jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Apr 21, 2016 4:55 pm Post subject: Re: low power |
No u dont. I'm running .585 lift and using 4046 bugpack springs. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
vw moses Samba Member
Joined: April 17, 2012 Posts: 213 Location: independance,louisiana
Posted: Thu Apr 21, 2016 6:21 pm Post subject: Re: low power |
that was their recommendation(cb), because that much lift(505) would wear out my springs faster. i got duels that came w/heads. _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
63 one of a kind beetle. 57 dash,double rear window--sweet! |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Thu Apr 21, 2016 6:37 pm Post subject: Re: low power |
You have the wrong heads for your application. A nice set of the Chinese castings, stock valved and about 50cc. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Apr 21, 2016 7:03 pm Post subject: Re: low power |
when can i bring in to your shop? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
MURZI Samba Member
Posted: Thu Apr 21, 2016 7:34 pm Post subject: Re: low power |
I am getting ready to start another engine so it may be a while. In the time being you should pull the engine, pull the heads, check your deck height and send those heads to Lee at action imports to get flycut. Reassemble with some nice 1.25 rockers, adjusters on PR side, lash caps, and chromoly pushrods. I'll help you with the reassembly. With better compression, .500 ish lift, and correctly jetted (dialed in with wideband) carbs it will run way better. In the end it's still a 1679 though. 80-85hp maybe. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Apr 21, 2016 7:52 pm Post subject: Re: low power |
allright--sounds like a plan--lets attack! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
MURZI Samba Member
Posted: Thu Apr 21, 2016 7:58 pm Post subject: Re: low power |
He is in Shreveport. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Apr 21, 2016 8:07 pm Post subject: Re: low power |
ok i'm going to pull out tomorrow. let you know when the heads are off.
thanks!--i'll be in touch _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
MURZI Samba Member
Posted: Tue Apr 26, 2016 5:31 am Post subject: Re: low power |
Did you pull it? _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Mon Jun 27, 2016 1:55 pm Post subject: Re: low power |
pulled mtr. removed the heads
deck is .050
my comp. is 7.7
i know i don,t need shims
but fly cut heads-to ???
presently working that out
i'll post more pic's later _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Posted: Mon Jun 27, 2016 2:09 pm Post subject: Re: low power |
that low compression explains why you needed such fat jetting so the engine would actually tear a paper bag. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Mon Jun 27, 2016 5:09 pm Post subject: Re: low power |
this is how much carbon formed
from over jetted _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
sled Samba Member
Posted: Mon Jun 27, 2016 5:12 pm Post subject: Re: low power |
looks like your heads have a big step in them? so your deck is actually much larger than .050
would explain poor combustion and lack of power _________________ drive your split. |
Posted: Mon Jun 27, 2016 5:37 pm Post subject: Re: low power |
what! there stock 044 mag. 55cc 40x37
you can change the step? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Jun 27, 2016 5:38 pm Post subject: Re: low power |
Have the steps milled out and it will fix your excessive deck issue and bump up the compression ratio where the can is happy. A smaller exhaust may help too. I'd bet it would wake up that engine. |
Posted: Mon Jun 27, 2016 6:11 pm Post subject: Re: low power |
not familiar w/step--what to look for
need pics-would help
i thought fly cutting the head was all i needed,
i want to do all the bells and whistles before they go on again
so i can "feel the power" _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
mark tucker Samba Member
Posted: Mon Jun 27, 2016 6:34 pm Post subject: Re: low power |
if you take em to mizzies guy have them remove the step...or take it down to .040 and set the piston deck to zero(flush with top of cylinder. or mill out step and leave piston down .040 or zero deck&.040 copper head gadget.
tighter deck will usualy use a smaller main &idle jet and the chambers will so stay a lot cleaner.
unless those heads dont have aastep....and were just looken at the thickwall cylinder seating that looks like a step |
Posted: Mon Jun 27, 2016 6:36 pm Post subject: Re: low power |
i do have the thick walled 88 p&c's (a/a) _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Posted: Mon Jun 27, 2016 6:42 pm Post subject: Re: low power |
heres some close ups
does it look clearer? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Posted: Mon Jun 27, 2016 6:58 pm Post subject: Re: low power |
i took a razor and scraped the carbon
its flat across to edge
i lapped the jugs against the heads w/valve compound so theres a distinguishing mark
what ya think? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
