paf Samba Member
Joined: February 24, 2015 Posts: 138 Location: France
Posted: Tue Nov 29, 2016 6:19 am Post subject: Split case : gear shift bushing ? |
Hello,
I have a euro 58 bug (I know this is for oval only, but split case is more common on oval than on 58-67 bugs, this is why I post here) with a split case transmission. I changed the fluid to a new one 75W90, but I still have the problem so shift down to 2nd when it is cold (grinding) and sometimes to engage first gear when stopped. That was present before, even if the new fluid helped for mild temperature conditions. Some tells me to change the shift bushing, and/or the coupler, but I would like to be sure that the bushing is present on a split case because I found contradictory information on that, for instance on the workshop manual in french for 52-57, not mentioning the bushing. Can someone help me to understand ? thanks. _________________ Fred
Euro '58 L334 bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=657333 |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Nov 29, 2016 6:35 am Post subject: Re: Split case : gear shift bushing ? |
Are you speaking of the shift rod bushing in the tunnel?
if so 58 didn't have one from the factory just a spring lever to hold tension on the shift rod.
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
paf Samba Member
Posted: Tue Nov 29, 2016 6:45 am Post subject: Re: Split case : gear shift bushing ? |
Yes I was dealing with this... So no shift rod bushing... Then the problem is related to the coupler only ? _________________ Fred
Euro '58 L334 bug
Posted: Tue Nov 29, 2016 7:26 am Post subject: Re: Split case : gear shift bushing ? |
How does it shift with the engine off?
could be coupler, take off the cover and watch it as you shift. it is just a steel clad piece of rubber and could be soft. Also how is your fee play at the clutch pedal? _________________ Rick
tasb wrote: |
sb001 wrote: |
paf Samba Member
Posted: Tue Nov 29, 2016 7:30 am Post subject: Re: Split case : gear shift bushing ? |
Free play is OK (20mm about 4/5"), I set it up recently, when I drain the old fluid : June this year. Can check again. I will check the coupler as well, maybe it is just loose.I do not remember how it is when the engine is not running, I will check as well this evening. _________________ Fred
Euro '58 L334 bug
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Tue Nov 29, 2016 8:42 am Post subject: Re: Split case : gear shift bushing ? |
paf wrote: |
but I still have the problem so shift down to 2nd when it is cold (grinding) and sometimes to engage first gear when stopped. |
This sounds like the clutch not fully releasing and/or sticky pilot shaft bearing inside the flywheel gland nut especially as it relates to your first gear symptom. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Tue Nov 29, 2016 8:43 am Post subject: Re: Split case : gear shift bushing ? |
What condition is the nose cone bushing?
Check that the coupler bolts are tight and properly safety wired. _________________ In Stereo, Where Available! |
paf Samba Member
Posted: Tue Nov 29, 2016 9:05 am Post subject: Re: Split case : gear shift bushing ? |
Snort wrote: |
paf wrote: |
Does it mean that the clutch is definitively not correctly set up ? Can it be the free play not properly set up (I already checked, but why not) and the curvature of the bowden tube not correct ?
Eric&Barb wrote: |
What condition is the nose cone bushing? |
Well, I do not know, I will check it this evening if I can.
Eric&Barb wrote: |
Check that the coupler bolts are tight and properly safety wired. |
I will check at the same time. _________________ Fred
Euro '58 L334 bug
Posted: Tue Nov 29, 2016 9:14 am Post subject: Re: Split case : gear shift bushing ? |
Do check the clutch pedal free play is correct.
Boden tube should only affect the release of the pedal. The proper curve in it acts as a shock absorber so the clutch does not bounce when suddenly released. _________________ In Stereo, Where Available! |
Snort Samba Member
Posted: Tue Nov 29, 2016 9:20 am Post subject: Re: Split case : gear shift bushing ? |
paf wrote: |
Does it mean that the clutch is definitively not correctly set up ? Can it be the free play not properly set up (I already checked, but why not) and the curvature of the bowden tube not correct ? |
Yes, but it can also be any number of parts that are worn or broken including pedal cluster, stretching clutch cable close to breaking, detached clutch cable tube, broken or improperly setup bowden tube, damaged cross shaft, failing pressure plate, clutch disc out of spec, flywheel surfaces machined improperly and again the pilot bearing binding on the transmission shaft so that even if the clutch is releasing properly the shaft still spins with the motor. |
paf Samba Member
Posted: Tue Nov 29, 2016 9:47 am Post subject: Re: Split case : gear shift bushing ? |
waoooo.... I don't know for most of them, but the clutch cable is new, I changed it last year due to a breakage... the bowden tube, is the same because I did not change it as it was correct (maybe I should have done it). The rest, well I do not know...
At least I will check the few item I can check.
Just by curiosity, changing the nose cone bushing needs the tranny to be out of the car ? _________________ Fred
Euro '58 L334 bug
Posted: Tue Nov 29, 2016 10:00 am Post subject: Re: Split case : gear shift bushing ? |
paf wrote: |
Just by curiosity, changing the nose cone bushing needs the tranny to be out of the car ? |
Yes it does. _________________ In Stereo, Where Available! |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Tue Nov 29, 2016 5:33 pm Post subject: Re: Split case : gear shift bushing ? |
paf wrote: |
Hello,
I have a euro 58 bug (I know this is for oval only, but split case is more common on oval than on 58-67 bugs, this is why I post here) |
I'm guilty of the same thing _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
paf Samba Member
Posted: Wed Nov 30, 2016 3:17 am Post subject: Re: Split case : gear shift bushing ? |
Hello,
I checked several thing yesterday evening :
* the coupler is ok, both screws are correctly tightened, safety wires are still present
* the freeplay was maybe to important, I tried to reduce it, but at one moment this is difficult to find the limit between moving freely and resistance is felt... I did not make a run yesterday, but will as soon as possible.
* the strange thing I noticed, is that when using the clutch pedal I can hear a squeak coming from the cable. I checked the Bowden tubes and while on all books the curvature is thru the floor on mine it is thru the top, I do not think this can be the problem, but I am doubtful about the squeaking... I did use lot of grease when i changed the cable however.
The thing I did not mention originally is that my bug is equipped with a SperrWolf shift lock from the factory, and while I wanted to check if the shift plate can be adjusted, I faced the issue that I am unable to understand how to dismantle/remove the shift lock. I will try to find documentation, but this is not similar to the service bulletin I saw on the site.
Next is to tests with the free play reduced. _________________ Fred
Euro '58 L334 bug
Posted: Wed Nov 30, 2016 7:51 am Post subject: Re: Split case : gear shift bushing ? |
Been a while since working on ours. Remove the screw in the front of the lock. Turn key to unlocked position and shifter in neutral. Slide top toward rear. _________________ In Stereo, Where Available! |
paf Samba Member
Posted: Wed Nov 30, 2016 8:28 am Post subject: Re: Split case : gear shift bushing ? |
Hello,
I checked again the clutch freeplay setting, and found something strange : the pedal is really loose at the beginning of the movement, whatever is the position of the nut on the lever (tighten or not tighten). I am not able to have it firmly and directly seated by the cable. The issue can come from this, isn't it ? I can confirm that the lever spring is present and not broken. _________________ Fred
Euro '58 L334 bug
Posted: Wed Nov 30, 2016 9:02 am Post subject: Re: Split case : gear shift bushing ? |
broken clutch tube welds in the tunnel? _________________ Rick
tasb wrote: |
sb001 wrote: |
paf Samba Member
Posted: Wed Nov 30, 2016 9:07 am Post subject: Re: Split case : gear shift bushing ? |
Not sure, before it broke, I did not meet the problem, I should have done something wrong when replacing it. _________________ Fred
Euro '58 L334 bug
Posted: Wed Nov 30, 2016 9:22 am Post subject: Re: Split case : gear shift bushing ? |
so the problem started when you replaced the stretched clutch cable?
could be the TO bearing is not setting on the clutch arm right? _________________ Rick
tasb wrote: |
sb001 wrote: |
paf Samba Member
Posted: Wed Nov 30, 2016 9:42 am Post subject: Re: Split case : gear shift bushing ? |
60ragtop wrote: |
so the problem started when you replaced the stretched clutch cable? |
Yes, before the replacement the clutch and gears where perfect..
60ragtop wrote: |
could be the TO bearing is not setting on the clutch arm right? |
Well I do not catch what TO bearing stands for, sorry for my bad english... _________________ Fred
Euro '58 L334 bug
