Starbucket Samba Member
Posted: Wed May 11, 2016 3:55 pm Post subject: 4 wire flasher Hot wire |
Does anyone know which is the "Hot Wire" to a 4 wire flasher unit in a 70 Ghia, 31, KBL, 49, or 49a? And is it Hot with the key off or only when it's on. Thanks for any help. |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Wed May 11, 2016 7:47 pm Post subject: Re: 4 wire flasher Hot wire |
http://www.thesamba.com/vw/archives/info/wiring/kg_8_69_usa.jpg
Howdy..The kind folks here at the Samba have been nice to provide copious amounts of wiring diagrams here in the "Technical section"
Both the 49s lead to the Emergency flasher (which is constant hot, )Blue and white wires, KBL is dash and the brown 31 leads to wiper motor, switch and turn signals etc. But from my understanding, anything with the 2.5 on the trace is something that operates without the key, headlights etc.. so the white 49 wire would be the constant hot, so it can operate the flashers without the key _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
wrackman Samba Member
Joined: December 29, 2015 Posts: 8 Location: whangarei NZ
Posted: Thu May 12, 2016 1:47 am Post subject: Re: 4 wire flasher Hot wire |
Hi there
49 is ignition & then batt when emergency switch is pulled out
49a is feed out to indictor switch
31 is ground (earth)
KBL is dash warning light
hope this helps |
Posted: Thu May 12, 2016 6:27 am Post subject: Re: 4 wire flasher Hot wire |
Thanks all that will help me find where I'm not getting power to the flasher. |
