AirAssault2 Samba Member
Joined: April 06, 2015 Posts: 64 Location: Washington D.C.
Posted: Thu Apr 21, 2016 11:59 am Post subject: Front door hex bolt stripped. Tried everything. Help me! |
Good afternoon, for the last 7 hours I have been trying to take off my driver's door and replace it with a new one. I have tried everything to remove the hex bolts holding on the door. I've successfully removed one in the last seven hours (not the best success rate). I have tried everything I could think off, allen key, torque key, cut a slot in it for a flat head, chisel and hammer and heated it with a propane torch, all with no success. Any other ideas out there from you guys? |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Thu Apr 21, 2016 12:03 pm Post subject: Re: Front door hex bolt stripped. Tried everything. Help me! |
Drill out the heads of the bolts, replace with new hardware. Always use a hex socket when removing those bolts cause they're easy to strip. Once you drill the head off and remove the door the body of the bolt will turn right out. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
SGKent Samba Member
Posted: Thu Apr 21, 2016 12:31 pm Post subject: Re: Front door hex bolt stripped. Tried everything. Help me! |
and don't forget to put a little penetrating oil on it next time. Also an impact screwdriver helps with that type removal. Just need to find one that takes or has a socket for an allen that size. Remember that allen come in metric and standard English/American sizes. Make sure you have the correct metric allen.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Peabody Samba Member
Posted: Thu Apr 21, 2016 4:47 pm Post subject: Re: Front door hex bolt stripped. Tried everything. Help me! |
For bolts you have not stripped yet:
QUALITY hex socket, as was said above. 3/8" drive with metric hex. Use an impact gun if you have one. If not, use a breaker bar, apply loosening pressure and have your buddy hit the breaker bar continuously until it breaks the bolt free.
For stripped bolts:
Find a bit just larger than the SHAFT of the bolt. Start drilling in the CENTER of the bolt until the head of the bolt spins off. When you get all the bolts out or drilled off, remove your door. Then use a stud extractor (the reverse collet type http://www.amazon.com/Titan-Tools-16023-Drive-Extr...+extractor ) to remove your stud.
Don't cheap out on yourself. Buy the right tools. You'll spend more time and jack more shit up if you don't. _________________ '71 Transporter "June" (traded a nissan hardbody + some $) (daily)
'76 Westy "Sandy" (traded an ak-47) (on hold)
'77 Westy (parts)
'74 Westy (parts) |
Posted: Thu Apr 21, 2016 7:24 pm Post subject: Re: Front door hex bolt stripped. Tried everything. Help me! |
You guys are awesome! Thanks so much! I got them off thanks to your suggestions. |
beatles4 Samba Member
Posted: Thu Apr 21, 2016 7:45 pm Post subject: Re: Front door hex bolt stripped. Tried everything. Help me! |
I highly highly recommend that handheld impact driver. It saved my bacon a few times and I have already put it to good use on my bus. You do have to hit it hard though. _________________ Click to view image
http://www.vw-mplate.com/mplate2-27771.png |
Gib_Gas Samba Member
Posted: Fri Apr 22, 2016 10:44 am Post subject: Re: Front door hex bolt stripped. Tried everything. Help me! |
If you work on any vintage vehicles the handheld impact driver is a must. _________________ 1979 Deluxe Westfalia 2.0 FI |
