iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
Posted: Tue May 10, 2016 1:35 pm Post subject: Fuel tank for diesel conversion? |
Have a diesel converted Vanagon (AAZ), revamping the fuel system and trying to figure out what the stock diesel Vanagon had fuel tank to injection pump?
This was a gas van, and had a new tank put in (with 7mm feed), which goes to diesel filter in the engine bay into a 12mm banjo, then it goes to 7mm banjo out of filter to injection pump which is 7mm.
So did the stock vanagon have a 7 or 12mm outlet fuel tank? Where and how did it go to the filter housing from there?
Cheers! _________________ 1986 Weekender "Birch" |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
Posted: Tue May 10, 2016 8:04 pm Post subject: Re: Fuel tank for diesel conversion? |
7mm on the stock van. on early vans the square pre-filter was used as a coupler into a larger inlet fuel pump. _________________ Learn to ride. Ride to learn. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue May 10, 2016 8:07 pm Post subject: Re: Fuel tank for diesel conversion? |
On gasoline engines it was 7mm with the square pre filter on early models and 12mm with no pre filter on late models, not sure if it was different for diesel _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Tue May 10, 2016 9:50 pm Post subject: Re: Fuel tank for diesel conversion? |
The diesel Vanagons had no pre-filters; the supply line ran directly from the tank to the large fuel filter mounted in the engine compartment, as shown in Bentley Page 20.10.
To be precise, there is a short (~24") section of black hose (7mm / ~.25" ID) leading from the tank outlet to a much longer section of semi-rigid plastic tubing (7mm / ~.25" OD) which runs all the way back and connects directly to the fuel filter.
The supply line from the filter to the injection pump is a similarly semi-rigid clear plastic hose but is (7mm / ~.25" ID). If original, this hose is likely nearly opaque after years of use so it is wise to replace it with something new and clear, in order to observe any air bubbles in the supply line during operation.
_________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
Posted: Tue May 10, 2016 10:23 pm Post subject: Re: Fuel tank for diesel conversion? |
That's exactly what I was looking for!
Thanks much. _________________ 1986 Weekender "Birch" |
MostynF Samba Member
Joined: November 14, 2019 Posts: 1 Location: California
Posted: Fri Feb 12, 2021 10:08 pm Post subject: Re: Fuel tank for diesel conversion? |
Thanks for the data about 5 years since you posted it. I’m installing an AAZ in a WBX and I need to know a lot of stuff. |
