minnisp Samba Member
Posted: Mon Apr 25, 2016 9:13 pm Post subject: Heavy gauge red wire loose in engine compartment? |
So I've been diagnosing a will-crank, no start, no spark on my 89 noncamper (manual). I removed the black plastic relay box and the existing coil. and i tried a new coil. I screwed it in place temporarily and noticed a heavy gauge red wire hanging loose near where the support for the plastic relay box sits above the coil. I traced it using Bentley and some gallery pics. I'm pretty sure it's from the AC relay. But is it ground? It's red, not brown. Let me know if any of you recognize it .. i'm still researching it.
Abscate Samba Member
Posted: Tue Apr 26, 2016 2:01 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
A red ground with a protective sheath? Probably not. Looks very B+ to me. _________________ .ssS! |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Tue Apr 26, 2016 3:11 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
Me Too. I would like to see a picture of the alternator. I bet that wire will reach the B+ terminal all the way to the right side of the engine behind the Alternator.
Tony _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
Posted: Tue Apr 26, 2016 4:56 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
the sheath the wire is in also contains the wiring that plugs into the compressor and the sheath runs up the pillar on the rear drivers side. I have always known RED to be +, but the damn thing looks like its made a home there in that position. Probably a coincidence it's got to go to some + terminal somewhere. I like the alternator idea but didn't see a path there. I"ll post a better pic of the sheath and maybe someone here has the same cable and can identify it. Since i'm new owner i can blame previous owner. that's my right |
Posted: Tue Apr 26, 2016 5:01 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
yes i changed the fuel lines. those things were crusty and reading about the fire hazard here on the forum i made it a priority. I also changed the coolant lines as you all have recommended. This site is a fantastic resource thank you all for the help!!! |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Tue Apr 26, 2016 6:23 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
AC power, connects inside distribution box to post in upper right corner, IMHO. If not using AC, just leave it, no 12V unless connected. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Posted: Tue Apr 26, 2016 6:27 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
I should have added, tape it off for good practice.
If you use white electrical tape, you could label it for what it is to remind you next time, too. Cross referencing it the numbered terminal on the wiring diagram would get you the journeyman auto electric merit badge. _________________ .ssS! |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Tue Apr 26, 2016 7:22 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
I believe it attaches to the B+ post on the alternator. I also believes it powers up the A/C. The wire eventually goes up the upper left rear pillar.
Posted: Tue Apr 26, 2016 8:24 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
from the gallery
that looks like my wire coming from the drivers side.
I should be able to trace in Bentley now that i know where to look. Thanks everyone! |
Posted: Tue Apr 26, 2016 11:48 am Post subject: Re: Heavy gauge red wire loose in engine compartment? |
My last no start issue was the hall sensor in the distributor. I am sure from the pro training guide it can be a lot of other things also but mine was the Hall Sensor.
Good luck _________________ TP in the Pack (I am a cyclist)
1990 Vanagon DOKA
1972 Super Beetle
Posted: Tue Apr 26, 2016 7:24 pm Post subject: Re: Heavy gauge red wire loose in engine compartment? |
my distributor looked very shaky, crumbling connector, corroded wires and a LOT of play. even if it's something else i couldn't drive far with that thing. i found a rebuilt one in the classifieds waiting on arrival. |
