guatebus Samba Member
Joined: May 12, 2003 Posts: 393 Location: Oakland, CA
Posted: Wed Apr 27, 2016 8:42 pm Post subject: Best Jack for Changing a Flat Tire? |
Hey, what jack are you guys carrying around with you in the bus for changing a flat tire?
I have a nice floor jack for work in the garage, but it is a beast to carry around in the bus.
I used to just carry a AAA card instead of a jack, but a recent experience has made me reconsider this practice. _________________ '64 standard microbus
'69 deluxe microbus |
ezcamper Samba Member
Joined: January 10, 2001 Posts: 897 Location: Atlantic Beach, FL
Posted: Wed Apr 27, 2016 8:46 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
If you jack points (and surrounding steel) are not rusted, a stock jack is great.
I carry a small walmart floor jack in a plastic case. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Nitty Samba Member
Joined: July 07, 2003 Posts: 488 Location: Farthest South
Posted: Wed Apr 27, 2016 11:28 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
The stock jack is great. I carry a wooden pad for ground support if needed. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Apr 28, 2016 7:08 am Post subject: Re: Best Jack for Changing a Flat Tire? |
Harbor Freight aluminum floor jack, $59, small enough and only about 40 pounds. I have one in each of my vehicles. _________________ Some people are so busy being clever they don't have time enough to be wise. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Malokin Martin Samba Member
Posted: Thu Apr 28, 2016 12:13 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
pyrOman wrote: |
Harbor Freight aluminum floor jack, $59, small enough and only about 40 pounds. I have one in each of my vehicles. |
Agree ^ Those HF jacks are pure garbage for everyday use, but are awesome for a tire change/emergency jack. Bring a piece of 4X4.
I figure the stock jack is enough, unless I'm worried something more involved may happen. |
DadaCheese Samba Member
Joined: April 15, 2008 Posts: 837 Location: Richmond, CA
Posted: Thu Apr 28, 2016 3:06 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
When my stock jack gave up the ghost, I bought one of these newer scissors-style jacks to carry in my Westfalia:
237-011-031 Bus Scissors Jack - Type 2 - OEM
That was six years ago, and I have been fortunate to never use it.
When/if I am at home and doing brake/wheel work, I block my wheels, and then use a floor jack an axle at a time, or put the whole bus up on jack stands if I'm going to be at it for awhile. _________________ ----------------------------------------------------------
Dada as in dadaism.
Cheese as in the stuff I love to eat. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Apr 28, 2016 6:44 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
... I keep a Wal Mart floor jack in my Ford Van, one in my 1960 single cab and one in my SO33... have a bottle jack in the '54 and '55 bugs... don't kike the stock VW jacks... _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Apr 28, 2016 6:52 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
Stock jack- all the way. Besides, Volksbaggin is now making really cool bags using TMI material for these things. She does not make one that improves the storage of your HF and walmart jacks. _________________
EverettB wrote: |
FU#5 |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Fri Apr 29, 2016 7:01 pm Post subject: Re: Best Jack for Changing a Flat Tire? |
Bruce Amacker wrote: |
I carry a scissor jack, I wouldn't trust a cheap hydraulic of any type to work. It's stored, neglected and rusted in your bus, gets air in it, then it won't work when you need it. Mechanical all the way in a rarely used application like that. |
I like this argument for some kind of mechanical jack over hydraulic in this application.
Looks like I'll be looking for some sort of scissors jack or stock jack solution. _________________ '64 standard microbus
Fredrok Samba Member
Joined: July 06, 2014 Posts: 227 Location: Under the evergreens. CO
Posted: Sat Apr 30, 2016 7:51 am Post subject: Re: Best Jack for Changing a Flat Tire? |
DadaCheese wrote: |
When/if I am at home and doing brake/wheel work, I block my wheels, and then use a floor jack an axle at a time, or put the whole bus up on jack stands if I'm going to be at it for awhile. |
^^ This all the way. For home maintenance, the $15 jack pad mentioned above with a standard floor jack is worth every damn penny. |
fotoroadie Samba Member
Joined: May 07, 2013 Posts: 180 Location: Manitowoc, WI
Posted: Wed Jul 19, 2017 8:29 am Post subject: Re: Best Jack for Changing a Flat Tire? |
My jack point failed over the weekend. Then out of luck, jack wedged in broken jack point. Had to be rescued.
So off to the salvage yard & found what appears to be a great option. From a somewhat recent Chevy Suburban. $25.00
It fits in the cavity under the seat & lift height is 17" more with wood block.
Lifts perfectly under torsion tubes front & rear.
srfndoc Samba Member
Posted: Wed Jul 19, 2017 9:11 am Post subject: Re: Best Jack for Changing a Flat Tire? |
Scissor jack all the way. Easy to store and works every time. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
