Front axle beam Grease fittings nipples T2
Page: Previous  1, 2
Wildthings
Wildthings is online now
PostPosted: Thu Jul 12, 2018 9:38 pm    Post subject: Re: Front axle beam Grease fittings nipples T2 Reply with quote
You don't particularly need a grease zerk. You can just drill a smallish hole, say 5/64" and use a needle fitting to lube the joint. Then close the hole off with a good smear of silicone or JB Weld. Be sure the clean the top of the joint well so that the silicone sticks. It is not like you need to relubricate the joints more than once a decade or so.
Page: Previous  1, 2
Page 2 of 2
