childofthewind Samba Member
Joined: October 19, 2010 Posts: 763 Location: Eastern Sierra
Posted: Tue May 10, 2016 12:49 pm Post subject: Are these "normal" sounds for a rebuilt manual transmission? |
Hey, everyone. Hope spring is treating you well.
I've got my new/rebuilt transmission in and wanted to run a couple noises past you. I'll try to explain the best I can:
* When I downshift into second from either neutral or any gear, there is sort of this zipping sound. It doesn't happen with any other gears. It only happens when shifting into second when the RPMs are higher than say when I'm shifting from first into second. Is this synchro related? According to the person who rebuilt the tranny, there are 4 new synchros in it.
* Second sound is a whirring in second gear, mostly from 2400 rpm up until I shift into third. I remember my old transmission making a similar sound in second gear and so I'm not sure if this is how ALL 4 speed transmissions for Vanagons sound in second gear. I don't remember my old one being as loud although I think the sound improved when a shop topped my tranny fluid.
Here is what the rebuilder included in the transmission (with a different core than mine):
-4 synchros / 2 diff bearing seals
-1 ms bearing
-1 pinion bearing
-1 lower pinion bearing
-2 needle bearings
-3/4 slider/hub updated
-6 dog teeth retainers
Just wondering if I should be at all concerned with above noises.
Thanks! _________________ 1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville |
Terry Kay Banned
Posted: Tue May 10, 2016 12:54 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
No one can decypher accurately what's happening without being there, experiencing the problem.
Post a sound byte here, or take the van back to the outfit who did the work.
The second selection being the best move you can make , Right Now. _________________ T.K. |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue May 10, 2016 1:13 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
No idea what to tell you about the first sound you describe. However, second gear does normally have a whine, atleast every van ive owned had the same whine in second gear, including brand new rebuilt transmission units. Hope that helps |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue May 10, 2016 1:42 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
I can't comment on your described noise, but I'll comment on what you've said below.
Only downshift into 2nd when your RPMs in 3rd dictate that you downshift to avoid lugging the engine. You shouldn't downshift into 2nd gear to slow the car down .. unless you have no problem with needless transaxle wear. (Brake components are less expensive.)
The synchros themselves don't make any noise.
childofthewind wrote: |
.. It only happens when shifting into second when the RPMs are higher than say when I'm shifting from first into second. Is this synchro related? ... |
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Tue May 10, 2016 2:15 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
gears wrote: |
Thanks for this. I do in fact downshift to slow the vehicle down. It's nothing dramatic -- I'm not going super fast when doing it but I'm not one to just put it into neutral and/or ride the clutch and brake until I stop. Old old habit from when my dad first taught me to drive stick all those years ago.. (so it's HIS fault! ha.)
It's just that I don't remember hearing the sound at all with my last tranny and I drove the same way.
I'm not wanting to pester the builder as I've already had to go back for other stuff (not related to these sounds) and wanted to ask the community to get a general sense, first.
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Tue May 10, 2016 2:25 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
Thanks for this. I do in fact downshift to slow the vehicle down. It's nothing dramatic -- I'm not going super fast when doing it but I'm not one to just put it into neutral and/or ride the clutch and brake until I stop. |
Regardless of your training, its simply not worth the wear in most every case... Double the number of clutch engagements etc. Decelerating in gear or using the engine drag to reduce braking down grades is fine. But actively downshifting during braking is simply not desirable in most any case except racing conditions.
I second the suggestion for an audio clip or video if possible. It's nearly impossible to accurately describe a noise over text. What you may think is transmission noise could be something else in the driveline. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Posted: Tue May 10, 2016 2:28 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
I tried hard to capture the sound via my phone's recorder. Couldn't get it. Here's an older thread that sort of describes what I'm talking about -- the sound when I'm downshifting into second:
http://www.thesamba.com/vw/forum/viewtopic.php?t=440625&start=0 _________________ 1987.5 wolfsburg hardtop; 2.1
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue May 10, 2016 2:30 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
...I do in fact downshift to slow the vehicle down... |
In my opinion this is neither necessary nor wise. Engine braking can be effectively accomplished by allowing the vehicle to slow in whatever gear you were driving in, selecting something lower puts additional stress on the driveline w/o any real benefit.
Now if you're coming into a corner where you will want to accelerate in, say 2nd, coming out, then a downshift going in makes sense. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Terry Kay Banned
Posted: Tue May 10, 2016 7:02 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
Is a vanagon the only manual trans vehicle on the planet you shouldn't use the benifits of engine braking by downshifting?
Never heard of such a crazy claim to fame.
I downshift my 51 Crosley coming up to a light for cripes sake.
The VW engineers really came up with a cheesy gearbox, that's for sure if you can't use it -- normally. _________________ T.K.
zak99B5 Samba Member
Joined: December 21, 2014 Posts: 471 Location: Albany, NY
Posted: Tue May 10, 2016 7:16 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
Downshifting coming to a stop is unnecessary and causes unneeded wear on the clutch (as well as tranny).
In any manual car.
Let's say you're driving along in town in third gear. You see a stop light ahead. Just leave it in third, let off the gas to gradually slow down (engine braking) and then apply the brakes as you approach the stop light.
As the speed of the bus slows, the rpms of the motor will also slow. When they get to about 1000 or so, just depress the clutch, shift ino neutral, let off the clutch pedal, and continue to stop the van with the brakes.
When the light turns green, depress the clutch, select first, and off you go.
This way you take advantage of engine braking without burning up the clutch to do so. _________________ 1991 Tintop GL Manual tranny, EJ22 |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Tue May 10, 2016 7:30 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
Brakes are cheap, especially if you use cheap pads that wear instead of rotors. |
Terry Kay Banned
Posted: Tue May 10, 2016 8:30 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
You don't need a clutch to downshift, or upshift for that matter, you only need it to come to or take off from a stop.
Semi's, no syncro's in a 9,10,13,16,18, speed gear boxes you upshift & downshift via rpms.
Only use the clutch to stop & start.
Gotta be a pretty weak drivetrain to not be able to use the mechanical advantage of usng it to slow down, or might be as simple as it's not knowing how to use it properly.
Lose RPM, an automatic trans will downshift to gain this built in advantage.
So you guys don't downshift going around a street corner for fear of smoking the clutch or transaxle?
Praise the Lord Baby Jesus, I'm really happy I've only owned automatics.
They do downshift coming to a stop or going around a corner.
No Charmin, Scott, cheesy transaxles for my driving style. _________________ T.K. |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Tue May 10, 2016 9:24 pm Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
The whirring noise you described is normal. Mine did it for a while and then went away. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Fri May 13, 2016 7:33 am Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
Well, thanks folks for the instructions on how to drive a stick shift. Being a woman, I probably have no idea how to do so.
I think those folks would go on about the best way to drive a stick if you were a guy too. They are just arguing among themselves without even addressing the question you posed.
Back on topic....
If your rebuilder said to drive it then I guess go ahead and do so, maybe it will go away. I do not think that the noise is 'normal' but I assume that the rebuilder is giving some kind of warranty and it is on him if it turns out bad? _________________ Dave O
The Western Syncro build
wyldryce Samba Member
Joined: August 14, 2011 Posts: 83 Location: Annapolis, MD
Posted: Fri May 13, 2016 7:36 am Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
I get that some of the posts come off as "mansplaining", but you did start a post talking about new tranny noises and soliciting information/advice . I think it's fair to say that you current driving style isn't causing the new noises your hearing; that is likely a faulty synchro or other other assembly issue, but downshifting into second without rev matching (causing the synchros to have the do the speed matching, is going to work them a lot harder than the methods of driving described by others. The fact of the matter is, by modern standards, these are a pretty fragile gearbox. That's why mine is being replaced by a Suby 5mt (that, and the desire for more appropriate gearing/ratios). TK is essentially right...one shouldn't have to treat a gearbox with kid gloves, but this tranny has a long and established reputation for proving that wrong. [/i] |
Posted: Fri May 13, 2016 8:43 am Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
One tip. If your shift linkage is a bit out of alignment, or its rubbing in the box/gate under the floor. Noises/vibrations can be transmitted to the handle.
When you are hearing the noise, try wiggling/moving the shifter a little bit. If the noise goes away, its likely that it is vibrations/rubbing in the shift linkage. The shift linkage turns the vibration into audible noise. Just a thought. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Fri May 13, 2016 9:54 am Post subject: Re: Are these "normal" sounds for a rebuilt manual transmission? |
gears wrote: |
Thanks! |
You rock for simply driving a stick, let alone knowing how to do it well. All six of my daughters knew they had to learn stick in winter before they got the keys...which was simple as Mom had the only slush box and it went to work..
Two of them are even brave enough to tackle the crashbox.... _________________ .ssS! |
