kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Mon May 16, 2016 8:23 am Post subject: Automatic Transmission Reverse Lights |
I know i've already been down this road on this forum but i'm still having difficulty with the reverse lights. I've tested the relay to the best of my knowledge with a test light by running it from the 50A connection to the RF connection and no lights on the test light, but it is going into reverse when selected. Is there a fuse of some kind somewhere that I have looked over? I'm using this wiring guide. http://www.thesamba.com/vw/archives/info/wiring/baybus_76_supplement.jpg _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon May 16, 2016 9:45 am Post subject: Re: Automatic Transmission Reverse Lights |
First verify that fuse S12 is good. If good. Pull the cover off the shifter and check for power in (15) and out (RF) of the switch. |
Posted: Mon May 16, 2016 9:53 am Post subject: Re: Automatic Transmission Reverse Lights |
I've connected a test light across those pins and it did not light up the lights. I'm going to check them a bit more this evening. Looking at the fuse my brake lights and horn work fine and I believe they are on the same fuse. _________________ 1976 Type II Westy P22
Posted: Mon May 16, 2016 10:46 am Post subject: Re: Automatic Transmission Reverse Lights |
looking at that wiring diagram does it jump from fuse 12 to fuse 11? _________________ 1976 Type II Westy P22
Tcash Samba Member
