ToughBug Samba Member
Joined: July 22, 2014 Posts: 354 Location: Carlisle, Pennsylvania
Posted: Sun Oct 29, 2017 6:10 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Here are some quick photos from this morning. Keep in mind that I'm still cleaning up the engine bay - no use wrapping everything up nicely quite yet.f
_________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sun Oct 29, 2017 6:16 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Other random things: fuel filter is under car near transmission, as recommended. All leaks fixed, except maybe super slow one from oil screen area under engine - Just watching, probably no problem.
Really was strong for a few 5 minute rides. Then stalling under load. Idling great. Revs good. Starts every time.
Thinking: clogged fuel filter, timing suddenly off? Clog in jets? _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sun Oct 29, 2017 6:17 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Gotta cover that alt terminal, I know. Haven't found a cap yet. _________________ 1973 chassis + 1974 body = super beetle saved |
sleeper bird Samba Member
Joined: August 27, 2017 Posts: 119 Location: Louisiana
Posted: Sun Oct 29, 2017 6:32 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Dont know how you pulled that wrap off with all the curves but that looks pretty damn good from the pics |
Posted: Sun Oct 29, 2017 6:44 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
That. was. Tough. And hardly perfect. But a nice experiment. So many curves!
Thanks! _________________ 1973 chassis + 1974 body = super beetle saved |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Sun Oct 29, 2017 7:30 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
ToughBug wrote: |
Thinking: clogged fuel filter, timing suddenly off? Clog in jets? |
So, if I understand correctly. Car is running fine first five minutes or so, then blahhhhhhhh. No more zest! Right?
So, on start up choke is closed causing a rich mixture. As engine warms up, choke slowly opens, about 5 minutes in total for warm up, give or take a few minutes. Sounds like a vacuum leak or an incorrect fuel float level. Clogged fuel supply, clogged air filter, restricted needle valve, gunk in the carb bowl, bad intake boots, poor end casting gaskets. Just a few of several things off the cuff.
When it starts losing power, can you pull over and pull the accelerator arm and reproduce the issue. If so, try spraying a shot of carb cleaner into the carb, indirectly, not straight down the throat. Should pick up if it is lean or there are vacuum leaks. You can also spray small blasts of carb cleaner at the intake manifold to find vacuum leaks. i.e. at the boots and head to end casting area. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sat Nov 04, 2017 9:35 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
OK, a frustrating day in the garage.
Gears 1-4 are GREAT. But no reverse.
Tried adjusting the shift plate about a dozen times. No luck.
Plate is in correctly. Long "ramp" up and to the right. Short tab up and to the left.
Removed the lock out plate entirely. Still no reverse.
I am depressing the stick. Originally it depresses about 1/2 and inch. If I loosen the bolts of course I can depress it further, about an inch.
Once today I *thought* I found the reverse slot. But now I can't get it into 3rd or 4th at all. With or without the shift plate.
I'm watching the shift rod at the coupling in back. Before 1-4 worked great but no turning counterclockwise for reverse. Now no rotation of the shift rod at all. Only forward and back for gears 1 and 2.
I'm about to uncouple the shift rod from the transmission entirely to see if the shift rod is hung up on something? bent? Would the shift rod / bushing problem ever prevent a rotating movement? That seems unlikely to me.
I am not running the engine, I'm just shifting with the clutch down to find the positions and see the shift rod operate the transmission properly.
Too bad. Last weekend I was driving in all four forward gears and it was awesome. Then I got greedy, wanting reverse too... _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sat Nov 04, 2017 9:36 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
PS - if I put my fingers or a screw driver in the shift rob socket I cn't move it at all. Maybe that is a clue. _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sat Nov 04, 2017 10:35 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
OK. Went back out to the garage after a break.
disconnected the shift rod. It moves freely in all directions and rotates as it should. It's smooth so even the bushing seems good.
hook it back up to the transmission and it only moves forward and back - no rotation so I can't move into 3rd or 4th, or reverse.
I went under the car and tightened the clutch cable, just to make sure. Now the clutch engages high on the pedal so there is no chance it isn't engaged.
I'm out of ideas... _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sat Nov 04, 2017 12:53 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
OK. better news. I put vice grips on the shift rod back under the rear seat. And with the shifter and some help from the vice grips I can go through all gears - even reverse.
A few runs through the gears this way seemed to loosen up the transmission.
Now with some force I can get through all gears just with the shifter.
Not easy or smooth yet. But progress.
Took to for a drive for a block or two. And was able to reverse out of the driveway. I'm counting this as progress. But I'm not sure exactly what I did.
Oh, changed the fuel filter today and that seemed to help the engine. There was grit in the old one. Probably from the resealed tank.
(PS - I checked in with Roy today. Just an email to ask for his thoughts. He got back within an hour on a Saturday - that's pretty great. Didn't expect that. We'll talk Monday. I think this is an adjustment issue on my end of things. Hoping that I'll get it all figured out tomorrow - which is family beetle work day around here.)
Got the wipers working today. Installing a $45 bluetooth speaker set with speaker phone, and a recharging port. The cabin is so small it's going to be plenty loud.
Still can't believe RustyBug runs. Just set up an appointment for an enhanced inspection later this month. _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sun Nov 05, 2017 11:19 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
All lights and electronics work!!!
Problems were grounds and tail light bulb connections. Took 4 hours and a helper to diagnose everything.
But we have fans, wipers, high and low beams....
Yipee! _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sun Nov 05, 2017 12:37 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Oh. Expect no turn signal flashers, hazards, or horn. Well, unravel the conundrum to get the enigma. _________________ 1973 chassis + 1974 body = super beetle saved |
