Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
Posted: Sat Apr 16, 2016 4:31 pm Post subject: Question on Axle, trailing arm and trans matching. |
I did try and search for this, but got conflicting info, so here goes.
For which transmission (bug or bus) do you use the 18-3/4" axle, with 2 X 3 arms in a Type 1 chassis? Like I said, I have seen posts saying both, but I know that can't bee right since I had to go to 15-5/8 when I installed my 002 in my Baja. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
jsturtlebuggy Samba Member
Posted: Sat Apr 30, 2016 4:13 pm Post subject: Re: Question on Axle, trailing arm and trans matching. |
Originally the 2x3 arms were made to use the stock length Bus axles when converting to a Bus (type 2 IRS) transaxle to keep cost down.
The Bus trans is approximately 18mm wider at outer edge of CV flange to CV flange then a type I transaxle, that is only 9mm on each side. I am sure you can use the same axle length.
You may end up with a little less wheel travel. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
