Steering box position-narrowed beam
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu May 05, 2016 6:36 pm    Post subject: Steering box position-narrowed beam Reply with quote
Anyone know how far over left or right the box needs to be on a narrowed 3.5" axle? It obviously won't fit between the notches anymore. I could grind one of them down. Also how does it need to be clocked? The angle look correct, or should I just wait to ajust it all once the body is back on? Thx
1963 Ragtop Bug
Miklo
¡Chale!
Miklo is offline
PostPosted: Thu May 05, 2016 7:47 pm    Post subject: Re: Steering box position-narrowed beam Reply with quote
The steering box should not be moved in either direction.
The steering shaft needs to be exactly straight going through and exiting the steering tube.
The steering box is tilted to far forward on the beam. That is why the pitman arm is hitting.
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
samstheman
samstheman is offline
PostPosted: Thu May 05, 2016 8:14 pm    Post subject: Re: Steering box position-narrowed beam Reply with quote
You need to move the locators over the amount you narrowed beam on that side of centerline if you narrowed 4in u need to move locators over 2in towards wheel and weld them back in to locate steering box.
EMPIImp69
PostPosted: Fri May 06, 2016 5:32 am    Post subject: Re: Steering box position-narrowed beam Reply with quote
Ok thanks for the info guys
1963 Ragtop Bug
