Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Tue May 10, 2016 6:36 am Post subject: This fuel pump relay |
Broke a contact off of the fuel pump relay I had on the 72 while removing it and bought this one but the contacts are labeled different than the old one. The contact numbers are 85,86,87, 870 and 30.
Can someone enlighten me as to the connections?
Please ignore blood and filth _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Tue May 10, 2016 6:45 am Post subject: Re: This fuel pump relay |
I'm willing to bet its not 870, but a poorly molded "a". Should be no issues if its exactly like the one it replaces. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue May 10, 2016 7:07 am Post subject: Re: This fuel pump relay |
Lil' Lulu wrote: |
Please ignore blood and filth |
That's funny. I was just thinking how your fingers look like my fingers these days... _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Tue May 10, 2016 12:15 pm Post subject: Re: This fuel pump relay |
That's a generic SPDT relay. The normal 'fuel pump relay' has terminals 30, 87, 15, 31, and 31a. It connects to the ignition points signal and has circuitry that only closes the relay contacts when the engine is running.
Wiring:
30 - +12 from battery
87 - power to fuel pump
15 - +12 from coil (term 15)
31 - ground
31a - points signal from coil (term 1) _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
SGKent Samba Member
Posted: Tue May 10, 2016 12:27 pm Post subject: Re: This fuel pump relay |
both your bays are carbed which means they were mechanical fuel pumps originally. If you have a relay on either of these carbed buses it is aftermarket. You need to look carefully how it is wired to be sure the last person didn't do something non-standard. Electricity gives very little warning when it cooks things. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue May 10, 2016 3:31 pm Post subject: Re: This fuel pump relay |
So Telford, are you saying this relay is not going to work? The old relay I put on myself wired it according to your instructions. Could not find one like it.
Hope to find out how to wire this one. Currently wired straight from coil to fuel pump. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 10, 2016 3:51 pm Post subject: Re: This fuel pump relay |
That relay will lighten the load on the ignition switch, but the fuel pump will still rune whenever the key is on, a real fuel pump relay is triggered by either points pulses, the charge light, oil light or airflow if FI.
Coil 15 to 85 on relay
ground 86
battery to 30 (fused)
pump to 87 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Tue May 10, 2016 7:30 pm Post subject: Fuel pump relay wiring |
To link to this thread
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=8076149#8076149]Fuel pump relay wiring[/url] |
Ford inertia switch wiring diagram
https://www.google.com/webhp?sourceid=chrome-insta...%20diagram
321 906 059 C Electric fuel Safety relay
Tcash
jtauxe Samba Member
Posted: Tue May 10, 2016 7:42 pm Post subject: Re: This fuel pump relay |
I believe this is what you are looking for...
http://www.busdepot.com/321906059c _________________ John
http://vw.tauxe.net
Posted: Tue May 10, 2016 9:25 pm Post subject: Re: This fuel pump relay |
Preferred relay coil connections (compatible with diode-protected relay coils):
Posted: Tue May 10, 2016 9:29 pm Post subject: Re: This fuel pump relay |
Lil' Lulu wrote: |
Hope to find out how to wire this one. Currently wired straight from coil to fuel pump. |
You can make it work - use one of Tcash's two schematics above. It will work differently than your current relay, however. _________________ '71 panel, now with FI
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Wed May 11, 2016 12:26 pm Post subject: Re: This fuel pump relay |
I believe that was what I was looking for ages ago when the only option at that time was the rabbit relay from a junkyard.
In the end I went with two relays. Not very complicated and still runs fine till this day. _________________ ---------
Rubber Duck
1974 Westfalia |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3837 Location: San Jose, CA
Posted: Wed Mar 14, 2018 9:42 pm Post subject: Re: This fuel pump relay |
telford dorr wrote: |
This diagram: is the yellow 12V from the coil the "hot" or the ignition (pulsed)/tach signal? As illustrated here, I'm thinking it's the "hot" from switched ignition. But if this is true, doesn't this configuration represent the undesirable condition of leaving a fuel pump energized in a crash? Other possibility (just thinking out loud), this is largely for the standard "Bosch type" relay for general purposes, and not desirable for a fuel pump installation.
I'm trying to edjumucate myself for a couple of installations upcoming. I'm pretty much settled on the Revolution FP controller, with its 3-second prime function, and pulsed tach signal energization, but an understanding of this one is ideal as well. |
Posted: Thu Mar 15, 2018 12:24 am Post subject: Re: This fuel pump relay |
Busstom wrote: |
This diagram: is the yellow 12V from the coil the "hot" or the ignition (pulsed)/tach signal? As illustrated here, I'm thinking it's the "hot" from switched ignition. But if this is true, doesn't this configuration represent the undesirable condition of leaving a fuel pump energized in a crash? |
Correct. To get some crash protection, yellow would need to connect to the blue wire at the alternator or alternator regulator. When the alternator is producing output, the relay will energize. Downside: if the charging system fails, the engine will quit from lack of fuel.
Looks similar to the Rabbit FP controller, with add'l features. Probably a better choice than a plain relay. _________________ '71 panel, now with FI
Posted: Thu Mar 15, 2018 7:05 am Post subject: Re: This fuel pump relay |
Busstom wrote: |
Looks similar to the Rabbit FP controller, with add'l features. Probably a better choice than a plain relay. |
Thanks for clarifying. I can't wait to get my hands on some of these gadgets and put them to work. |
