RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Fri May 13, 2016 10:39 pm Post subject: Securing Plate-Torsion Arm 311 401 205 A...What does it do? |
What is the function of this torsion arm securing plate? Is it a bump stop of sorts for the lower torsion arm? After lowering my '66 Notch I reinstalled the plates. I just raised the car one inner spline and once again looked at T3 FAQ Sticky on Lowering/Raising and noticed that the plates were not on the car in that tutorial. See link below.
http://www.thesamba.com/vw/forum/viewtopic.php?t=188457
Are these plates necessary? Thank you... _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
scranscran Samba Member
Posted: Sat May 14, 2016 7:51 am Post subject: Re: Securing Plate-Torsion Arm 311 401 205 A...What does it do? |
I hate to respond to your question with a question, but I am in the process of restoring my 66 beam, its off the car, stripped down, and painted. I did not remove the lower torsion arms or plates, but I now need to do so to replace the seals (total overhaul of the front end) With them beam being off the car, and no pressure applied, when I take the plates off will the torsion bars then swing forward with force? Really scared about this step in general, scared to mess up the geometry, etc.. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3695 Location: San Jose, CA
Posted: Sat May 14, 2016 11:29 am Post subject: Re: Securing Plate-Torsion Arm 311 401 205 A...What does it do? |
RHD Notch wrote: |
Are these plates necessary? Thank you... |
It's a safety lock tab to keep the lower arm from sliding out if the bolt on the opposite side works itself out. The arm would still be connected to the spindle so it's not going to totally come out, but I wouldn't want to be driving on the freeway if this did happen. The beam in the tutorial is earlier or a replacement beam that has the tab built into the beam. You can see it if you look really close. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Sat May 14, 2016 11:31 am Post subject: Re: Securing Plate-Torsion Arm 311 401 205 A...What does it do? |
scranscran wrote: |
No. I would take note with an angle finder before you pull the lower arm out, that way you can put it back into the same splines when you put it back together. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
Posted: Sat May 14, 2016 2:55 pm Post subject: Re: Securing Plate-Torsion Arm 311 401 205 A...What does it do? |
Thank you squaretobehip! _________________
Lind wrote: |
campingbox wrote: |
Posted: Sat May 14, 2016 3:05 pm Post subject: Re: Securing Plate-Torsion Arm 311 401 205 A...What does it do? |
Me too, thanks for the tip! |
