking you have clearance. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
rodgersbadassbus64 Samba Member
Joined: January 24, 2009 Posts: 417 Location: Ortonville, Minnesota
Posted: Tue Apr 12, 2016 7:53 am Post subject: Re: Need an extra inch for garage |
If you go online you can find a tire size calculator. You input your tire size and it will tell you how tall it is and you put in the tire size you want and it tells you the difference between the new tire and your original Tire. Very simple. There are a lot og OG GUYS who live for Busses. They are right 6 ply tires are great just in case but there are many more who have lower profile tires. I had rubber band formosa tires once...not Doing that again I think they were 22 inches tall on the front. I now have 185 65 15 at 24.4 inches tall. Please don't dig out your floor...Lol Many have posted there garage solutions and I am impressed with 8 foot doors while getting new siding as well as the barn doors. I have left stuff in my rack it wasn't good opps:( |
HelmutofBuffalo Samba Member
Joined: August 22, 2005 Posts: 554 Location: West Coast of New York
Posted: Tue Apr 12, 2016 7:58 am Post subject: Re: Need an extra inch for garage |
SGKent wrote: |
wait until something is in that roof rack and you forget when you pull in thinking you have clearance. |
Been there done that
Once forgot I had the kayaks up there and tried to pull into garage
_________________ 1979 Type I Convertible |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Apr 12, 2016 8:31 am Post subject: Re: Need an extra inch for garage |
Things you use, rely on or significantly appreciate every time you use your bus:
1) the proper tire size (whether you know it or not)
2) the garage
Things that bring you occasional use or moderate pleasure:
1) the rack
Suggestions / options:
1) take off the rack, temporarily install when really needed.
Benefits:
1) bus will handle & drive normal.
2) rack will stay in better condition (if stored inside, ceiling?)
3) engine may last longer
4) you get to park in the garage.
Small tires will wind your engine out at highway speed & look funny. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
