Thing Lift Spindles
Spoole12
Spoole12 is offline
PostPosted: Wed Apr 13, 2016 6:13 am    Post subject: Thing Lift Spindles Reply with quote
Who is the best provider of lift spindles for a thing I am trying to get some clearance on?
1963 Hippy Bus (11 window camper)
1974 Thing
1969 Baywindow (sold)
1963 Turkis Single Cab (sold)
1973 Sunroof Baywindow (sold)
1967 13 window Deluxe Bus (sold)
1974 Karman Ghia Convertible (sold)
1969 Squareback (sold)
63ziggy
63ziggy is offline
PostPosted: Wed Apr 13, 2016 5:51 pm    Post subject: Re: Thing Lift Spindles Reply with quote
check with Locky. He has a set made by Doug Fuller in Utah. I believe he was very pleased with the quality.
I had a set made by Blind Chicken Racing. It was not the best customer service experience. They sent me someone elses. I ordered 2". I received a set like 3 1/2", took forever to rectify. I returned the incorrect set. took a very long time to get replacement set. end result, the replacement set look like they just cut down the wrong set and welded back together.
I am still running but would pass in the future in dealing with BCR.
Doug is also on Volksrod site if you are looking for contact info.
I am not aware of others. Tweed used to make a set. I do not believe available any more.
Not sure if Bugzyla will make set. They do extended arms etc
let us know where you land and what you think
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
sam_w
sam_w is offline
PostPosted: Wed Apr 13, 2016 9:45 pm    Post subject: Re: Thing Lift Spindles Reply with quote
I have doug fuller spindles and they are great.
63 singlecab
73 thingster
sam_w
sam_w is offline
63 singlecab
73 thingster
Ratt
Ratt is offline
PostPosted: Wed Apr 13, 2016 10:25 pm    Post subject: Re: Thing Lift Spindles Reply with quote
I just installed a set of Doug's spindles. I love them. Really nice quality. They took a bit to get, but well worth the wait.
I've got 3" taller, and the steering knuckle runs on the wheel a bit. I will need to use spacers or get wheels with a different back space.
Home is where the Bus is!
vwthingboy
vwthingboy is offline
PostPosted: Sat Jul 29, 2017 10:50 am    Post subject: Re: Thing Lift Spindles Reply with quote
Paging Ratt, Sam and Locky, please,
The Doug Fuller raised spindles are getting installed on my car and my Rader wheels are tight against the tie rod end.
The wheels are 5" wide with a 3.25" backspace.
Did you guys end up using spacers?
My shop tells me I probably need .5" or .75" spacers.
Where would I get spacers from?
I see them on Cip1 and others.
Thanks for any and all guidance.
-Sean
Duffer 2005-2012
Volkstuning
Volkstuning is offline
PostPosted: Sun Dec 03, 2017 8:35 am    Post subject: Re: Thing Lift Spindles Reply with quote
Hi, Can someone provide with contact info for Doug fuller please.
Thanks
63ziggy
63ziggy is offline
PostPosted: Sun Dec 03, 2017 9:48 pm    Post subject: Re: Thing Lift Spindles Reply with quote
found this info from one of Doug's classified on The Samba
it was renewed 10-30-17, should be good
please check my feedback for the proof of this for youself
you will be more than happy with my service!
[email protected]
mail spindle cores to:
Douglas W Fuller 801-529-5153
435w 1550s
Sunset UT 84015
i did raised spindles by another company(not the best experience). I had to use like a 3/8 spacer if I recall to get clearance from the rim and spindle tie rod arm. I would have gone with Doug but had committed to other company and was in middle of that when I found out Doug was doing raised spindles.
Ratt
Ratt is offline
PostPosted: Mon Dec 18, 2017 10:50 pm    Post subject: Re: Thing Lift Spindles Reply with quote
Using Doug's spindles, Ill need to run a spacer with 14" wheels. 15's look like they will clear. Additionally Im not sure If I am going to be able to run discs in the front or not with how the spindle is built. I haven't had a lot of progress on my thing in the last year or two. Doug did great work, but the turn-around was a little long. It was a little on my end and a little on his end. All in all, I am happy with the product and they sure make my Thing sit nicer.
