project_therapy Samba Member
Joined: September 10, 2006 Posts: 163 Location: san marcos ca
Posted: Mon May 02, 2016 4:09 pm Post subject: Early 55 tranny question? |
Any difference on early 55(April) tranny shock mounts. Straight or curved?
Just spoke with the Rancho guys and they said there are two styles.
Thanks |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed May 04, 2016 6:24 pm Post subject: Re: Early 55 tranny question? |
... tell ya what I do, to understand something... Google, Bughaus.com. Once there, click on "Bug", then "transmission"... saw 2 early-listings there - 1946 to 9/1952 (KDF dash split) part number 211 301 297 and a picture... ... and 10/1952 (start at Zwitter) to 1959 211 301 265A and a picture.
Bughaus is 99% right-on... I trust them whole heartedly. Based in this info, there is only one application. Then, I usually order it.
Good luck. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
EVfun Samba Member
Posted: Thu May 05, 2016 5:28 am Post subject: Re: Early 55 tranny question? |
I believe the angled (curved arm) shock mounts started in 1960. The axle tube shock mount should match the body mount, strait to strait and angled to angled. There are not a lot of Bugs I see with the angled mount and no cast in bump stop. I have an unloved 1960 Bug splitcase box in my garage and its tubes have the angled mounts. _________________
Wildthings wrote: |
Posted: Thu May 05, 2016 10:49 am Post subject: Re: Early 55 tranny question? |
... man, did I read that wrong... sorry.
There was only one rear shock offered in 1955. In fact the shock for 10/52 with the intro of the Zwitter was the same in the rear... part number 113 513 031... looks strait to me. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Thu May 05, 2016 1:42 pm Post subject: Re: Early 55 tranny question? |
I believe knaggy is asking about the bearing housing which is a cast piece that includes the lower shock absorber mount.
I have straight ones on my 57, but that was a choice I made when I had my current split case transaxle built. My choice was based mostly on my recollection of what was in there 40 years ago before I had switched to a full syncro.
I think EVfun is close to the right answer with 1960 or perhaps 1961 with the full syncro. |
EVfun Samba Member
Posted: Thu May 05, 2016 2:14 pm Post subject: Re: Early 55 tranny question? |
My '57 Bug has strait shock mounts on the frame but angled shock mounts on the bottom because it is running a 1962 transaxle. You can mix the two types.
He Snort, I see you are in the Seattle area. Where did you get your original type transaxle built? After 55 years my 2nd gear syncro is a bit worn. The previous owner had serviced the box so the oil was very clean, so I pumped a quart out and added a quart of MTL. It works great when warm, but can still "grunk" a bit going into 2nd when cold if I shift too fast. I am am seriously considering back to stock as I still have the original engine and brakes. I miss the 1st gear whine my first Bug had. _________________
Wildthings wrote: |
Snort Samba Member
Posted: Thu May 05, 2016 2:41 pm Post subject: Re: Early 55 tranny question? |
^^^ I worked with Gary at Gary's Transaxles in Kent. He's a one man operation with an obsession. I saw him a few months ago and he had some good things to say about the availability of some new parts for split case that were not available previously so this might be a good time for you to look into it. Call him and ask to stop by for a chat, he's very open to working with people that have specific needs and you'll enjoy the time spent with him.
edit: I feel your first gear noise pain, once you've driven a straight cut first gear, it sticks with you and the full syncro helical cut gears leave you wanting. |
Posted: Fri May 06, 2016 7:02 am Post subject: Re: Early 55 tranny question? |
Hi thanks for the replays, got the info needed, seems like pre may tranyys had the straight cast shape...thanks again! |
