crazy horse Samba Member
Posted: Mon May 09, 2016 12:13 pm Post subject: WW safari window disengager types help please |
hi guys,
i am looking for some WW safari window disengagers....are there different types..i.e external or internal type...
many thanks |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
EverettB Administrator
Joined: April 11, 2000 Posts: 69826 Location: Phoenix Metro
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Feb 07, 2019 9:38 am Post subject: Re: WW safari window disengager types help please |
easy e wrote: |
55-64 came with internal.
65-67 had external.
If you need the early style... good luck getting reproduction ones to engage/disengage. Original are far superior, and very hard to find.
There's an early complete set in the UK for sale right now for 1500 GBP... expensive... but probably worth it in the end.
If you need the late style... disengagers are simple.
It will be worth reading these three threads:
Safaris Discussion thread
Safaris - installing and threaded plate?
Best one-eyed duck repro
e |
Is there a fix for the aftermarket ones or? just curious what the problem is. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Malokin Martin Samba Member
Posted: Thu Feb 07, 2019 10:27 am Post subject: Re: WW safari window disengager types help please |
Wiper pivots on safaris are strictly for looks anyway. None of them do anything but smear the rain around. |
easy e Samba Member
Posted: Thu Feb 07, 2019 11:42 am Post subject: Re: WW safari window disengager types help please |
crofty wrote: |
easy e wrote: |
65-67 had external.
e |
Is there a fix for the aftermarket ones or? just curious what the problem is. |
Loose tolerances let moving pieces get askew & bind.
There's a spot welded tab limiting vertical motion of the ball pivot piece... it's too far away from the bottom thick piece (too much slop).
Need to drill spot welds + move tab down + re-weld tab (to remove slop) OR create a spacer/shim to affix to the bottom surface of the tab (to take up slop).
See this post & the four above it:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7136569#7136569
Malokin Martin wrote: |
Wiper pivots on safaris are strictly for function. None of them come in contact with rain (they're inside the bus). Maybe you are thinking of wiper blades? _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Thu Feb 07, 2019 5:25 pm Post subject: Re: WW safari window disengager types help please |
easy e wrote: |
Wiper pivots on safaris are strictly for function. None of them come in contact with rain (they're inside the bus). Maybe you are thinking of wiper blades? |
You mean like this piece that’s outside the bus?
If so, then the they work as good in the rain as removing the entire arm. |
easy e Samba Member
Posted: Thu Feb 07, 2019 6:38 pm Post subject: Re: WW safari window disengager types help please |
Crofty was inquiring about the early (inside the bus) wiper pivots.
I didn’t even have the late (external) disingagers, on my mind.
The late style appears to be pushed further away from the glass.
Assuming your blades are in good order...
Maybe bend the arm towards the glass... and the added pressure will make them more effective? _________________ aka: Evan
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Fri Feb 08, 2019 8:07 am Post subject: Re: WW safari window disengager types help please |
There was someone back in the 90's that was making the early style disengagers, and they were awesome; I wish I'd bought a couple extra sets.
What's sad is to make these _right_ wouldn't have cost much more than to make them wrong. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Fri Feb 08, 2019 8:23 am Post subject: Re: WW safari window disengager types help please |
thom wrote: |
What's sad is to make these _right_ wouldn't have cost much more than to make them wrong. |
Yeah! I bought a pair of those back in the 90's when they first were reproduced (someone reputable out on the left coast as I remember). I've never used them, still have 'em somewhere and might use 'em someday on one of my Buses. They look beautifully machined. I'll have to look for and dig them out. If I find 'em, I'll post a few photos.
And in a related topic, Susan Crandall Dolvin and I and a few other VW nutjobs were rootin' through the dark, dusty part shelves of the Vintage VW parts department in the VW Automuseum near the Wolfsburg factory grounds way back in the mid 1990's when I hear her holler out from a few dark aisles away. I run over and she had discovered 6 or 7 NOS pairs of the later '65-'67 Safari wiper disconnects in a dingy drawer. She bought them all and in the car heading back to our hotel I bought a pair from her. Man, we got a lot of cool, old NOS VW parts for pretty cheap out of that VW Parts department back in the '90's! REALLY good times!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
thom Samba Member
Posted: Tue Mar 19, 2019 6:56 am Post subject: Re: WW safari window disengager types help please |
I was looking for something this weekend and found a set of safari disconnects of unknown origin and unknown application. They are very nice, I'm sure someone would try to pawn them off as NOS. They are a lot longer than the other disconnects I have.
For comparison, I dragged out the other sets I have and took some pix for comparison. The goldish ones on the left are CIP1, the long once in the center is the mystery part, and the one on the right is of unknown provenance.
Notice how the CIP1 part doesn't even have the same thread, so they have to give you some crappy little nut to hold them on. Also notice how the inner support bracket is much larger than the shaft it's supposed to be containing.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Tue Mar 19, 2019 9:54 am Post subject: Re: WW safari window disengager types help please |
That one in the middle could be a Barndoor disengager. It has the typical spotweld divots on the backside. The shaft and threaded sleeve are longer than a later bus. But, so are BD nonsafari pivots. Someone with a BD safari equipped bus must know if that is correct for a BD. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
easy e Samba Member
Posted: Tue Mar 19, 2019 11:00 am Post subject: Re: WW safari window disengager types help please |
Nice comparative pics thom.
The shitty CIP one made out of lamp parts isn't even worth talking about.
cru62 has the BD one nailed... original goodness. You did good finding those! AFAIK... no one reproduces the BD style.
The other 55-64 one is repro... maybe one of the old nicer repros that Thom and Bill were referring to.
You can tell it's not original because:
Doesn't have the divots on the reverse, as cru62 noted.
The center of the ball is higher above the flat swiveling plate (than the BD one... they should be same height).
The swiveling plate is thinner than the BD one.
The ball is attached to the swiveling plate differently than the BD one.
The u-shaped frame has a bowed back and horizontal parts of the frame aren't horizontal/parallel, like the BD one.
Just curious... does it have downward pointing pin in the channel of the bigger round piece... that pokes into the swiveling plate?
Can see the pin/little receiving hole in the pic below...
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 824 Location: North Carolina
Posted: Tue Mar 19, 2019 6:29 pm Post subject: Re: WW safari window disengager types help please |
I think that center one may be for early post BD, maybe 55-58 or so? If you poke around I think standard wiper shafts for earlier post BD buses had a slightly longer pin/threaded shaft. Barndoor is definitely different in size. Here’s a photo I borrowed , BD being the 2 center ones.
It does look original to me though. Man, that CIP one is hideous
_________________ www.thebustransfer.com
Whaaaaat? |
thom Samba Member
Posted: Wed Mar 20, 2019 6:07 am Post subject: Re: WW safari window disengager types help please |
The "barndoor" one in my collection does not have the pin _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Clara Samba Member
Posted: Wed Mar 20, 2019 7:39 am Post subject: Re: WW safari window disengager types help please |
You live on the dry side. . There wipers are decorative. Lol
As someone who lived on the wet side daily driving splitties you do need good condition and good quality blades to make the wipers work well, as with any car.
My red 61 is an og safari bus, and the wipers work fine. One pivot was og to the bus when I got it, afaik. It has a wee bit of slop. The other I bought NOS about 50k miles ago, it is super nice still. That bus has a lot of rainy miles on. Including to Havasu this year.
I saw some repros that brand new that had about a third of the travel area as slop. I would find that very annoying.
Originals are probably hard to find. I found a pair once on the site listed as ‘wiper parts’ in the general section. That was a fluke.
Sorry my advice isnt easy like here’s a great repro for $100 the pair. |
EmpiGT Samba Member
Posted: Wed Mar 20, 2019 7:51 am Post subject: Re: WW safari window disengager types help please |
BeaterBarndoor wrote: |
Not positive but the 2 in the center of that picture, look no longer than the one posted earlier? Maybe even shorter? |
Posted: Wed Mar 20, 2019 7:52 am Post subject: Re: WW safari window disengager types help please |
Tried installing a set of the CIP ones yesterday. the ball that connects the linkage rod is a bit too big too. Just thought i'd add some actual hands on experience to this topic. _________________ Your Vanagon sucks, Stop waving at me.
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Tue May 26, 2020 8:02 pm Post subject: Re: WW safari window disengager types help please |
I was holding out to buy some from CIP-1 because they were cheaper (but always out of stock) .After reading this thread I'm rethinking that move.Does anyone have any fead back on the ones that Wolfgang sells ,(the older internal ones) ? _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Dewayne Samba Member
Joined: October 05, 2003 Posts: 332 Location: Oklahoma
Posted: Wed May 27, 2020 7:20 am Post subject: Re: WW safari window disengager types help please |
I had a set from Wolfgang on my DC and used them for years. Once in a while they would stick in the engaged position, probably from not being disengaged for a long period. Otherwise, no slop, no problem... _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
