drj434343 Samba Member
Joined: January 31, 2016 Posts: 401 Location: Portland, OR
Posted: Sat May 14, 2016 8:56 pm Post subject: GoWesty big brake kit requires late model spindles? Crap... |
I was nearly through installing a GoWesty big brake kit on my 1983 Westy when I noticed some strange interference points on the lower ball joint stud and the spring coil itself hitting the front steering spindle. Wondering what was wrong, I went back to the GoWesty website and found at the very bottom of the fitment page they mention early Vanagons need 86-91 front steering spindles to work with their big brake kit. Crap, I missed that.
Furthermore, the spindles are apparently different between power and manual steering. I have manual steering, which was more rare on late model vans.
So now I'm stuck with a mostly installed big brake kit but incorrect spindles. I can't find them new at any of the parts suppliers. Ebay and Samba classifieds are empty right now.
Does anyone know if I can modify my spindles to work? At the very least, it looks like I need to drill out my caliper holes, which are threaded. I have never seen a later spindle, so I don't know what else is different.
I can't return the big brake kit at this point, I've pressed the studs and bearings into my spindles. I need a way to move forward. Any other ideas? |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sat May 14, 2016 9:18 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Call GW. They have an extensive supply of used parts. If not...
WAY OUT SALVAGE: www.wayoutsalvage.com
AFFORDABLE GERMAN: 602.253.8889 (Arizona - All VW Models)
BW AUTO DISMANTLERS: 800.327.0888 (California - All VW Models)
RUSS' RECYCLING: 626.303.4366 (California - All VW Models)
FAST INC: 626-357-3361(California - All Watercooled VW Models)
SMALL CAR CONNECTION: 760.244.9811 (California - Aircooled, some Watercooled) _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
icolquhoun Samba Member
Posted: Sun May 15, 2016 4:58 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
if you have trouble finding late spindles, or want to maintain your steering geometry for non power steering, you can have your early spindles machined.
I just did this to my early spindles a few days ago to fit 312mm audi s4 brakes:
adapter machined to hold spindle:
spindle held in mill and indicated for parallelism
spindle machined to thickness
compared to non machined spindle:
spindle held on drillpress to drill out holes to proper size:
keep in mind, this would cost you more than finding 86-91 spindles unless your a machinist or have a very close friend who is |
Posted: Sun May 15, 2016 9:36 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Well, it looks like the only difference are those bolt hole ID's and the material thickness required to mount the different calipers. Trouble is, I don't know what thickness is required to get the GoWesty big brake calipers to align without a proper set in hand, or having someone carefully measure.
Thanks for the info! |
Michael4104 Samba Member
Joined: February 09, 2014 Posts: 340 Location: Livermore, Ca
Posted: Sun May 15, 2016 11:07 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
icolquhoun wrote: |
Nice write up.
What is the cut diameter and depth and what diameter is the hole drilled to?
Thanks _________________ 1990 Wolfsburg Carat with new poptop.
1985 Westy now sporting a 1995 Jetta ABA 2.0L. Sold |
pomfritz Samba Member
Joined: December 18, 2014 Posts: 477 Location: Folsom, CA
Posted: Sun May 15, 2016 12:32 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Different spindles for power and manual? Where did you find that info? I had seen the warning on the GW site and was planning on installing big brakes. I acquired some late model spindles but no idea what type of model it came from. I saw later that I need the caliper bolts too that ar elate model. BTW I have the 83 manual model too. _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
Posted: Sun May 15, 2016 1:12 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
I had a member on the Samba respond to my WTB ad to warn me that manual and power steering are different.
I know on my Volvos, those differences are manifested in how far forward the wheel bearing spindle is from the steering pivot. I'm assuming there's something like that on these as well, but I don't know about the specifics. |
insyncro Banned
Posted: Sun May 15, 2016 1:18 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Yes, they are different.
The best bet when buying late parts for the BBKs would be to buy the entire late front suspension.
Swap it all over, a huge improvement
I have done the swap many times.
Buying a late parts van really makes the job easier and a financial win when you part the un needed rest. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon May 16, 2016 3:17 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
So I've gone down the contact list and no one has 86-91 spindles from a manual steering Vanagon. Furthermore, several people told me they thought 86-91 Vanagons were pretty much non-existent in the US with manual steering.
So it looks like my only option is to machine my current spindles. Boring the bolt holes will be easy, but I don't know what thickness the flange needs to be on the spindle to get the caliper offset correct.
Does someone have this info, or can someone volunteer to measure the thickness of that flange on their late model spindles? |
GreenMachineVW Samba Member
Posted: Mon May 16, 2016 3:28 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
It took quite a while, but I successfully sourced a pair of late model, manual steering spindles. I had a Want To Buy advertisement up for a quite a while. Even the above posted insyncro replied (but when I offered under $500 a pair I never heard from him again ...).
So, if you have time, try a WTB ad, and be patient.
Last edited by GreenMachineVW on Mon May 16, 2016 5:22 pm; edited 1 time in total |
Posted: Mon May 16, 2016 4:01 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
If you can wait a day or so I can measure the spindles I have. I can also take pics big the measurement. _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
Posted: Mon May 16, 2016 4:53 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Yes, I can wait. I am hoping to pull my spindles back out this week and take them to a machinist friend this weekend.
If you could post your findings in this thread, I can help create a guide for those that want to machine their spindles. It sounds like there are a few others in the same boat I am in. |
levi Samba Member
Posted: Mon May 16, 2016 7:36 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Seems like it would be a whole bunch easier just to buy the spindles for power steering, fill the existing hole and drill a new one farther out on the arm of the spindle. There's plenty of room there.
The new hole wouldn't have to be absolutely precisely located as long as both spindles had the new holes drilled in the same place, it all has to be re-aligned anyways...
_________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Tue May 17, 2016 7:51 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
I'm being quoted $300-$500 for pairs of used power steering spindles. At this point, it looks like machining my own will be much cheaper. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue May 17, 2016 8:49 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Looking at the machined ears above, it appears the majority of the material was removed from the inner edge and it looks as though they stopped the machining when it was near flush with the outer edges. That surface is what will center the caliper on the brake disc. You might be able to make some measurements with the parts you have on hand to determine how much material will need to be removed.
The fixture for holding the spindle in the mill is a very nice tool. Don't enlarge your caliper holes until you have the spindle surface milled. They are using the original caliper bolt threads to "hold" it secure during machining. You might get away with a less elaborate fixture, but you will need to hold the spindle level, and secure. _________________ ☮️ |
Posted: Tue May 17, 2016 11:14 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Okay here are the pics and measurements from the spindles I have. They look to be the power steering type from a post 85 van. Not sure what exact model it was, the guy I got them from had removed them already.
Hope that helps, if you need any more measurements, let me know. I'll keep the part out for a little.
So I guess if I do the big brakes I could get the hole filled and redrilled further away to match the spindle I remove? _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
Posted: Tue May 17, 2016 11:46 am Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
To determine how much material should be removed from the early spindle, Pomfritz, if you could measure from the back plate mounting surface down to the machined ear where the caliper seats and then measure the same on the early spindle, subtract that measurement from the first measurement, and that should tell you how much material needs to be removed. That is directed at the original poster and to pomfritz.
As far as converting power spindle to manual spindles, I imagine the new tierod hole needs to be pretty equal on both spindles. If not, you will have one wheel turning more than the other. I think that is referred to as Ackerman angle.
Disclaimer, all of the above could be partially or completely wrong. _________________ ☮️ |
Posted: Tue May 17, 2016 12:27 pm Post subject: Re: GoWesty big brake kit requires late model spindles? Crap... |
Pomfritz, it looks like you took measurements only at the tie rod end hole on those spindles. If I machine my current manual steering spindles I won't need to touch those at all.
What I need is the thickness at the 2 caliper bolt holes. The power steering spindles are thinner at this location than manual steering versions, which is why I need to remove material from there.
I think we're almost there. Can you measure the thickness right at both of those bolt holes? |
